Competency of Trainer for Internal Auditor Training (IATF 16949)
buffalo
Dear All,
IATF 16949 (7.2.3 Internal auditor competency):
QMS auditors shall be able to demonstrate the following minimum requirements:
a, understanding of the automotive process approach for auditing
b, understanding of applicable CSR
c, understanding of applicable ISO 9001 & IATF 16949 requirements
d, understanding of applicable core tools
e, understanding how to plan, conduct, report and close out audit findings
Where training is provided to achieve competency (of internal auditor), documented information shall be retained to demonstrate the trainer's competency with the above requirements.
We are looking for an external trainer for internal auditors training, and don't know what kinds of certificate (documented information) are needed from the trainer to satisfy this requirement.
Do any of you have any ideas?
Thanks a lot.
jelly1921
Re: Competency of trainer for internal auditor training
The requriements of a), c) d) and/or e) could be demonstrated by external trainer with a certificate that shows the trainee have been trained with these subjects.
For e), usually, the organization could define the times of internal audit that the new auditor has to conduct as trainee, and as lead auditor supervised by qualified auditor. That kind of records could demonstrate to meet the requirement of e).
For b), OEMs usually provide CSR training, so the certificate from OEM could provide demontration. Or, the organization could provide such training if OEM have not such course. In that case, the training record could demonstrate it.
Jelly
QualitySpirit
Hi I would prepare my QMS auditors to be able to answer CB auditors questions that demonstrate their understanding clearly.
Mostly CB auditors would care more to verify understanding by interview than to look at paper records. If it is found some QMS auditors totally have no ideas about those competency, they would look in the paper records of those questionable internal auditors.
For documented information to demonstrate trainer's competency, I think simple resume or work history and related training should be acceptable to CB auditors.
What is your opinion?
buffalo
Thank you QualitySpirit,
I still wonder if the external trainer must be trained by OEM (for SCR) & IATF authorized organization such as SMMT for IATF & core tools? Or training certificates from any orgnization are accepted.
QualitySpirit
I don't think that "the external trainer must be trained by OEM (for SCR) & IATF authorized organization such as SMMT for IATF & core tools" is required in this requirement.
If customer CSR does not specify so clearly that they want it that way, I don't think CB auditors have enough basis to raise a nonconformity for external trainers not being trained by OEM or authorized organization.
Subjects a, c, d, are quite general. An external trainer could provide a proof of his competency by work records, or certificates of training e.g. ISO9001:2015, IATF16949 etc.
Subject b, customer CSR should be trained by your customers not by an external trainer.
Otherwise you will need to provide the trainer all CSRs for his study before he can achieve competency himself to train your internal auditors.
Peters
It could be more complicated.
Trainer for internal auditors in the scope of "core tools" is John Smith.
Does John Smith may be a trainer? He has a certificate in "core tools" released by James Jones.
Is that enough? Not so fast…, Is James Jones enaugh qualified to train the John Smith? James Jones has a certificate in "core tools" released by Mark Brown.
Is that enough? Etc etc ...
Golfman25
Yep at the end of the day, you'll need to pull out your wallet and attend the IATF/AIAG auditor training. Anything less will just cause you nightmares come audit time.
Peters
It's not my problem.
It will be the problem for companies during the certification audit performed by "creative" auditors.
drlukas
I would have to agree. Our CB auditor came right out and said that this is the easiest way to satisfy the requirement of internal auditor competency.
M IATF 16949 7.2.3 Internal Auditor Competency - Trainer's competency Internal Auditing 7
Q How can an Internal Auditor Trainer's Competency be Evaluated - IATF 16949 Cl. 7.2.3 IATF 16949 - Automotive Quality Systems Standard 10
D Competency requirements of an SOP Writer/Trainer ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Determining Competency of a Trainer Training - Internal, External, Online and Distance Learning 8
V Internal Auditor Competency KPI IATF 16949 - Automotive Quality Systems Standard 14
B Internal Auditor Competency - Product Auditors Internal Auditing 9
I IATF Lab Scope Testing Qualification and Competency Documentation IATF 16949 - Automotive Quality Systems Standard 3
B Internal and external auditor competency to CSR's IATF 16949 - Automotive Quality Systems Standard 20
D QA Inspector testing - Test for competency Quality Manager and Management Related Issues 1
S API Spec Q1 - How to define Management Representative competency for QMS Oil and Gas Industry Standards and Regulations 12
K Changing from Procedure based to Process based Competency Evaluations General Auditing Discussions 5
J ISO 9001 2015 - 7.2 Competency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
A Documentation of Competency, Awareness IATF 16949 - Automotive Quality Systems Standard 11
J ISO 9001 Competency - Forklift License and Internal Auditors ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
C AS9100 Cl. 7.2 Competency for contract workers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
K IATF 16949 Line and Dock Auditor Competency Requirements Internal Auditing 4
C IATF 16949 Cl. - 7.2.3 Internal Auditor Competency IATF 16949 - Automotive Quality Systems Standard 1
C IATF 16949:2016 Cl. 7.2.3 Internal Auditor Competency Requirements IATF 16949 - Automotive Quality Systems Standard 39
Q IATF 16949 Cl. 7.2.3 - Internal Auditor Competency and Records IATF 16949 - Automotive Quality Systems Standard 5
P Problem with IATF 16949 Clause 7.2.3 Requirements (Internal Auditor Competency) IATF 16949 - Automotive Quality Systems Standard 3
L Auditing Top Management - Meeting Competency Requirements and Questions to Ask General Auditing Discussions 11
S How to evaluate "competency" of consultants ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
T MSA (Measurement System Analysis) Competency Test Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
A Assessing/Mapping Employee Attitude during Competency Mapping (Assessment) IATF 16949 - Automotive Quality Systems Standard 15
C Appropriate ways to address Competency? Generic vs Specific ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Auditing TS16949 Competency Requirment (No Written Procedure IATF 16949 - Automotive Quality Systems Standard 3
G What is needed to show competency Clause 6.2.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
Crusader Training / Competency Assessment Record for review and feedback Training - Internal, External, Online and Distance Learning 12
E Procedure Templates for Training, Awareness and Competency Assessment Process Document Control Systems, Procedures, Forms and Templates 7
K Internal Audit Competency Application Form example wanted Internal Auditing 3
P Supplier's Quality Competency - Testing the knowledge/competency of their personnel Supplier Quality Assurance and other Supplier Issues 8
V Should QA have Technical Competency US Food and Drug Administration (FDA) 13
J 'Competency of Staff' Evaluation Method Training - Internal, External, Online and Distance Learning 8
E Push or Pull Induction and Competency Training Method for New Employees Training - Internal, External, Online and Distance Learning 3
M Internal Auditor Competency based upon Skill Sets based on ISO 19011 Internal Auditing 20
S Competency Requirements? Training - Internal, External, Online and Distance Learning 1
S Incidence of Loss of Competency - Departure of a Knowledgable Employee Misc. Quality Assurance and Business Systems Related Topics 10
S Proof of Competency Outside of the Organization - Sending an Employee Abroad Training - Internal, External, Online and Distance Learning 4
A Competency Records Management - How do you manage your training/competency records? Training - Internal, External, Online and Distance Learning 1
Z Top Management (Exempt Staff) vs. Training and Competency ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
V Competency - How I can show experienced operators are competent? Document Control Systems, Procedures, Forms and Templates 3
R Company Director - Competency and Documented Job Description Requirements Document Control Systems, Procedures, Forms and Templates 2
Q Competency and Training Verification - Review of employee resume/application ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
B Training and Competency Records Retention - UK Health Service Records and Data - Quality, Legal and Other Evidence 5
S Advice on how to assess competency in the absence of academic qualifications? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J Training & Competency - ISO 13485 - Question ISO 13485:2016 - Medical Device Quality Management Systems 2
S Authorization Individual Form - Competency to use certain equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
D Testing an Inspector to Prove Competency in Visual Inspection Records and Data - Quality, Legal and Other Evidence 2
N Raising a Nonconformance for Lack of Competency of Contractor ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
