Combinations of ME EQUIPMENT and non-ME EQUIPMENT
shimonv
Hi
we have a product composed of ME equipment (Tablet PC) in the patient environment and a non ME equipment outside the patient environment (PC Workstation). The equipment is connected via RJ-45 cable.​
1. According to the 60601-1 I understand that our product is ME system. Is that correct?​
2. For the purpose of external laboratory test for compliance with IEC 60601-1 I need to take the ME equipment only. The non-ME must comply with its respective standard. Is that correct?​
3. Do I have to install a separation device on the RJ-45 cable because in connect an ME equipment with non-ME equipment?​
Thanks so much.​
Simon​
Stijloor
Hi
Thanks so much.​
Simon​
Can someone help Simon?
Thank you very much!
Stijloor..
Peter Selvey
It is an ME system, and should be evaluated under IEC 60601-1-1 (2nd ed) or IEC 60601-1:2005 Clause 16.
There are two basic principles:
(1) electrical devices should comply with their appropriate standard, e.g. 601-1 for medical device, 950 for the external PC
(2) the set up should not cause leakage over the limits in 601-1 inside the patient area in normal condition and with any single earth wire broken
The second part is a bit of a problem as it is really a case by case situation.
For example, if the external PC is Class II with low leakage, maybe no action is required. If the medical device and external PC both are Class I (earthed) and plug into the wall separately, again maybe no action is required since there are effectively two separate earths, breaking one is not a problem.
But if the medical device is Class II (double insulated, no earth) and the PC is earthed, then a broken earth in the PC could result in high leakage going to the medical device and hence the patient.
A separation device simplifies things. Other possibilities are using an isolation transformer for the PC, or adding another earth to the wall.
In any case, most manufacturers simply provide a warning that the person who sets up the system should follow IEC 60601-1-1 (or IEC 60601-1:2005 Clause 16). It's a bit of a cop out, as most users wouldn't know what that means.
In truth it's not that critical for most medical applications. There are only special cases where it would really be important. Leakage from a PC can be high enough to hurt, but not stop your heart if applied external to the body. Important cases are for example if a surgeon is performing a delicate operations, where shock could cause them to move quickly (from pain) and then injure the patient (unintended action); catheters which might direct the current straight to the heart, or open heart surgery.
V Informational EMA - Quality requirements for drug-device combinations EU Medical Device Regulations 0
D Minitab - Design combinations (DOE) Using Minitab Software 4
D Risk Management for Drug-Device Combinations ISO 14971 - Medical Device Risk Management 1
B Drug Device combinations - Drug degradation and impurities Other Medical Device and Orthopedic Related Topics 2
A Canadian Safety Labels for medical electrical equipment Canada Medical Device Regulations 0
lanley liao Question regarding the calibration of monitoring and measure equipment. Oil and Gas Industry Standards and Regulations 0
P Equipment URS, pFMEA and dFMEA ISO 14971 - Medical Device Risk Management 3
D Question on equipment - when to use reference only or research only stickers ISO 13485:2016 - Medical Device Quality Management Systems 5
L Gage RandR on automated equipment. IATF 16949 - Automotive Quality Systems Standard 7
W How long do you keep information about equipment no longer used? Document Control Systems, Procedures, Forms and Templates 2
B 4DINSPEC Inspection Equipment General Measurement Device and Calibration Topics 0
D Equipment Register and PM question ISO 13485:2016 - Medical Device Quality Management Systems 2
R Classification of USB DC operated medical equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
H IEC 60601-1 ME equipment or ME system IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
D Definition of equipment for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 1
J Confusing on Harmonic Emissions/Voltage Fluctuations/Flicker test for CISPR 11 Class A Equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Equipment Register related question ISO 13485:2016 - Medical Device Quality Management Systems 1
Y We found out we have been using a equipment without validation for past 4 years Quality Manager and Management Related Issues 6
I Equipment service dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Missing measuring equipment General Measurement Device and Calibration Topics 6
P Equipment 21 CFR 820.70(g) - User Requirements Document for Off the shelf equipment 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
G Is repeatability required for equipment calibration? General Measurement Device and Calibration Topics 10
A Looking for a third party to calibrate our measure equipment - South Carolina General Measurement Device and Calibration Topics 6
K Problems with process equipment ISO 13485:2016 - Medical Device Quality Management Systems 4
D New Equipment form / template Document Control Systems, Procedures, Forms and Templates 5
W Protective earth for Class I ME equipment IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
R MSA for ATE (Automatic Test Equipment Embedded Software) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
P Design verification driven by new equipment. How is this different than process validation? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D DQ documents of new equipment - Function specification Qualification and Validation (including 21 CFR Part 11) 0
R MSA studies for Heat Treatment Equipment Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
T AMS2570E certification equipment questions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
J Class Fixed ME Equipment (US Deviation) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
P Manufacturing equipment (e.g.: Dental Welder): medical device or not? US Food and Drug Administration (FDA) 5
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
D Infrastructure: Equipment, Work Environment and Contamination Control ISO 13485:2016 - Medical Device Quality Management Systems 4
M Are Electrical Laparoscopic Surgical Devices ME equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
D Definition of "Critical Laboratory Equipment"? General Measurement Device and Calibration Topics 1
N Calibration Requirements for Production Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
T How to “validate/qualify” a new measurement equipment? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
D Software validation in Medical Equipment Other Medical Device and Orthopedic Related Topics 20
I Approved Suppliers ISO/IEC 17025:2017 and used test equipment ISO 17025 related Discussions 6
S Calibration Equipment Selection General Measurement Device and Calibration Topics 2
A Handling of contaminated medical equipment Other Medical Device and Orthopedic Related Topics 0
T Confirming The Local Safety Regulations for Equipment - I'm in Malaysia General Measurement Device and Calibration Topics 1
B IEC 60601 Cl. 8.4.3 - ME EQUIPMENT intended to be connected to a power source by a plug / Plug discharge IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Y Packaging validation for non-sterile Medical Equipment Other Medical Device Related Standards 1
E Equipment Qualification - IQ/OQ per ISO 13485:2016 section 7.5.6 Process validation ISO 13485:2016 - Medical Device Quality Management Systems 7
A Contraindication Safety Statement in website - Radiotherapy equipment Other Medical Device and Orthopedic Related Topics 1
B What is 'equipment'? Qualification and Validation (including 21 CFR Part 11) 2
