Compliance Marks on Labeling - Required, recommended, or useless?
Mark Meer
Hi Everyone,
With regards to labelling an electrical medical device in the EU:
Obviously, the CE mark is required.
But what about the following:
- WEEE mark
- RoHS mark
- GS mark (for Germany?)
- Mark to show EN60601-1 compliance (such as the TUV T-mark)
Are the above marks:
- Required to be present on the device labels to market the medical device in Europe?
OR
- Recommended to access markets. Are there markets that are likely to specifically look for such marks (like an NRTL mark in US)?
OR
- Totally optional. Just a way to show compliance to standards or directives?
Marcelo
We are talking two different things here.
CE marking is a mandatory regulatory requirement. When you give it to yourself (yes, you give it to yourself, not anyone else give it to you), it means you comply with the applicable european directives relevant to your product.
MDD, AIMMD, IVDMM, RoHS and WEEE are European directives.
If your device is a medical electrical device, you may need to be compliant with: MDD, RoHS (depending on the date), WEEE, maybe the EMC directive, maybe the Machine Directive, maybe the General Product Safety Directive.
Again, this is mandatory.
Although CE Marking it is called marking in general, it has nothing to do with certification marks, which are voluntary.
GS mark (Gepr?fte Sicherheit ("Tested Safety")) or mark to show EN60601-1 compliance (such as the TUV T-mark) are voluntary certification marks. Generally they are not required (one clear case in which such usual voluntary marks are required are the UL components required by the US), but can be used to help fulfill requirements of regulations.
So they are totally optional. Just a way to show compliance to directives. Note that for the directives, even the standards are voluntary too.
Mark Meer
Thanks Marcelo.
For most medical electrical equipment, yes, RoHS and WEEE, and of course either MDD, AIMMD or IVDMM will apply.
From the directives, it appears:
  • For the RoHS2 (2011/65/EU), there is no particular marking requirement.
  • For the WEEE (2012-19-EU), a marking with the WEEE is required. If not on the device itself (due to space or function), at least on accompanying packaging, IFU and warranty (see Article 14(4))
Yes, EN60601-1 compliance goes a long way to fulfill requirements of regulations (side-note: hats-off to any manufacturer that does not go this route! :yes:).
...but my question is specifically regarding marks. If claiming compliance, is such marks on the product required, or is it sufficient just to maintain appropriate test-reports internally?
...and if not strictly required, are there certain markets (e.g. clinical, hospital) that are likely to be looking for them anyway?
Marcelo
Thanks Marcelo.
Yes, EN60601-1 compliance goes a long way to fulfill requirements of regulations (side-note: hats-off to any manufacturer that does not go this route! ).
I think there?s some confusion here.
The mark required by WEEE is regulatory requirement which is a label symbol which has a meaning defined in a standard. It?s mandatory due to Article 14 of the regulation.
The certification "marks" are symbols from certification bodies which shows compliance with certification programs run by those certification bodies. The need for a product to have this marking (label symbol) to show compliance with the certification porogram is defined by the certification requirements (and they are usually required anyway).
So
If you worried about claiming compliance with the mark (meaning, it?s a certification problem), you have to verify if the certification rules requires the marking.
If you are worried about claiming compliance with a standard to show compliance with the regulatory requirement, the mark (certification mark) is not needed (again I,m saying this about certification marks, not the marking required by WEEE, which is mandatory)
In the case of EU, it depends on the country. The GS mark, I think, may be expected in Germany, even if mandatory. It would be the same case as in the US, in which generally the UL mark is not required for the product itself, but people feel more comfortable with it (and this can get worse because some or all insurance companies won?t insure devices if they do not bear the UL mark).
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
H Automotive wires - Compliance with USCAR21-4 & USCAR38-1 Various Other Specifications, Standards, and related Requirements 0
M FULFILMENT of compliance obligation versus COMPLY with compliance obligations ISO 14001:2015 Specific Discussions 2
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
M Advice needed for SEH Compliance Software and ISNETWord Compatabiliy Occupational Health & Safety Management Standards 2
D HIPAA, HITECH and Interoperability compliance route Medical Device and FDA Regulations and Standards News 2
A Environmental Compliance obligations and risks (ISO 14001:2015 6.1.3) ISO 14001:2015 Specific Discussions 3
M Tracking Expiration dates on compliance certifications REACH and RoHS Conversations 2
T Training recommendations? Bringing our RoHS and REACH compliance efforts in-house REACH and RoHS Conversations 2
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
G ISO 14001 - 6.1.3 Compliance Obligations ISO 14001:2015 Specific Discussions 1
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
N Which EN ISO 17664 version compliance to EU MDR? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
J Management Representative and PRRC (Person Responsible for Regulatory Compliance) ISO 13485:2016 - Medical Device Quality Management Systems 10
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
J Interesting Discussion Compliance with regulations in exceptional circumstances EU Medical Device Regulations 5
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
V Preparing the IFU in compliance with MDR 745, Chapter III EU Medical Device Regulations 2
L AS9146 Implementation and Compliance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P MDR PRRC (person responsible for regulatory compliance) and personal liability EU Medical Device Regulations 3
R Foam mattresses used in hospitals - compliance with MDR requirements? EU Medical Device Regulations 6
E Machines in Europe not in compliance with the EC directive CE Marking (Conformité Européene) / CB Scheme 0
N EUDAMED postponement and compliance with Article 120 (3) MDR for Legacy Devices EU Medical Device Regulations 8
R Role of quality compliance in SAP Software Quality Assurance 2
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
M MDR Legacy Medical Device Labeling compliance timeline EU Medical Device Regulations 3
D Required Checklist Showing Compliance to IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 11
D What is the best software used for the pharma compliance management? Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 0
T Rumours that class 1 NS, NM, NR devices will have a new deadline for MDR compliance EU Medical Device Regulations 3
M Informational From RAPS: Danish Regulators Seek to Help Smaller Companies With EU MDR Compliance Medical Device and FDA Regulations and Standards News 0
G ISO 9001 Legal Compliance and Legal Register Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Ed Panek Do Cloud services require 21 CFR Part 11 compliance? Qualification and Validation (including 21 CFR Part 11) 7
R Certificate of compliance to RoHS/REACH/WEEE - any such animal? REACH and RoHS Conversations 18
Sidney Vianna Interesting Discussion Legal compliance as part of ISO 45001 accredited certification. Major OSHA penalties in the USA. Occupational Health & Safety Management Standards 15
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
J Business Intelligence and 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 1
M Informational US FDA issued the first warning letter for UDI violations to help ensure compliance Medical Device and FDA Regulations and Standards News 0
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab ISO 17025 related Discussions 0
D USFDA vs NRTL/IEC 17025 Differences - Compliance testing lab US Food and Drug Administration (FDA) 6
I CAP/CLIA Environment - Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 3
