tahirawan11
Hi all,
I am interested in compairing two measurement systems and decide which is better in terms of accuracy and capability. The characteristics in question is the 'Mix ratio' of a compound. The mix ratio is expressed in terms of 'percentage value'. The compound is made up of two 'Ingredients'. The first 'measurement system A' cannot measure the mix ratio directly; instead four different 'mechanical properties' are calculated which are then compared with a standard table which is used to predict the 'mix ratio'.
The second 'measurement system B' is capable of making direct measurement and gives direct 'mix ratio' figures. In order to evaluate which measurement system is better, i have performed a Gauge R&R study. And on the basis of the results; 'measurement system B' has less Gague R&R value (0.9 %) compare to 'measurement system A' (10%).
My question is that' is it enough to prove that 'measurement system B' is better than 'measurement system A'. Do i need to perform a 'Producer risk' and 'Consumer risks' analysis as well and if so how can i do that. Are there any other methods / techniques beside Gauge R&R which can be used to compare two different measurement systems.
thanks
thanks
