Combined Environmental / Quality Manufacturing Process Audit
#11
Karen -
I really like the chart format that you incorporated into the Auditee, Product, and Monitoring and Measuring Equipment sections. Keeps things well organized and easy to find.
This will help a lot. Thanks!
P
Pinkpetall
#13
Karen R said:
We also have a more generic version of the checklist, which can be used for any process. Guess I could have attached that too :) I also have a summary question sheet I use during auditor training, perhaps that will help, so I'll attach that too!
Hello Karen, I make some reading of your "audit plan blank", but here I have a question needing trouble you to free,
Does you mean it applys to all process in company, so I want to get know how you to identify your company activity?
Now our company have such process as like "document and data control" or "Supplier selection", it is just a support process, so if audit these two processes according to your audit plan, then which product producing from it, and what Monitoring and Measurement Equipment as Gauge/Measuring Device. As it is a not value-adding process, so what is its product?
Perhaps I have not well understand, I think I will get more wonderful thoughtness if I get your answer. :thanx:
Pinkpetall
K
Karen R
#14
Good questions, Pinkpetall. We use the audit tool for each of our production processes, which have been identified on our master process flow, and key support processes - Purchasing, Maintenance and System Administration. Document and data control is audited as part of each process - if I audit the lab, for example, I will ensure that they have access to procedures, the procedures and forms are current, there are no uncontrolled documents in use that could impact the system, etc.
Once per year, when I audit System Administration, I will look at the document control process itself - do I have a documented procedure that complies with the standard, does the overall process appear to be effective, etc. When I do that, there is no "product" to trace, tho I suppose I could track several documents and ensure that they are properly controlled, updated, approved, revisions have been communicated, and the like. I don't though since I've done that a piece at a time when I look at each production process.
As far as supplier selection, that is part of the Purchasing Process, and audited then. For Purchasing, its product is the primary output of the process, which would be a completed purchase order and received product. For completed purchase orders the criteria would be appropriate approvals obtained, appropriate vendor selected (approved vendor for critical product, all vendor paperwork on hand), sufficient detail included on PO (specs, timeframe, if calibration - the calibration standard info is there). For received product I would make sure that all the steps for receipt and inspection were completed, inspection sheets in order, material received on time, and any discrepancies resolved. In our case, Purchase does have equipment subject to calibration - the tools used to inspect certain incoming material.
In summary, the product for any process is it's primary output - a controlled document, a completed purchase order, a received product, a training record - and it's criteria are whatever your process deemed critical. If a section of the form does not apply, like equipment calibration, you can simply note that it's not applicable.
Hope that helps! If you need more clarification, just ask :)
P
Pinkpetall
#15
Thank your answer.
I see, this will be useful for me to improve the effectiveness of audit. It breaks the original checklist audit and just adapt to the activity of company. Sometimes only find a appropriate method for self, it should be operated well.
Thanks more. I got it.
#16
All,
I went ahead and performed a combined manufacturing process audit a few weeks ago. I have attached the audit documents that we used.
The "Combo Process Audit Definition Form" is a form that BSI (our registrar) uses to define processes that they are auditing. I just made a few adjustments to include the environmental side of things. I figured that this was a good way to begin, so that the auditors get a good understanding of the process that is being audited.
The "Combo Process Audit Checklists" are organized so that every section of the process definition form has it's own set of questions. My thinking was that by doing it this way, it would show that we are basing the audit more from a process approach, not the standard element-by-element approach. As you can see, I just plucked out questions from the standards that would apply to a manufacturing process audit, and put them into their corresponding process catagories.
This is definitely still a work in progress, because I am not entirely happy with it. To me, it still smacks of your standard elemental checklist. I would like to work in some kind of a work sheet that would summarize the actual performance of the process against established quality and environmental goals. I have seen these types of worksheets for quality and the environment seperately, but I haven't come up with a combined one yet.
I think that the biggest obstacle we came across during the actual audit was that the quality auditor (me) and the environmental auditor on the team kept wanting to go our seperate ways. There are a lot more TS questions than ISO-14001 questions, so if we stayed together the environmental guy was just sitting there doing nothing much of the time. Since it was supposed to be a combined audit, I wanted to stick together as much as possible so that we could learn from each other. This didn't happen to the degree that I would have liked. It may have been complicated by the language barrier (the audit was performed in a Mexican plant, the environmental auditor is Mexican and doesn't know much English, and I'm your typical monolingual gringo). The obvious way to get around this is to have internal auditors qualifed in both standards, but I still think that there is a way to structure the audit so that a team of quality and environmental auditors could do an effective and efficient audit. I just haven't figured out the best structure yet.
Anyway, I apologize for the length of this post! Please give me your input if you have any.
jmurph01
#17
Ken,
At first glance this looks really good. I will definately be reviewing it further as this is something I would like to do at our plant. I would deffinately agree that one auditor or a team of auditors that have knowledge on both QMS and EMS would give you better results. I have found that it is hard to get our QMS internal auditors to pickup on environmental or safety related non-conformances. During one of our first TS based audits we found a fan missing the cover and the fan blade was very wobely - I deffinately didn't want to stand near it for even a few minutes but this was directed at an employee (for cooling) who stood in front of it for 8 hours! I said we should put it as a NC and issue a corrective action but was faced with another auditor that said "but why, it's not a quality concern!". Point is, TS is a more comprehensive system that covers more broader spectrum then before. And if one looks at it as a "management system audit" then this clearly is poor management of a safety aspect.
Thanks for posting this!!! Please post any further improvements, as this is a big help to others style sorting through this issue!
Jennifer
Claes Gefvenberg MR Agenda - Combined Quality, Environmental & Energy Mgmt System Other ISO and International Standards and European Regulations 5
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Q Risk/Opportunity in a combined ISO 9001 & 14001 System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Sequence and Interaction - Combined for both ISO 9001:2015 and EMS 14001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 9001:2015 and EMS 14001:2015 combined audit checklist General Auditing Discussions 5
A Combined ISO 13485 Certification with ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 23
H Combined Procedure - Control of Non-conforming Product, Corrective and Preventive Document Control Systems, Procedures, Forms and Templates 14
F Control Points in a combined BRCv6 and IFS v6 system Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
E QP (Qualified Person) for Combined Pharma-Medical Devices Quality Manager and Management Related Issues 1
G ISO 14001 and ISO 9001 Combined Quality Manual ISO 14001:2015 Specific Discussions 7
H Two Business Units Combined in the same Building ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Ppk for Combined Data Sets Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Combined Uncertainty of an Indirect Measurement Measurement Uncertainty (MU) 8
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
Jerry Eldred Combined Uncertainty With Multiple DC Reference Standards Measurement Uncertainty (MU) 4
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
D What is required in a combined ISO 9001, ISO 14001 and OHSAS 18001 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
F Combined ER/EP Checklist template that covers both MDD ERs and Australian EPs EU Medical Device Regulations 1
N NCR (Nonconformance Report) Combined with Corrective Action Report? Nonconformance and Corrective Action 1
B Combined ISO 9001/ISO 14001 Internal Audits Miscellaneous Environmental Standards and EMS Related Discussions 7
S IFU for combined OTC Medical Device in light of IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Ajit Basrur Combined Search by Baidu and Google After Work and Weekend Discussion Topics 4
somashekar OSHAS 18001 and ISO 14001 Combined Survelliance Audit Manday Guidelines Occupational Health & Safety Management Standards 5
T Quality Check Sheet combined with Work Instruction Document Control Systems, Procedures, Forms and Templates 3
F What Combination (Combined Advanced Therapy Product) Products are Approved in the EU? EU Medical Device Regulations 2
A Interaction of Processes for both ISO 9001 & ISO 14001 Combined Misc. Quality Assurance and Business Systems Related Topics 4
S Error Accumulation - Combined Result without going to Partial Derivitaves Capability, Accuracy and Stability - Processes, Machines, etc. 2
J Registrars Doing Synchronized (Combined) Audits to AS9100 and ISO 13485 Registrars and Notified Bodies 8
D FDA Requirements for Combined Software US Food and Drug Administration (FDA) 3
harrysons Combined checklist for ISO 9001, ISO 14001 and ISO/TS 16949? Document Control Systems, Procedures, Forms and Templates 1
C IMS (ISO 14001/ BS OHSAS 18001) combined Audit Checklist & Schedule ISO 14001:2015 Specific Discussions 1
R CAPA (Corrective Action Preventive Action) Procedures Separate or Combined Nonconformance and Corrective Action 9
B Cl. 4.4.7 (Emergency Preparedness) Combined ISO 9001 & ISO 14001 ISO 14001:2015 Specific Discussions 2
W ISO 13485, ISO 9001, and AS9100 Combined QMS Manual Quality Management System (QMS) Manuals 14
B Combined ISO 9001 and ISO14001 audit Internal Auditing 5
W ISO 9001:2008 and AS9100 combined Quality Manual (Systems Manual) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 53
L Combined Corrective and Preventive Action Procedures? Document Control Systems, Procedures, Forms and Templates 19
P Combined ISO 9001, ISO 14001 and OHSAS 18001 Manual and System Quality Management System (QMS) Manuals 8
I Combined ISO 14001 / OHSAS 18001 Implementation ISO 14001:2015 Specific Discussions 16
P Auditing to Combined ISO9001 and ISO14001 Systems General Auditing Discussions 5
Marc Combined ISO 9001:2000 ISO 14001:2004 Compliance Audit Form General Auditing Discussions 8
A Relative or Combined Type A & Type B Uncertainty Calculation? Measurement Uncertainty (MU) 4
P ISO 9001:2000 and ISO 17025 combined Quality Manual needed ISO 17025 related Discussions 9
T Pros and Cons of Combined TS 16949 and ISO 14001 Audits General Auditing Discussions 3
Jen Kirley "Micro Combined-Heat-and-Power" System (micro-CHP) - The future of home energy? World News 10
