Comparison table between ISO 20000 and ISO 9001
JJ777
Does anybody have a comparison table between ISO20 000 and ISO9001.
We are ISO9001 certified and we are also looking at ISO20 000 because we deliver IT services.
I just want to adopt the ISO20000 requirements into our ISO9001 procedures, because I do want separate procedures for ISO9001 and ISO20000.
harry
Re: Comparison table between ISO20000 and ISO9001
I just want to adopt the ISO20000 requirements into our ISO9001 procedures, because I do want separate procedures for ISO9001 and ISO20 000.
Howste provided you with an answer almost two years back.
I just want to adopt the ISO20 000 requirements into our ISO9001 procedures, because I do want separate procedures for ISO9001 and ISO20 000.
Have you purchased a copy of various ISO 20000 related standards? The are some similarities. I'd anticipate that one has a comparison table.
john.b
You can find such things, although I don't remember where I've seen such a table. It is of limited usefulness, though.
There are only a few standard things all management systems require that would be common: document control, internal auditing, and corrective and preventative actions come to mind.
The additional requirements for 20000 (many) are not likely to already be a part of your 9001 system. You will probably need new procedures for all processes (incident, change, problem, release, etc.), and policies are defined as required for some as well. "Required" is obvious in the standard because of the word "shall." As of the last revision you'll need a service catalogue (although you kind of did before anyway), and tons of other records, roles, practices, and other functional elements.
This does all sound really familiar. The starting point is figuring out why you want to certify to ISO 20000 and if that reason is even valid. If you don't have a lot of formally implemented IT service management processes in place it's almost certainly a bad idea, but you might learn a lot in failing to succeed.
john.b
I uploaded a reference table of 20000 requirements that covers part of this same question in a different thread here. Really most of the commonality isn't referenced because it covers main ITSM process requirements (about incident managment, change, etc.), not as much on standard common requirements like internal auditing, training, management review, and so on.
PAS 99 is a BSI standard that deals with this sort of thing, integrating management systems and common elements. It isn't an auditable standard (it's a reference document) and doesn't give that much guidance on practical issues like conducting combined auditing, but it does review some of those standard elements.
It seems like these discussions aren't really reaching out to the related audience beyond IT scope. ISO 20000 and service management aren't just about IT, although they started there and apply best there. Processes like incident management, change management, and configuration management really can apply broadly beyond IT to different types of services provisioning. Reference sources like ITIL and Cobit will keep evolving in that direction.
Management system certification to general "service management" outside of IT is a different thing, related but perhaps far off. As the 20000 standard is written now in theory it could happen now but in practice it probably wouldn't.
darbym
I also wanted to mention that for many IT companies in addition to the management system elements such as document and record control there is typically some areas already completed in the following areas:
ISO 9001 - 7.3 Design and Development/ ISO 20000 5.1-5.4 Design and Transition of New or Changed Services
ISO 9001 - 7.4 Purchasing / ISO 20000 7.2 Supplier Relationship Management
ISO 9001 - 7.2 Customer-Related Processes / ISO 20000 7.1 Business Relationship Management
While they are not likely to be covered in their entirety there is certainly some information that can be reused based on the scope.
P IEC 60601-2-25:2011 Comparison Table (ECG, Diagnostic) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
K Multiple Comparison in Chi Square - More than 2 Rows/Columns in Contingency Table Using Minitab Software 9
A Comparison Table for ISO 9001 & ISO/IEC 17020 Clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
K Comparison: AS9110C vs. C.A.S.E. 1-A AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
K Comparison wanted: ISO 15378:2018 vs. PS9000:2016 Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
Q Capability - CPk comparison values Capability, Accuracy and Stability - Processes, Machines, etc. 12
O ISO 13485 vs. GMP - Comparison matrix wanted EU Medical Device Regulations 4
T Interlaboratory comparison or proficiency testing in destructive testing of welded joints ISO 17025 related Discussions 3
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
K Comparison essential requirements EU compared to those of MDSAP countries Other Medical Device Regulations World-Wide 3
L Comparison matrix between IATF 16949:2016 to ISO 12207, ISO 9001 and Automotive SPICE IATF 16949 - Automotive Quality Systems Standard 3
P ISO 15378 2015 to 2017 Comparison wanted General Auditing Discussions 4
E 2 participants in inter-laboratory comparison tests ISO 17025 related Discussions 3
T MDD and IVD comparison Other Medical Device Regulations World-Wide 2
Q JIS T 1115 Comparison (Japan Medical Device Standard) Japan Medical Device Regulations 0
A Does anyone have a comparison between ISO 9001:2015 and ISO 13485:2016? ISO 13485:2016 - Medical Device Quality Management Systems 2
J Machinery Directive vs. MDD Comparison Matrix wanted EU Medical Device Regulations 6
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
A ISO 13485:2003 vs. ISO 13485:2016 Differences Comparison ISO 13485:2016 - Medical Device Quality Management Systems 4
A ISO9001:2015 comparison with AS9100:2016 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
D Comparison of ISO 9001:2008 and CAN3-Z299.3 Other ISO and International Standards and European Regulations 1
C Checklist comparison between ISO9001:2008 and ISO 3834 Quality Management System (QMS) Manuals 1
N Digital vs Dial Caliper Comparison Measurement Uncertainty (MU) 17
P Comparison of OEDC and US FDA GLP (Good Laboratory Practices) Other Medical Device and Orthopedic Related Topics 4
P Alternative To PT/ILC (Inter-Laboratory Comparison) Requirement General Measurement Device and Calibration Topics 3
N Ranking Criteria Systematically - Pairwise Comparison.xlsm Lean in Manufacturing and Service Industries 8
C What is "Participation in interlaboratory comparison or proficiency-testing programs" General Measurement Device and Calibration Topics 8
G Comparison Study of CMMs and software along with Probe Types Inspection, Prints (Drawings), Testing, Sampling and Related Topics 12
F Comparison of 2 CMM machines using Gage R&R Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
M SAE AS 9101 Rev D and E Comparison wanted - March 2014 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
S ISO 9001:2008 / ISO TS16949:2009 Comparison ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q ISO 9001:2008 & 2015 comparison ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C How to determine a sample size for comparison purposes ? Quality Tools, Improvement and Analysis 2
S Comparison between Rapapport Vassilliadis Broth and Selenite Broth for Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 1
M CMDR vs. MDD Comparison Canada Medical Device Regulations 3
L Australia/Canada and USA v's EU Medical Devices Regulations Comparison Other Medical Device Regulations World-Wide 4
S Method Comparison Design Onput Sample Range Requirement Design and Development of Products and Processes 3
S Comparison between Microgen A+B,API 24e and microbact 24e US Food and Drug Administration (FDA) 1
F Statistical Comparison of Product: High Average vs. Low Range Capability, Accuracy and Stability - Processes, Machines, etc. 13
M Comparison between TS 16949 clauses 8.5.2 and 8.5.2.1 IATF 16949 - Automotive Quality Systems Standard 6
P GMP or quality system "requirement" comparison for different sector Various Other Specifications, Standards, and related Requirements 1
P The Name for a Calibration - Bootstrapping or Comparison General Measurement Device and Calibration Topics 12
H Quick Comparison Check of Multiple Thermocouples on one Datalogger General Measurement Device and Calibration Topics 6
M Adding Bizminer's Industry Financial data to my Peer Company Comparison Manufacturing and Related Processes 0
AnaMariaVR2 Regulatory Review of Novel Therapeutics ? Comparison of 3 Regulatory Agencies US Food and Drug Administration (FDA) 0
T IEC 60601-2-27 - Comparison of 2nd to 3rd edition IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
optomist1 ISO 9001 vs TL 9000 - Looking for a comparison matrix Other ISO and International Standards and European Regulations 3
R 21 CFR 820 comparison to RDC No.59 Other Medical Device Regulations World-Wide 2
Z Comparison between AS9100 and FAA 145 Repair-Station (CFR's, FAR's) Federal Aviation Administration (FAA) Standards and Requirements 3
M ISO 13485 x ICH Q10 Pharmaceutical Quality System - Comparison Evaluation ISO 13485:2016 - Medical Device Quality Management Systems 2
