Complex Surface Profile as a datum
Coleman Donnelly
I have a part that has a complex surface (free form surface/sculpted surface) which produces vectors in all 3 axis.
This surface acts as the primary datum in terms of how the part will seat/mate functionally in the assembly.
My intent is to identify this surface as Datum A with a profile tolerance which is essentially creating a virtual condition boundary for the form of the feature.
My question is - this is rather unorthodox and I am not sure how to identify the basic dimensions as they relate to datum A. I have not been able to find an example of this having been done before either.
Typically a datum control frame establishes a coordinate reference frame. If you consider the concept of a classical 3-2-1 control frame you have a plane, a line and a point constraining all 6 degrees of freedom. The plane and the line create the orientation of your coordinate frame and the convergence of the 3 features represents your origin point.
In my example all 6 degrees of freedom are constrained by Datum A. However, there is no flat plane that defines the orientation of my coordinate frame or location that represents my origin that is specific to the feature.
Any help?
Paul F. Jackson
The basic profile must be defined 3D from a coordinate system reference so that reference location will be your X0,Y0,Z0 for translation and the fit of the "imperfect form" relative to the "perfectly defined form" will establish the 3 rotations.
It doesn't matter where the coordinate translation reference X0,Y0,Z0 is relative to the form as long as the definition remains basic.
Paul
Coleman Donnelly
Exactly what I expected.
Is it fair to utilize the model to identify the correct relationship to 0,0,0?
Also - Can you provide me with an example of this for reference?
Paul F. Jackson
Yes it is good to share the parametric model as it can often be utilized to tool, manufacture, as well as inspect the resultant part.
No I have no examples to share. Post your form up that we can mark-up and discuss.
Michael_M
I don't know if this will help:
Can you set "tooling" points that give the "measure from" points. I did a quick mark up of your drawing (very quick). You define the 6 points (I only show 5 as my example) based on distances from 'edge'.
All defined dimensions, profiles, and objects are called from these tooling points. This might make it easier to measure as they have something tangible to measure too.
Coleman Donnelly
Thanks for the response :)
Thats part of the problem - the geometry is not based on discreet points. The mating geometry is a mirror of the surface in the print, and the "best fit" could be represented by any points in the surface - and the points will vary from sample to sample.
Paul F. Jackson
• Is the mating geometry the basic profile of the contoured primary?
• Is the part rigid?
• When a part is fitted on the mating geometry is there any definition of a true or conforming profile of the remaining surfaces?
• If possible use the mating profile as the datum simulator for your inspections.
• For comparison digitize a grid of conforming points from the conforming surface and create an array of the translation displacements making sure to increase saturation of points in any areas that have abrupt contour changes like edges etc.
• Fit the copies on the datum simulator and gather the mapped grid points for comparison to the conformance array.
• If it is not possible to use the mating profile as the datum simulator then you are going to have to digitize the true or conforming profile and store it in an array and scan/digitize the same grid on datum feature surface of the replica then run a best-fit pattern routine on the two arrays (you may have to iterate the process by shifting and rotating the grid on the replica until you are unable to significantly reduce the error between the true profile and the candidate profile). Once you have established the coordinate system on the replica then you can gather grid point data for all the remaining geometry and compare it to the true profile.
Paul
Coleman Donnelly
The mating geometry is a mirror image of the contoured geometry. The part is rigid. When the primary mating part is attached there is only contact between 2 surfaces. However, clerance and wall thickness are an issue, and other surfaces will assemble with other parts. There are some holes that will eventually be added, but it is still early in this design. Holes will mate with other parts in the assembly.
The concern here is not so much how to inspect, but how to document the correct information on the drawing...
R Complex IEC 60601-1 gap assessment IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
R Bill of Materials for a complex product - Industry best practice ISO 13485:2016 - Medical Device Quality Management Systems 2
Y Change Management in a very complex Research Organization Misc. Quality Assurance and Business Systems Related Topics 3
V Acceptance Criteria Gage R&R - Simple vs Complex Techniques Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
D SDS (MSDS) for complex products such as a TV, computer, cars, etc Miscellaneous Environmental Standards and EMS Related Discussions 3
L Automate GR&R using Minitab on complex, multi-measurement assemblies Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
Q Heat Treat Steel, Rockwell C - Variability in Complex Machined Shapes Manufacturing and Related Processes 7
T Sanity Check: 6 Sigma with a Complex Business Process Six Sigma 5
W 510(k) Submission for a huge, changing complex Medical Device System Other US Medical Device Regulations 6
C AS9100C Implementation in a Complex Situation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
optomist1 GD&T Study Aids - Medium to Complex Y14.5M Drawings Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K Complex Cause Root Cause Analysis Quality Tools, Improvement and Analysis 3
P Internal Auditing - How complex must it be? Metal Processing ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
M Quality Management is simple or complex (man-machine-method-material-environment) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
U Tools for Complex System Interactions Design and Development of Products and Processes 5
M How do you identify the wrong orientation in complex wiring harness? Manufacturing and Related Processes 21
S Organizational Complexity Theory - What makes organizations complex Quality Manager and Management Related Issues 4
K Product Development Management System (PDMS) that's too complex. Manufacturing and Related Processes 4
E Source Inspection Minimum Qualifications - Complex PWAs and PWBs - SOW and J-Std-001 Career and Occupation Discussions 2
K IMDS concern (re: CaZn Complex Stabilizers) - No CAS number RoHS, REACH, ELV, IMDS and Restricted Substances 4
S Reliability Prediction of Complex Assemblies Reliability Analysis - Predictions, Testing and Standards 2
S Surface roughness Rz Manufacturing and Related Processes 1
L GD&T Position for surface Inspection, Prints (Drawings), Testing, Sampling and Related Topics 9
K Surface finish (Evaluation Length) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
P Surface scratch measurement General Measurement Device and Calibration Topics 1
D Surface Roughness understanding Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
D Calibration of Digital thermometer with surface probe General Measurement Device and Calibration Topics 1
J Gear Surface Finish - Print with the word "calibrated" Manufacturing and Related Processes 2
R Design and Manufacture Guidelines for Surface Mount Technology Misc. Quality Assurance and Business Systems Related Topics 9
8 Surface Finish - Callout as 8 - 16 Rq Manufacturing and Related Processes 1
M Active Surface Disinfectant Claims - FDA vs EPA and Hands vs Objects Other Medical Device and Orthopedic Related Topics 0
GoKats78 Callout on Surface Finish General Measurement Device and Calibration Topics 11
P Gas Nitriding Surface Hardening of Stainless Steel 304 ISO 13485:2016 - Medical Device Quality Management Systems 4
S Difference between Surface Finish (Ra) and Flatness (GD&T) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N Creepage - Does a surface mount isolator body negate a PCB slot? IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
CCaantley Where to get a good test indicator stand for a granite surface plate General Measurement Device and Calibration Topics 8
M Interesting Discussion Surface Cleanliness Real Time Test Tools General Measurement Device and Calibration Topics 2
P Romer Arm - Profile of a Surface Changing General Measurement Device and Calibration Topics 4
R Reporting Profile of a surface with U modifier Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
S Response Surface Method to create design matrix in Minitab Using Minitab Software 5
Proud Liberal Surface finish measurement (roughness) - Rz under the ISO standard vs ANSI standard Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
Proud Liberal Measuring axial and radial surface finish (16 Rz) on a broached internal radius Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
B Profile of a Surface Callout on this Drawing General Measurement Device and Calibration Topics 4
O Can a Profile of a Surface have a Diameter Symbol? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Surface Roughness - Conversion of RS on a Print to RZ General Measurement Device and Calibration Topics 3
S ARP 1820 Surface Contamination Testing Various Other Specifications, Standards, and related Requirements 1
N Projection welding of nuts on zinc coated surface Manufacturing and Related Processes 3
K Can a Surface of a profile be applied to a feature of size? GD&T questions Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
alonFAI Component Failure (Relay) during ICT Testing after Surface Mount Assembly Manufacturing and Related Processes 5
