Combined ISO 14001 / OHSAS 18001 Implementation
Jen Kirley
Quality and Auditing Expert
#11
Welcome to The Cove! :bigwave: Wow, your plate is piled high isn't it?
EMS and OSHAS have so much in common that implementing them together is doable - in fact, I would prefer doing that over merging the systems later as I will be eventually doing where I work.
In this thread I included a link to an information source from LRQA that may be of some initial help. (I am not affiliated with LRQA) The site also has LRQA's implementation planner for ISO14001 to help give you some idea of what to expect.
IMO, You should first attend schools in both of these standards, to make ready for designing a system. I have also found it helpful to have OSHA's 10-hour card, which you may be able to get with help of your state's Dept of Labor. Check your state's web site for information on available training help for employers; maybe there is something for environmental too.
I hope this helps!
harry
#12
Knowing how each of these 2 standards relate to each other makes the starting part much easier. Have a look at: OHSAS14k9k2k comp.doc (ISO 9001 VS ISO 14001 VS OHSAS 18001)
Note: the ISO 14001 in the comparison table is the 1996 version which is slightly different from the 2004 version. There is also a comparison table for these 2 in the files attachment list.
RoxaneB
#13
Before I joined the Dark Side (aka Corporate), I worked at a site and was tasked with integrating the systems. The management group was...and is...a firm believer in one-stop shopping. The managers didn't want a quality management system...an environmental management system....a health & safety system....they wanted a business management system or BMS.
Our own company's core system is based on Plan-Do-Check-Act (PDCA) and that was, I decided, to be the set-up of our BMS. From there, I studied our applicable standards and aligned them with PDCA. The end result was a matrix in a PDCA format that showed the alignment between ISO 9001, ISO 14001, OHSAS 18001, ISRS, Sarbanes-Oxley and our own company's business system requirements. Due to the confidential nature of our own company's requirements, I am unable to share the matrix at this time. I will look at it, however, and see if I can tweek it by removing company-related information.
That being said, I was only able to do this based on my own knowledge of the company, along with training in the applicable standards.
What the matrix enabled me to do next was align our system and processes. Internal auditing was internal auditing...it didn't matter the scope. The concepts and flow were the same, while the people might be different. In the following year, we worked on integrated audits and they continue - even after my absence - to do internal audits that address the requirements of ISO 9001 and ISO 14001. I hadn't evolved yet to incoproate health and safety and no one has run with that since I left.
Nonconformances and corrective action were the same, no matter what. Same log. Same form. Same system.
It has helped the site in breaking down the walls between departments and in having everyone speak the same language.
I
Indrit
#14
Thank you all for the replies.
I have read both standards 14001 and 18001. I have an idea now about both standards, yet I still need to see some implementation sample, Implementation template. Can someone please send me a sample of their plan? I don’t know where to start and how to build my plan up. It does not matter if your plan has to do with another company and its products; I think somehow the plan should be the same in principals. Any kind of excel spreadsheet, or else would help. Overall plagiarism (if allowed by the source :) ) it is good sometimes if the purpose of using it bring us the good and the comfortable.
Regards,
Indrit
ajikkn08
#17
Hi indrit,
I would suggest you to first go through the requirements for ISO 14001 and OHSAS in detail.Carry out a gap analysis of your organisation.find out what are gaps ..Select core team member through the management.
Familiarize the members to the iso 14001/18001 through a training programme and ensure it is perculated down.
Together with the core team members fill the gap,prepare procedures,records as necessary...ensure reckoner ongovernment regulation on safety and environment also si simultanously prepared.
Prepare Manual on env and safety.
train internal auditors.
conduct internal audit.
conduct MRM and then apply for certification.
YOU CAN DO IT.
Cheers,
Kris
Q Risk/Opportunity in a combined ISO 9001 & 14001 System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Sequence and Interaction - Combined for both ISO 9001:2015 and EMS 14001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
R ISO 9001:2015 and EMS 14001:2015 combined audit checklist General Auditing Discussions 5
J Can I conduct Internal Audit for combined ISO 9001, ISO 13485 and ISO 14001? Internal Auditing 37
D Combined Quality Manual for ISO 9001, ISO 14001, ISO 50001 and OHSAS 18001 Document Control Systems, Procedures, Forms and Templates 11
G ISO 14001 and ISO 9001 Combined Quality Manual ISO 14001:2015 Specific Discussions 7
D What is required in a combined ISO 9001, ISO 14001 and OHSAS 18001 Audit? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
B Combined ISO 9001/ISO 14001 Internal Audits Miscellaneous Environmental Standards and EMS Related Discussions 7
somashekar OSHAS 18001 and ISO 14001 Combined Survelliance Audit Manday Guidelines Occupational Health & Safety Management Standards 5
A Interaction of Processes for both ISO 9001 & ISO 14001 Combined Misc. Quality Assurance and Business Systems Related Topics 4
harrysons Combined checklist for ISO 9001, ISO 14001 and ISO/TS 16949? Document Control Systems, Procedures, Forms and Templates 1
C IMS (ISO 14001/ BS OHSAS 18001) combined Audit Checklist & Schedule ISO 14001:2015 Specific Discussions 1
B Cl. 4.4.7 (Emergency Preparedness) Combined ISO 9001 & ISO 14001 ISO 14001:2015 Specific Discussions 2
P Combined ISO 9001, ISO 14001 and OHSAS 18001 Manual and System Quality Management System (QMS) Manuals 8
Marc Combined ISO 9001:2000 ISO 14001:2004 Compliance Audit Form General Auditing Discussions 8
T Pros and Cons of Combined TS 16949 and ISO 14001 Audits General Auditing Discussions 3
H What are the Current OHSAS 18001 & ISO 14001 Revisions & Combined Systems Various Other Specifications, Standards, and related Requirements 37
A ISO 14001 and ISO 9001 combined? Talk within ISO to combine these two specs ISO 14001:2015 Specific Discussions 12
J Rockwell (Honeywell) example manual of ISO 9001 and ISO 14001 combined Quality Management System (QMS) Manuals 5
I Three Combined Systems - An IQMS if you will - OHSAS 18000, TS 16949 and ISO 14001 ISO 14001:2015 Specific Discussions 10
Claes Gefvenberg An interesting audit coming up - First combined ISO 9001 / 14001 surveillance audit General Auditing Discussions 6
M Scope of Combined ISO 9001 and IATF 16949 QMS - Non-automotive customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Combined ISO 13485 Certification with ISO 9001:2015 ISO 13485:2016 - Medical Device Quality Management Systems 23
P Separate procedures? ISO 14k System combined with OHSAS 18001 Occupational Health & Safety Management Standards 3
J Registrars Doing Synchronized (Combined) Audits to AS9100 and ISO 13485 Registrars and Notified Bodies 8
W ISO 13485, ISO 9001, and AS9100 Combined QMS Manual Quality Management System (QMS) Manuals 14
B Combined ISO 9001 and ISO14001 audit Internal Auditing 5
W ISO 9001:2008 and AS9100 combined Quality Manual (Systems Manual) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 53
P ISO 9001:2000 and ISO 17025 combined Quality Manual needed ISO 17025 related Discussions 9
D ISO 22000 combined with ISO 9001 - Implement both or only one of them? Food Safety - ISO 22000, HACCP (21 CFR 120) 62
G Combined ISO 9001 - TS 16949 Audit check list in German - Translation Needed! IATF 16949 - Automotive Quality Systems Standard 3
C Combined audit - ISO 9001 and ISO 13485 - Why Separate Audits? General Auditing Discussions 5
T ISO 9001 + HACCP implementation - Statistics and/or surveys on Combined Registrations Food Safety - ISO 22000, HACCP (21 CFR 120) 15
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
H Combined Procedure - Control of Non-conforming Product, Corrective and Preventive Document Control Systems, Procedures, Forms and Templates 14
F Control Points in a combined BRCv6 and IFS v6 system Food Safety - ISO 22000, HACCP (21 CFR 120) 1
P Applying Combined Tolerances of Two Scales - Balance Tolerance Question General Measurement Device and Calibration Topics 9
E QP (Qualified Person) for Combined Pharma-Medical Devices Quality Manager and Management Related Issues 1
H Two Business Units Combined in the same Building ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Ppk for Combined Data Sets Capability, Accuracy and Stability - Processes, Machines, etc. 6
S Combined Uncertainty of an Indirect Measurement Measurement Uncertainty (MU) 8
B Calculating Combined DPMO and Sigma Level for Two or More Different Work Areas Six Sigma 3
Jerry Eldred Combined Uncertainty With Multiple DC Reference Standards Measurement Uncertainty (MU) 4
A Calculating Combined Measurement Uncertainty - VDA 5 Measurement Uncertainty (MU) 1
F Combined ER/EP Checklist template that covers both MDD ERs and Australian EPs EU Medical Device Regulations 1
N NCR (Nonconformance Report) Combined with Corrective Action Report? Nonconformance and Corrective Action 1
S IFU for combined OTC Medical Device in light of IEC 60601-1-11 IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
Ajit Basrur Combined Search by Baidu and Google After Work and Weekend Discussion Topics 4
T Quality Check Sheet combined with Work Instruction Document Control Systems, Procedures, Forms and Templates 3
F What Combination (Combined Advanced Therapy Product) Products are Approved in the EU? EU Medical Device Regulations 2
