Comparing PPM Year over Year - Determining the PPM decrease from 2009 to 2010
CMfgT
Can some one check my logic?
I am trying to determine the PPM decrease from 2009 to 2010.
The department PPM in 2009 was 11,754
The department PPM in 2010 was 8,638
So wouldn't this be a 27% decrease in PPM
((2010PPM-2009PPM) / 2009PPM)*100
I asummed this was like sale increases and decreases?
thanks,
Bill Pflanz
Re: Comparing PPM year over year
Or it could just be normally variation. If you have the monthly data, control chart that data and it will be more meaningful.
Bill Pflanz
thanks,
What's wrong with just comparing the number of defectives for each year?
CMfgT
Can't compare defectives because they made a larger amount of product, then I wouldn't be comparing apples to apples.
As far as control charting. I am not trying to make this a hard to understand, I just want to show the operators the PPM dropped by X percentage and tell them thank you for all of the hard work. We have been decreasing our PPM and we continue to grow.
Thanks,
Bill Pflanz
Based on your comments the ppm decrease calculation is fine to use. Just be careful not to oversell it if it is just normal variation.
Bill Pflanz
tomvehoski
I've never like PPM measures, as all of the following could be true.
2009 PPM resulted in a paper cut to the user in every instance.
2010 PPM resulted in death to the user in every instance.
We reduced PPM by 27% from 2009 to 2010.
I don't think you can claim improvement in the above (hopefully exaggerated) example. Of course, you can do the same with any statistics.
I should have asked the question more clearly. Why can't you just use simple ratios (x% in 2009, y% in 2010) and leave the problematic PPM thing out of it?
Jim - I'm not sure what is problematic about this particular situation. The percent change doesn't change if you use ppm or %.
(assuming that the ppm is not some theoretical statistical estimate)
after all % is the proportion multiplied by 100 and ppm is the same proportion X10^6...both measures make the printed number look bigger than the proportion.
(I have the same caveats concerning random noise and more importantly the issue of whether or not the 'operators' had any influence on the results. But those aren't effected by the concern you raise)
I understand. A ratio is a ratio. My misgivings are with the idea of PPM, which makes no sense if you're not actually making millions of things. Why not PPT--parts per trillion?
Well, if he is making millions of parts then there isn't an issue?
one of my product lines measures things in ppb. because we really are looking at billions. so I guess if I were measureing or making trillions I'd use ppt
O Software for comparing text of PDF files Contract Review Process 2
M Comparing data from destructive testing Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
A Demonstration of Equivalence - Need for comparing biological characteristics for an SamD EU Medical Device Regulations 1
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
V Statistical basis and justification while comparing / changing sampling plans Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
N Does FDA allow comparing with the competitors Medical Device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
L Procedure for Comparing the Monitor Reading with Laboratory Result Statistical Analysis Tools, Techniques and SPC 4
S Looking for a checklist comparing ISO 13485:2016 and 21 CFR Part 820 ISO 13485:2016 - Medical Device Quality Management Systems 14
M Comparing the MMOG (v3 or v4) with ISO / TS16949 Customer and Company Specific Requirements 3
A Comparing US/FDA Drug Regulations against US/FDA Device Regulations US Food and Drug Administration (FDA) 3
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
R Comparing Laboratory Scope of Accreditation against internal equipment General Measurement Device and Calibration Topics 3
C Comparing Two Independent Group Observations - 95% Confidence Intervals Overlap Statistical Analysis Tools, Techniques and SPC 3
D Comparing the ISO 9001:2008 standard to ISO 17025 ISO 17025 related Discussions 2
S Comparing Quality System Software Features Quality Assurance and Compliance Software Tools and Solutions 18
C Comparing Two Test Methods - Acceptable Difference(s)? Statistical Analysis Tools, Techniques and SPC 3
M pH Calibration - Comparing Electrical and CRM Methods General Measurement Device and Calibration Topics 1
I Six Sigma comparing to other National and International Models Six Sigma 6
A Comparing Effect of Process Parameters on Equipment Performance during Start Ups Statistical Analysis Tools, Techniques and SPC 3
P Acceptable Adjusted R Squared Value Comparing 2 Measurement Devices in Minitab Using Minitab Software 3
M z Test vs. F Test - The most appropriate for comparing the Variances Statistical Analysis Tools, Techniques and SPC 3
T Comparing Two Measurement Systems in terms of Accuracy and Capability Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
R Comparing the Accuracy of Analog vs. Digital Multimeter General Measurement Device and Calibration Topics 6
T Comparing two different Ultrasonic Tester Calibration Techniques General Measurement Device and Calibration Topics 2
Q Internal Audit:Comparing Efficiency of Similar Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Comparing Variation - A CMM and an On-Line Inspection Station Statistical Analysis Tools, Techniques and SPC 6
N Statistically Comparing Technician Techniques Reliability Analysis - Predictions, Testing and Standards 16
C Comparing Histograms - Bimodal Distribution? Statistical Analysis Tools, Techniques and SPC 4
K Comparing CQE vs. MSc. Professional Certifications and Degrees 1
J To PPAP or Not? Comparing two machines (one old and one new) APQP and PPAP 6
C Comparing OHSAS 18001 to the new ANSI Z10 - Where I can get information? Occupational Health & Safety Management Standards 1
J Has anyone created a matrix comparing ISO 9001 VS BS 7799 and or ISO 27001? Document Control Systems, Procedures, Forms and Templates 1
A Comparing six sigma & EFQM (European Foundation for Quality Management) Six Sigma 2
C Comparing what I do against Canada request - Immigration Immigration and Expatriate Topics 4
J KAPPA Statistic - Comparing appraisers ratings to a known standard IATF 16949 - Automotive Quality Systems Standard 8
R Comparing MicroVu?s Vertex machine to OPG?s Smart Scope Flash General Measurement Device and Calibration Topics 2
D Comparing ISO 10012 and 17025 ISO 17025 related Discussions 2
S Comparing ISO with PMBOK (Project Management Body of Knowledge) Misc. Quality Assurance and Business Systems Related Topics 2
D Comparing Apples and Apples vs. Apples and Oranges QS-9000 - American Automotive Manufacturers Standard 8
C Gap Analysis comparing QS-9000 and TS 16949 IATF 16949 - Automotive Quality Systems Standard 33
M Targets / limits for PPM/ Scrap Manufacturing and Related Processes 2
M Help me improve the definition for internal PPM Manufacturing and Related Processes 3
A ISO 2859-1 - 9.3.3.2 Switching score - Sampling Plans and PPM AQL - Acceptable Quality Level 0
S Software for Supplier Charge back and internal PPM General Information Resources 2
L PPM - wrong parts or defective parts? IATF 16949 - Automotive Quality Systems Standard 18
0 PPM calculation of customer complaints for PMS Customer Complaints 10
F Determining what type of scrap to include in my internal PPM calculation Quality Manager and Management Related Issues 5
R PPM, Pictorial Process Mapping, Templates Manufacturing and Related Processes 5
V PPM - Internal PPM / External PPM Quality Manager and Management Related Issues 4
L PPM Defect Rate as a Performance Metric - Are there Flaws? Quality Manager and Management Related Issues 9
