db said:
Indeed, that is the purpose of the off-topic. But little_cee also makes a valid point with:
This is in part why I maintain the only way to "prove" competence is to look at the output of the task. Job descriptions are great, and so are performance apprasials, provided they truly are focused on the task and the demonstrated competency.
Determining what kind of competency evidence to use could be done on the same premise as deciding how often to calibrate equipment: frequency of use, critical contribution to the process and a failure rate (which escalates at a certain time span) for when the thing isn't maintained. LIkewise, if a production worker's performance has been consistently acceptable, he or she may not need any more reinforcing training as long as no other factor determines that.
If a production worker has been performing at acceptable levels and never misses a trick, does that "grandfather" into historical evidence of competency? Maybe, but then we must ask:
1. Will other performers be compared to that level, or will performance be more subjective?
2. Do we expect that time away from the task will dull the skill level? And if so, what is the curve if diminished skill we expect, at what point? This is for the sake of recerts, you see.
I truly don't want to "nuke the thing", as we said on my ship. However, we must show evidence of competency: a relative matter, IMHO.
