Common items : which iso 9001 are common to all areas?
Graciel
Hi!
Looking at iso 9001, which items you guys consider is common to every area of the company ( production, purchase, engineering,hr, sales...etc)? I mean, that all areas are questioned by the auditor.
Thanks.
Mikey324
Not sure what you mean. That's a very broad question. Auditors will audit all the requirements. Maybe not product design if you have no design responsibility.
Hi!
Thanks.
Auditors will audit all of the processes you've identified as being within the scope of your QMS.
Tagin
All clauses (4-10) apply to all processes.
Typically though, 4,5,10 are mostly handled by processes that are shared across the organization. But even then, you want to be able to show how, for example, nonconformances in purchasing are escalated to the shared corrective action process.
So, for example, you need to address documented information (7.5) in all the areas you listed (production, purchase, engineering,hr, sales...etc). You could do that with separate QMS documentation for each area, or you could have shared QMS documentation that talks about 'documented information' in all areas. It is up to you, as long as it is covered.
Some clauses may not apply to some areas. E.g., Design (8.3) is probably not going to apply to your shipping department. That's fine. As long as you can justify it.
Graciel
Hi! Thanks for feedback.
I wonder, can a company define item 8.5 as not applicable?
Graciel
I know. What I mean is: item 6 for example (6.1, 6.2 etc) ,can be checked in every area of the company. But 8.3 (if applicable) will be checked in one area only.
Which items would be common to all the areas?
Tagin
It would seem extremely unlikely that 8.5 Production and Service Provision could be not applicable. An organization takes inputs, transforms them, and creates outputs. I can't imagine an organization that doesn't do that.
Graciel
Hi!
Sorry. I forgot to put the sub item,which it'd be 8.5.1 h) . About post delivery activities.
malasuerte
Hi!
Thanks.
Yes...this should be part of what your audit program builds; plus it is what (as far as I know) registrars require for audits.
You would build a matrix like this with clauses on the vertical and areas on the horizontal.
dgrainger Informational Published - Common specifications for the groups of products without an intended medical purpose listed in Annex XVI EU Medical Device Regulations 1
leftoverture REACH Folks - We Need Common Sense! RoHS, REACH, ELV, IMDS and Restricted Substances 23
dgrainger Informational Common Specifications for certain class D IVDs EU Medical Device Regulations 0
J Common Specifications per MDR EU Medical Device Regulations 2
A Common Specifications versus Harmonized Standards EU Medical Device Regulations 3
G Similarities between format of technical file for CE and ASEAN common submission dossier template (CSDT) CE Marking (Conformité Européene) / CB Scheme 2
J 'Failure rate leading to false-negatives and repeat testing' - MDCG and Common Tech Specs Other Medical Device Regulations World-Wide 0
K Common "modern" network switches suitable for use as a separation device? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
dgrainger Informational DRAFT - Common specifications for the groups of products without an intended medical purpose listed in Annex XVI. EU Medical Device Regulations 0
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R EU-MDR Article 9-common specifications Other ISO and International Standards and European Regulations 2
Z Is Op Amp Common-Mode Rejection Ratio (CMRR) test applicable to battery operated devices? Other Medical Device Related Standards 0
Sidney Vianna IATF 16949 News Update on the IATF CARA Project (“Common Audit Report Application”) - 12/2020 IATF 16949 - Automotive Quality Systems Standard 1
M MDR "Common Specifications" (CS) - If not standards, then what? EU Medical Device Regulations 7
G Is it common to do a repeatability check during calibration of an instrument? General Measurement Device and Calibration Topics 5
M Medical Device Directive - Seeking common nonconformance write up scenarios CE Marking (Conformité Européene) / CB Scheme 2
Sidney Vianna What do these things have in common? Surge in new ISO Committees & Standards Other ISO and International Standards and European Regulations 7
A CTD (Common Technical Document) for a Topical Preparation Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
W IMDS - Help (Common Warning and Error Fixes) RoHS, REACH, ELV, IMDS and Restricted Substances 9
M CB and Internal auditors most common nonconformities against AS9100D AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
W Can 2 different sites under different Quality System have a common management review? ISO 13485:2016 - Medical Device Quality Management Systems 4
G ISO 17025 Calibration Laboratory Assessor's Common Questions and Procedures ISO 17025 related Discussions 11
M IATF:16949 Common Quality Manual - Company is in Country A and Country B Quality Management System (QMS) Manuals 5
I Is it common practice for a bake oven to require a CQI-9? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
P Converting DMF III into eCTD (Electronic Common Technical Document) Medical Information Technology, Medical Software and Health Informatics 4
R Common Statistical Errors Using Minitab Software 1
cscalise Separate Forms or Procedure Attachments - What's more common? Document Control Systems, Procedures, Forms and Templates 2
J What is the most common industry requesting ISO 9001 Certification ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
2 Is it common to employ part time dental assistants ? Coffee Break and Water Cooler Discussions 3
P What do you think is the most common root cause of NCRs in a construction project? Quality Manager and Management Related Issues 3
BHobbs_Busche ISO/TS16949:2009 - MSA requirements for common gages IATF 16949 - Automotive Quality Systems Standard 5
S Common Electric Fan Motor Problems Reliability Analysis - Predictions, Testing and Standards 3
AnaMariaVR2 Finding a Common Language for Disaster-resistant Supply Chains Supply Chain Security Management Systems 1
M Common Reasons for Out Of Tolerance condition of DC Calibrator or any reference std General Measurement Device and Calibration Topics 1
V Most Common Internal/External Audit Observations on Risk Management ISO 14971 - Medical Device Risk Management 4
V Common Root Cause for Failures in Scaleup & Commercial (Validation) Batches 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 13485 - Moving towards common (single) certification for multiple locations ISO 13485:2016 - Medical Device Quality Management Systems 13
J Is this practice common? 1 Quality Manager covering QA, QC, QE, SQE IATF 16949 - Automotive Quality Systems Standard 20
S How to do Adjustments & Repairs on Common Inspection Equipment General Measurement Device and Calibration Topics 7
J TL9000 Common Measurements - Design and Development for Telecommunication Products TL 9000 Telecommunications Standard and QuEST 5
M VDA Specifications - Common definitions, acronyms, etc. VDA Standards - Germany's Automotive Standards 1
V Common Failure Modes for a Product/Process Line ISO 14971 - Medical Device Risk Management 1
V Common Errors while Implementing Risk Management Process ISO 14971 - Medical Device Risk Management 9
V Common Coating Problems in Refinery Manufacturing and Related Processes 1
P The most common name for specifications? Design and Development of Products and Processes 3
M Do all common polymers have estrogenic activity? Other Medical Device and Orthopedic Related Topics 5
S What are the common Problems preventing (Gaps) Implementation of ISO 14001? ISO 14001:2015 Specific Discussions 7
B Common Sterilization Methods in Hospital - Prevalence? Hospitals, Clinics & other Health Care Providers 2
B ISO Clause Reference for Developing Common Customer Service Standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
