Commercial Quality Assurance Software (ie: SAP) vs. Custom Databases
mlthompson
What is everyone's experience regarding enterprise wide software (i.e SAP) vs purchased software vs developing custom (access) databases. Which gives you the best overall results (functionality, capabilities, usefulness, etc)?
Also, how many Quality Assurance professionals have found that database programming has had to become a necessary skillset in the quality field?
Re: Quality Assurance Software vs. Custom Databases
Aaaargh! SAP is an ugly word here. It has been forced down our throats to replace other more suitable local applications, and we have little control over it.
Could be the way to go if you can find something that fits your needs. If it does not, you may want to change your routines rather than going for local adaptations (Those may be a dreadful liability when the inevitable upgrades turn up).
May be worth your while if no commercial application fits your needs, but beware: It could gobble up your meagre recources (working hours) at an alarming rate, and thus be more costly than an off the shelf application! My advice is to build something very basic to set you off, and then improve and expand it as the need arises.
That, alas, is impossible to say. Different companies, different needs...
I for one... When we downsized I had to take over several tasks previously performed by others. I pushed everything else out of the way for a couple of weeks, while I created a number of tools I needed to be able to cope with the increased workload. To make a long story wonderfully short, that move saved my bottom. Ulcers were lurking around the corner....
/Claes
Q
qualitygal
Re: Quality Software vs custom databases
From what I've seen I stay away from anything that is canned. Develop your own stuff. At least that way you know how it works. The problem I run into all of the time with my clients is that the IT guys that do customized programing don't really know anything except I/O. You can spend endless hours trying to fix what someone else thinks you do. I have some really great CPAR and NCR logs that I developed myself and they are in Excel. Not everyone understands Access and the like. And sadly most Quality people are people who are put in the position because no one else wants it.
Sleepless
I've found that a lot of quality needs focus around traceability. Although most enterprise solutions claim complete traceability between each piece of software, there usually are some issues (sometimes big issues) that make the enterprise solution less valuable than it might first appear.
Off the shelf software and home made stuff both have pros and cons. It really depends on knowing what you need to accomplish and understanding whether the potential software can meet that need or not. Do your homework before making the decision.
Helmut Jilling
Auditor / Consultant
Your question is very broad. ERP/MRP databases, like SAP, are far bigger than just quality software. They literally run the whole enterprise, incuding accounting. That kind of decision would invilve your whole management.
Most bigger organizations go to this level of systems, though implementation and customizing is very costly. If done well, they are wonderful. But the cost and time to get there can be great.
If your needs are smaller, just quality software, then you have to define your need, and disuss particular software.
mlthompson
I guess I'm just venting. I'm just trying to get a feel for how other Quality Managers are addressing and/or struggling with the IT needs in their departments. The companies I have worked for, typically 700-1200 corporate wide employees, who have enterprise wide systems haven't been willing to take on the expense of adding the QA modules. Purchased software doesn't always accommodate specific needs. IT departments don't have the programming talent/time to develop what I need. So out of survival, like Claes, I have had to develop custom databases to handle the information/data that flows through my department (all of which saves tons of man-hours and generates CI from the previous archaic methods). Yet I get scruntinized saying the programming isn't a Quality Manager's job. I would be as effective as a screen door in a submarine without the database tools.
Putting the frustation aside, what other job requires such a variety of skills. QA people have to be database programmer, graphic designer (visual factory), housekeeper (5S), design engineer (designing test fixtures), manufacturing engineer, statistician, project manager, politician, cheerleader, cop, business analyst, accountant, public speaker, teacher, infomercial saleperson, lawyer, author, photographer, ...
Yes, but other than that we don't really do much.:D
I just wanted to say a word about software documentation. Many moons ago, in the embryonic days of what was then quaintly referred to as "data processing," programmers provided job security for themselves (and did a kind of extortion) by writing programs with syntax and logic streams that were so convoluted and anfractuous that no one else could figure them out. Oftentimes when a programmer moved to another job, there was weeks of trying to figure out how to do maintenance on his creation. This lead to a team-based approach and initially something called structured programming which in turn evolved into object-oriented programming.
The goal was to produce "lean," modular, well-documented code that was optimized for both speed of execution and ease of maintenance. I bring this up here to emphasize the need for good documentation of "home brew" programming solutions. If the programming works well for you but the next person who comes along doesn't understand your strategies, algorithms and logic flow, there's going to be trouble. A narrative description of what the program does and precisely how it does it should always be considered de rigueur.
Sleepless
I agree with Jim. And again, I would point to really understanding the 'need' you're trying to meet with the software (or any tool). If you understand the need, then anyone else who comes along, can make use of the tool you bought or created. If you don't really understand the root-need, you run the chance of finding/creating something less useful than it could have been.
MisterD
I am aware of a nice Quality Management System that is easy to use
and provides conectivity to your Access DB, SQL, or ODBC
require specifics?
Marc
require specifics?
This is your first post. Are you in any way associated with the software you are recommending?
I am asking because it is required by the forum TOS that if you have any 'interest' in the product you are 'praising' you must acknowledge your relationship with the company. We frown on 'stealth' advertising here.
L Any tips on setting up a Quality Management System for a Commercial Printer? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Commercial excel templates that calculate overhead, hourly rates, fee proposal Excel .xls Spreadsheet Templates and Tools 0
DMLqms Country of Origin on Commercial Invoices EU Medical Device Regulations 2
P Qualifying commercial off the shelf (COTS) external suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P Medical Device not on commercial distribution but installed in the establishment. 510k? Other US Medical Device Regulations 10
DuncanGibbons To what extent are NASA standards applicable to commercial aviation? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
B IATF 16949 Cl. 4.3.2 - CSR vs Commercial Agreements IATF 16949 - Automotive Quality Systems Standard 8
shimonv Creating a new commercial product based on a modification to an existing product Other US Medical Device Regulations 4
Ajit Basrur How do I label this commercial product ready for clinical study? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
P Design exclusion in AS9100D for commercial products AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
P What is expected in a Medical Device Commercial Release Procedure Design and Development of Products and Processes 3
F Definition Commercial Distribution - Definition - Scope of Commercial Distribution Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
M Commercial tablet as an "accessory" for a medical device IEC 60601 - Medical Electrical Equipment Safety Standards Series 5
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
S COTS (commercial off-the-shelf) Validation FDA Requirements Software Quality Assurance 4
E Commercial Laboratory Audit Tips ISO 13485:2016 - Medical Device Quality Management Systems 2
C Commercial Grade Supplier Surveys - Not qualifed 10CFR50 Appendix B or NQA-1 Other ISO and International Standards and European Regulations 2
S ISO 15189 - When commercial QC Material is not available Hospitals, Clinics & other Health Care Providers 4
B Commercial Calibration Laboratory Software Recommendations Calibration and Metrology Software and Hardware 1
T ISO 17025 - 4.1.5b Internal/External commercial, financial, and other pressures ISO 17025 related Discussions 3
B List of all Auto Parts in a Commercial Vehicle Manufacturing and Related Processes 11
C Apostille of French Commercial Documents for the Republic of Turkey EU Medical Device Regulations 5
H Certification of a large commercial helicopter acc. AC29-2C / CS29 EASA and JAA Aviation Standards and Requirements 1
V Common Root Cause for Failures in Scaleup & Commercial (Validation) Batches 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S Regulatory Value of Commercial Documents (Brochures, Marketing Leaflets, etc.) EU Medical Device Regulations 2
M Everything to AS9100 vs. ISO 9001? Commercial Jobs require AS9100 "Extras"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
S Regulatory requirements for Commercial Medical Devices for sale in Europe ISO 13485:2016 - Medical Device Quality Management Systems 2
B Ideas on how to differentiate jobs (AS9100 jobs vs. "commercial" jobs) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
Jim Wynne "Massive" Epsilon Interactive Commercial Email Breach After Work and Weekend Discussion Topics 7
B Commercial Grade Dedication requirements for a 10CFR50 Appendix B Manufacturer Various Other Specifications, Standards, and related Requirements 8
S Risk Management in terms of Technical and Commercial Failure (Disaster Recovery) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Commercial Measurement of Raw Materials/Production etc. Manufacturing and Related Processes 2
B References for GMP Consultants in Illinois (trade/commercial printer/packaging) Quality Manager and Management Related Issues 3
N COTS (commercial off-the-shelf) Computers - Warranty return rate? Benchmarking 3
Pancho Oquma - a new QMS-on-wiki commercial offering Imported Legacy Blogs 3
D ITAR/EAR and effects on commercial Heat Treating AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Dutch Commercial & Environmental legal requirements for enterprises Miscellaneous Environmental Standards and EMS Related Discussions 14
A Packaging Commercial off-the-shelf (COTS) Products as a Single System Design and Development of Products and Processes 2
D Purchase ? Guidelines - Technical and Commercial Evaluation Guidelines for Products ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Taking Lean beyond 5S - Commercial Printer Lean in Manufacturing and Service Industries 10
R LCD-TFT screen with player for publicity film - Commercial device CE Marking CE Marking (Conformité Européene) / CB Scheme 1
D Commercial and AS9100 operation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
ISOsandy Looking to expand into Commercial Nuclear Various Other Specifications, Standards, and related Requirements 11
I Validation of Commercial off-the-shelf software - Spreadsheets ISO 13485:2016 - Medical Device Quality Management Systems 16
W What Commercial (off the shelf) QMS Software are you using - Any Recommendations? Quality Assurance and Compliance Software Tools and Solutions 14
A Process for receiving functions - COTS (commercial off the shelf) vs Custom parts. Document Control Systems, Procedures, Forms and Templates 6
W ISO 9001 certification (registration) requirements - No commercial product or service ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 42
R Certificate of compliance (C of C) DOD requirements for commercial items in products Various Other Specifications, Standards, and related Requirements 3
Marc No Commercial Advertisements Allowed In This Forum Buy, Sell or Trade - NO Commercial Advertisements 8
