Common Freaking Sense
Do people in your company generally use common sense?
  • Yes
    Votes: 17 23.9%
  • No
    Votes: 54 76.1%
  • Total voters
    71
bmccabe - 2006
#82
According to your, uncorrupted by advertising influences, link. the pen was offered to NASA in 1965. The Russians had men in space in 1961. .Common sense says those guys didn't snow-write. Perhaps if you dig a little deeper, you would find the whole truth. I found an 18aug61 time magazine article without much trouble at all. Then there's film footage which clearly shows the cosmonauts writing with a pencil.. But you've probably already made up your mind. About the money? Alright :eek: I exaggerated. I read once that NASA did prototype the pen, and gave the design to Fisher.... Sounds reasonable to me, but I don't know for certain.
#83
Not sure how I missed this 3 weeks ago when it was posted, but...
And what do you suppose American astronauts were doing between 1961 (Alan Shepard, Freedom 7, Project Mercury, 5-5-61) and 1967 when the Fisher pen was adopted?
I dug as deeply as I needed to. Who said that the Russians weren't using pencils? The NASA article I linked to says that the Russians used grease pencils, but it doesn't say that they used them to the exclusion of every other possibility. And again, what do you suppose the American astronauts were using for six years--nothing? Or do you think that we sent them up there with conventional pens that we knew wouldn't work?:frust:
It's not just an exaggeration; you fell for an obviously fishy urban legend without checking it out first. Your $100m turned out to be $6 a throw. Like you said, "Perhaps if you dig a little deeper..."
E
ezorangee
#84
Wouldn't Have a Job!
The way I look at it, if common sense was a requirement for the company I work for.....I wouldn't have a job! I am not the sharpest knife in the drawer, but I am always amazed at some of the problems that I am asked to assist in the elimination of. Usually, my response to the problem is, "Uhhhhh, how about we just do the job the way the control plan and work instructions describes it to be done?"
acook81
#85
Common Sense
I just completed an Internal Audit of a company that does not feel Control of Documents or Control of Records are processes. I found that very strange. It is the process that holds the system together. They feel that since they look at documents during an audit, that they have audited Document Control and records. It's it me or do they just not understand?:biglaugh:
#86
Doesn't look to make sense - BUT - did you find a problem with any of their documents?
James
acook81
#87
Yes I found several problems with there documents. One being that a corrective action was written against a department for not having controlled records and in investigating found that the records are still not controlled even after the CAR had been closed. Doesn't make sense to me.
#88
YOU WIN GOOD BUDDY - FUR SHUR:truce:
I wonder how many times they will need to be bit in the :ca: before they figure that one out. Sounds a little like my folks here. Recently during a quoting/order entry audit I asked what the expected output of the process was. In several instances I simply noted on my sheet D.I.H. (Deer in headlights) :nope:
It's like come on people you're performing a PROCESS!! you have INPUTS!! you have OUTPUTS!! :frust:
James
D.Scott
#89
Although I know of no requirement that either must be defined as a process in itself, each is required to have a specific documented procedure. Both of these procedures may be part of a larger "process" and IMO could certainly be audited as part of that process. As long as the internal audit determines that the procedures are effectively implemented and maintained, I see no problem in not defining them as a specific process. You must remember that not all records are required to be documented just as all documents need not be controlled. Only those documents required by the QMS are required to be controlled and it is up to the company to define how they are controlled. If they are following their documented procedure and it is effectively implemented and maintained, they are most likely meeting the requirements.
As for the CAR, who wrote the C/A? Is it possible that the company considered the finding yet determined no control was necessary for those identified records? I have seen any number of corrective actions written by internal auditors that quite possibly should never have been written in the first place. Obviously, a judgment can't be made with as little information as we have here but based on the information given, I see nothing wrong with the company's approach. There is certainly a potential for a N/C and it is begging for a closer look but this may be a case of "One size does not fit all". When I audit, I try to determine conformance. The non-conformance will show up by itself.
Dave
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
M MDR "Common Specifications" (CS) - If not standards, then what? EU Medical Device Regulations 5
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
Sidney Vianna What do these things have in common? Surge in new ISO Committees & Standards Other ISO and International Standards and European Regulations 7
A CTD (Common Technical Document) for a Topical Preparation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
M CB and Internal auditors most common nonconformities against AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
W Can 2 different sites under different Quality System have a common management review? ISO 13485:2016 - Medical Device Quality Management Systems 4
G ISO 17025 Calibration Laboratory Assessor's Common Questions and Procedures ISO 17025 related Discussions 11
M IATF:16949 Common Quality Manual - Company is in Country A and Country B Quality Management System (QMS) Manuals 5
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P Converting DMF III into eCTD (Electronic Common Technical Document) Medical Information Technology, Medical Software and Health Informatics 4
R Common Statistical Errors Using Minitab Software 1
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
J What is the most common industry requesting ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
2 Is it common to employ part time dental assistants ? Coffee Break and Water Cooler Discussions 3
P What do you think is the most common root cause of NCRs in a construction project? Quality Manager and Management Related Issues 3
BHobbs_Busche ISO/TS16949:2009 - MSA requirements for common gages IATF 16949 - Automotive Quality Systems Standard 5
S Common Electric Fan Motor Problems Reliability Analysis - Predictions, Testing and Standards 3
AnaMariaVR2 Finding a Common Language for Disaster-resistant Supply Chains Supply Chain Security Management Systems 1
M Common Reasons for Out Of Tolerance condition of DC Calibrator or any reference std General Measurement Device and Calibration Topics 1
V Most Common Internal/External Audit Observations on Risk Management ISO 14971 - Medical Device Risk Management 4
V Common Root Cause for Failures in Scaleup & Commercial (Validation) Batches 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 13485 - Moving towards common (single) certification for multiple locations ISO 13485:2016 - Medical Device Quality Management Systems 13
J Is this practice common? 1 Quality Manager covering QA, QC, QE, SQE IATF 16949 - Automotive Quality Systems Standard 20
S How to do Adjustments & Repairs on Common Inspection Equipment General Measurement Device and Calibration Topics 7
J TL9000 Common Measurements - Design and Development for Telecommunication Products TL 9000 Telecommunications Standard and QuEST 5
M VDA Specifications - Common definitions, acronyms, etc. VDA Standards - Germany's Automotive Standards 1
V Common Failure Modes for a Product/Process Line ISO 14971 - Medical Device Risk Management 1
V Common Errors while Implementing Risk Management Process ISO 14971 - Medical Device Risk Management 9
V Common Coating Problems in Refinery Manufacturing and Related Processes 1
P The most common name for specifications? Design and Development of Products and Processes 3
M Do all common polymers have estrogenic activity? Other Medical Device and Orthopedic Related Topics 5
S What are the common Problems preventing (Gaps) Implementation of ISO 14001? ISO 14001:2015 Specific Discussions 7
B Common Sterilization Methods in Hospital - Prevalence? Hospitals, Clinics & other Health Care Providers 2
B ISO Clause Reference for Developing Common Customer Service Standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
N CMC File Content and what is common to share with the customer ISO 13485:2016 - Medical Device Quality Management Systems 4
somashekar Definition Evaluate and Select ... What are the most common understandings of these words. Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 12
Wes Bucey Privacy of communications - a common myth Career and Occupation Discussions 3
A Common causes of Corrosion on Alm 7075 Material Annodized, Tumbled, and Plated Manufacturing and Related Processes 6
P Are all standards based from common sense? Coffee Break and Water Cooler Discussions 11
B MSA (Measurement Systems Analysis) with One Operator using a CMM or Common Calipers Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M General decline in good manners / common courtesy? Coffee Break and Water Cooler Discussions 26
E Which standard Cpk value intervals are common or frequently used? Statistical Analysis Tools, Techniques and SPC 5
ScottK Retroactive FMEA and Control plan - is this a common thing? FMEA and Control Plans 12
