Commercial Grade Dedication requirements for a 10CFR50 Appendix B Manufacturer
Bubba
I am looking for some assistance to clarify my understanding of commercial grade dedication requirements for a 10CFR50 Appendix B manufacturer that supplies items to nuclear utilities.
Situation: My company manufactures electrical components for nuclear utilities under a 10CFR50 Appendix B program that utilizes NQA-1 for the framework of our quality system documentation. We test our finished assemblies for 1E qualification using IEEE 323 and IEEE 344. We also provide 10CFR21 reportability defects discovered with our product. In this situation we are providing a basic component to our customer.
The design of our product requires us to procure commercially available items such as resistors, capacitors, relays, etc. that are used to build our finished product. Are these items that are the building blocks of our finished products in need of commercial grade dedication in accordance with industry standards (EPRI, 10CFR21, etc.) or are they merely part of our design bases in accordance with our Appendix B program used to produce a qualified basic component?
I welcome any comments I can get from those that are more experienced and well versed than I am in the nuclear industry. :confused:
Stijloor
Comments anyone?
Thank you!!
Stijloor.
P
PittsburghBrass
Bubba,
I am in the beginning stages of a CGD program, though I am unsure as to how to effectively get started. My research into CGD has yielded lots of generalities but few specifics on how-to, etc. Feel free to email if we can compare notes.
Thanks.
rgunn1
Just glancing at NQA-1-2008, commercial grade dedication would only apply if the item performs a safety function. Regardless, for each item in your assembly, I would maintain a documented analysis on whether or not commercial grade dedication is required per 10 CFR 50 / NQA-1. Hope this helps!
H
Hemi999
I work mostly in materials but the basis of any dedication is Engineering must determine the critical charismatics. If you do not have an engineering department the customer must tell you the charismatics to test. In the material area it is easier to determine because the ASTM /ASME specifications give you a starting point. I would be glad to provide some specific assitance. my contact is 910-988-4399.
Bubba
Thank you to those that have offered their assistance. NQA-1 2008/2009a is the edition of NQA-1 that we apply to our quality program. I have recently discovered a standard from EPRI that has enlarged my understanding of CGD from a manufacturer's perspective. Our auditors consistently call out EPRI 5652 as the standard to use for CGD, but EPRI TR-102260 (Supplemental Guidance for the Application of EPRI Report NP-5652 on the Utilization of Commercial Grade Items) is much more useful for our needs. Section 3.0 is specific to Supplier Dedication Issues and contains four acceptance options in section 3.2.2. Option D is the one that applies to the original situation that I wrote about in March. It states, "the original equipment manufacturer is buying several commercial grade parts and possibly raw materials (e.g., potting compounds) that are installed into an assembly. The assembly, inspection, and testing process is performed in accordance with the supplier's nuclear quality assurance program... If the combination of the assembly, inspection and testing of the complete assembly demonstrates the acceptability of the parts, the individual commercial grade parts may be accepted and dedicated by this process."
So, to summarize my new understanding, all of the commercially procured items that become part of our manufactured basic component do need to be dedicated. However, we may dedicate them through the implementation of our 10CFR50 Appendix B program as we inspect and test the completed assembly rather than through individual component dedication procedures.
If I have not applied this guidance correctly, please let me know. I am still learning. PittsburghBrass, hopefully this discovery can be of use to you as well.
H
Hemi999
The EPRi standards are good basis for deication but the NRC further requires that the components be dedicated before assembly unless you do a tremdous amount of testing of the assembled parts. This is one of the problems in the industry, there are standards out there but there government departments that add to those requirements.
If you have any questions contact me at 910-988-4399 if I cant give you a response that way I will research the question with some of my contacts.
Jim
crager34
Some info (I pulled a few relevant sections, but the whole thing is worth a read through:
NRC - LICENSEE COMMERCIAL-GRADE PROCUREMENT AND DEDICATION PROGRAMS (GENERIC LETTER 91-05)
In NRC Generic Letter (GL) 89-02, "Actions to Improve the Detection of
Counterfeit and Fraudulently Marketed Products," the staff described its
perspective on good practices in procurement and dedication and provided the NRC's conditional endorsement of an industry standard (EPRI NP-5652) on methods of commercial-grade procurement and dedication. A number of recent inspection findings, as discussed in Enclosure 1, indicate that licensees have failed to include certain key activities, as appropriate, in the implementation of the dedication process.
The term "critical characteristics" is not contained in Appendix B and has
no special regulatory significance beyond its use and definition in various
industry guides and standards. The NRC first used the term critical
characteristics in GL 89-02 as constituting those characteristics which need
to be identified and verified during product acceptance as part of the
procurement process. The NRC has not taken the position that all design
requirements must be considered to be critical characteristics as defined
and used in EPRI NP-5652. Rather, as stated in Appendix B, Criterion III,
licensees must assure the suitability of all parts, materials, and services
for their intended safety-related applications (i.e., there needs to be
assurance that the item will perform its intended safety function when
required). The licensee is responsible for identifying the important
design, material, and performance characteristics for each part, material,
and service intended for safety-related applications, establishing
acceptance criteria, and providing reasonable assurance of the conformance
of items to these criteria.
A licensee may take different approaches for the verification of the
critical characteristics, depending on the complexity of the item. In
many cases, the licensee can verify the critical characteristics of
each item during receipt inspection testing. However, for a complex
item with internal parts which receive special processing during
manufacturing, the licensee may need to conduct a source verification of the manufacturer during production to verify the critical
characteristics identified as necessary for the item to perform its
safety function. When these methods cannot verify the critical
characteristics related to special processes and tests, certification
by the original equipment manufacturer may be an acceptable alternative
provided documented, verified traceability to the original equipment
manufacturer has been established and the purchaser has verified by
audit or survey that the original equipment manufacturer has
implemented adequate quality controls for the activity being certified.
C Commercial Grade Supplier Surveys - Not qualifed 10CFR50 Appendix B or NQA-1 Other ISO and International Standards and European Regulations 2
B Components "Commercial grade" vs "Automotive grade" Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
DMLqms Country of Origin on Commercial Invoices EU Medical Device Regulations 2
P Qualifying commercial off the shelf (COTS) external suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Medical Device not on commercial distribution but installed in the establishment. 510k? Other US Medical Device Regulations 10
DuncanGibbons To what extent are NASA standards applicable to commercial aviation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B IATF 16949 Cl. 4.3.2 - CSR vs Commercial Agreements IATF 16949 - Automotive Quality Systems Standard 8
shimonv Creating a new commercial product based on a modification to an existing product Other US Medical Device Regulations 4
Ajit Basrur How do I label this commercial product ready for clinical study? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Design exclusion in AS9100D for commercial products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P What is expected in a Medical Device Commercial Release Procedure Design and Development of Products and Processes 3
F Definition Commercial Distribution - Definition - Scope of Commercial Distribution Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Commercial tablet as an "accessory" for a medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
S COTS (commercial off-the-shelf) Validation FDA Requirements Software Quality Assurance 4
E Commercial Laboratory Audit Tips ISO 13485:2016 - Medical Device Quality Management Systems 2
S ISO 15189 - When commercial QC Material is not available Hospitals, Clinics & other Health Care Providers 4
B Commercial Calibration Laboratory Software Recommendations Calibration and Metrology Software and Hardware 1
T ISO 17025 - 4.1.5b Internal/External commercial, financial, and other pressures ISO 17025 related Discussions 3
B List of all Auto Parts in a Commercial Vehicle Manufacturing and Related Processes 11
C Apostille of French Commercial Documents for the Republic of Turkey EU Medical Device Regulations 5
H Certification of a large commercial helicopter acc. AC29-2C / CS29 EASA and JAA Aviation Standards and Requirements 1
V Common Root Cause for Failures in Scaleup & Commercial (Validation) Batches 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Regulatory Value of Commercial Documents (Brochures, Marketing Leaflets, etc.) EU Medical Device Regulations 2
M Everything to AS9100 vs. ISO 9001? Commercial Jobs require AS9100 "Extras"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Regulatory requirements for Commercial Medical Devices for sale in Europe ISO 13485:2016 - Medical Device Quality Management Systems 2
B Ideas on how to differentiate jobs (AS9100 jobs vs. "commercial" jobs) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Jim Wynne "Massive" Epsilon Interactive Commercial Email Breach After Work and Weekend Discussion Topics 7
S Risk Management in terms of Technical and Commercial Failure (Disaster Recovery) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Commercial Measurement of Raw Materials/Production etc. Manufacturing and Related Processes 2
B References for GMP Consultants in Illinois (trade/commercial printer/packaging) Quality Manager and Management Related Issues 3
N COTS (commercial off-the-shelf) Computers - Warranty return rate? Benchmarking 3
Pancho Oquma - a new QMS-on-wiki commercial offering Imported Legacy Blogs 3
D ITAR/EAR and effects on commercial Heat Treating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Dutch Commercial & Environmental legal requirements for enterprises Miscellaneous Environmental Standards and EMS Related Discussions 14
A Packaging Commercial off-the-shelf (COTS) Products as a Single System Design and Development of Products and Processes 2
D Purchase ? Guidelines - Technical and Commercial Evaluation Guidelines for Products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Taking Lean beyond 5S - Commercial Printer Lean in Manufacturing and Service Industries 10
R LCD-TFT screen with player for publicity film - Commercial device CE Marking CE Marking (Conformité Européene) / CB Scheme 1
D Commercial and AS9100 operation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
ISOsandy Looking to expand into Commercial Nuclear Various Other Specifications, Standards, and related Requirements 11
I Validation of Commercial off-the-shelf software - Spreadsheets ISO 13485:2016 - Medical Device Quality Management Systems 16
W What Commercial (off the shelf) QMS Software are you using - Any Recommendations? Quality Assurance and Compliance Software Tools and Solutions 14
A Process for receiving functions - COTS (commercial off the shelf) vs Custom parts. Document Control Systems, Procedures, Forms and Templates 6
W ISO 9001 certification (registration) requirements - No commercial product or service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 42
R Certificate of compliance (C of C) DOD requirements for commercial items in products Various Other Specifications, Standards, and related Requirements 3
L Any tips on setting up a Quality Management System for a Commercial Printer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Marc No Commercial Advertisements Allowed In This Forum Buy, Sell or Trade - NO Commercial Advertisements 8
