Complaint System Internal Audit - Topics to Emphasize
RoxaneB
#11
Sidney, good point but company has to be careful to not allow the tail to wag the dog, so to speak. Ideally, the process is defined and the tool implements the process. Having a tool define the process is, from my experience, a risk that can lead to all sorts of process deviations ("well if the tool supports it, it must be ok"). This is especially true in a large, "do all" application like Trackwise (from what I understand of it).
A software application should be used to meet its intended purpose. You don't want to end up using your hammer to drive a screw.
I don't believe including the software in this case warrants a "process defines the tool" versus "tools defines the process" debate. An audit that incorporates how the tool is used to support the process can also help gauge the effectiveness and efficiency of a process.
What if one site uses the software and one site does not? The process concepts may be identical, but the identifying best practices from one location or another could be benefit the organization (and process) as a whole.
The audit may also uncover that the tool DOES NOT support the process. What if data is not able to be viewed in such a way for trend analysis and the site is unable to speak to recurring issues other than 'I remember this one time...' examples (i.e., impact on failure analysis)? What if the documented procedure is not aligned with the steps the software takes (i.e., impact on training)?
Standardizing a process should include more than just a documented procedure. It is also helpful to standardize the tools used, be it a software or a manual log. When assessing a process, my own experience has been that it is valuable...and value-added...to include how the tools support the process on a day-to-day basis, as well as from an improvement perspective.
Sidney Vianna
Post Responsibly
#12
I agree with the premise and distinction between the tool and the process; actually I made a similar point in this post in the What is the best Complaint Handling system? thread.
But, since the issue at hand was tips for an effective (internal) audit of the complaint handling process, I don't think we should be telling the OP that the tool to be used for the process could be disregarded or that the tool is irrelevant. In my opinion, the opposite is true: proper deployment and use of the tool is paramount for the complaint handling process to be effective. We all know that one of the typical problems with complaint handling is situations where the dissatisfaction does not get captured because the source of the feedback is atypical and not always comes via a call center. If the tool is not used and we lose instances of customer complaint, that might drive ineffective analysis by the organization.
So, to summarize, in my opinion, the OP needs to familiarize himself with the use of the tool to be able to assess if the tool is being properly used, as a critical resource of the process.
Q Internal Audit of Product Quality Complaint System (21 CFR Part 820) Customer Complaints 9
C Web based Complaint Software which interfaces with our Enovia system Document Control Systems, Procedures, Forms and Templates 0
Q Customer Complaint Vs. Nonconformance - CAPA SYSTEM Customer Complaints 2
A Risk Management, complaint handling and CAPA system ISO 14971 - Medical Device Risk Management 5
R Everest Customer Complaint System by Lynk Software US Food and Drug Administration (FDA) 1
Michael Malis What is the best Complaint Handling system? Customer Complaints 16
S Data Flow diagram for a Customer Complaint System - Help wanted Customer Complaints 6
B Small Company Customer Complaint System ISO 13485:2016 - Medical Device Quality Management Systems 2
R FDA Part 820 Quality System Regulation - 820.198 Complaint files ISO 13485:2016 - Medical Device Quality Management Systems 20
M Reduce occurrence rating based on the PMS data and customer complaint data ISO 14971 - Medical Device Risk Management 2
B Complaint Records - Accessing records on Easy Track Software Records and Data - Quality, Legal and Other Evidence 3
J Customer Complaint & SCAR, false data Nonconformance and Corrective Action 14
M ISO 13485:2016 Complaint Definition Clarity Customer Complaints 2
J Customer Complaint Response 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
S How to treat a customer complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
A Requirements for Complaint Files - Distributed Goods Customer Complaints 3
S Is any dissatisfaction over a Medical Device considered as a complaint? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
A Complaint alert levels - Industry standards pertaining to alert levels for complaints Customer Complaints 5
B Procedures for Complaint Handling and Post Market Surveillance EU Medical Device Regulations 7
J KPIs or Metrics to Measure a New Complaint Handling Process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 9
D Class II medical device - When should a complaint be closed? Customer Complaints 6
PhilM Nonconformance report, Customer complaint investigations and RMAs ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Problem Resolution Report Monitoring - Customer complaint or PRR as general motors use Customer Complaints 12
R Does an RMA = a Customer Complaint Customer Complaints 4
G Customer complaint over a Reference Dimension Manufacturing and Related Processes 9
Z Security for Approvals - Cloud based Complaint, NC, and CAPA systems Qualification and Validation (including 21 CFR Part 11) 8
S How to collect complaint data from customers Customer Complaints 24
E Is there an Automotive Customer Complaint Index? IATF 16949 - Automotive Quality Systems Standard 3
R In a software development company: Is every bug reported by the customer a complaint? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Decontamination responsibility on customer complaint investigation Customer Complaints 4
N Possibly worlds first customer service complaint Supply Chain Security Management Systems 0
A What is a Customer Complaint? (ISO 9001:2015) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S What is the difference between a service request and a complaint? ISO 13485:2016 - Medical Device Quality Management Systems 2
M Should Potential Customer Complaint Outcome Define Registrar NC Rating? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
J FDA definition of a complaint - Customer orders spare parts 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
R 510(k) - Finished Test Reports - RTA - Bit of a Complaint 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
P Customer Complaint Definition - Food Distributor Customer Complaints 5
J Using Complaint Rate to Update FMEA P.O.C ISO 14971 - Medical Device Risk Management 4
C Complaint Training - FDA - How to recognize complaints and what actions to take 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
M Complaint Handling Responsibilities for a Design Partner - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 9
S Merging Post Market Surveillance and Complaint Handling ISO 13485:2016 - Medical Device Quality Management Systems 3
R Customer Complaint - Samples vs. Removal - FDA Requirements 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Retention Requirements of Complaint Medical Devices Customer Complaints 2
Moncia Complaint / Non-Conforming Product / CAPA Procedures - Please share your experience ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Moncia Customer Complaint Procedure example needed Document Control Systems, Procedures, Forms and Templates 1
C Medical Device Malfunction - Customer Complaint - Response vs. Correction Other US Medical Device Regulations 3
J ISO 13485 Complaints (what is a complaint) Customer Complaints 5
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
M Using a Complaint Management Software (Medical Device companies) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
