Compliance to 21 CFR Part 11 Require Registration to FDA?
dsudduth
In a past audit, the auditor recommended that if an establishment had implemented electronic signature capability for its quality system, the establishment needed to register with the FDA. We searched the FDA website for this requirement under 21 Part 11 but only found reference to the registration for electronic, e-signed MDR submissions. Any thoughts from this group? :bigwave:
Ajit Basrur
Are you refering to 21 CFR Part 11.100 (c) -
(c) Persons using electronic signatures shall, prior to or at the time of such use, certify to the agency that the electronic signatures in their system, used on or after August 20, 1997, are intended to be the legally binding equivalent of traditional handwritten signatures.
(1) The certification shall be submitted in paper form and signed with a traditional handwritten signature, to the Office of Regional Operations (HFC-100), 5600 Fishers Lane, Rockville, MD 20857.
(2) Persons using electronic signatures shall, upon agency request, provide additional certification or testimony that a specific electronic signature is the legally binding equivalent of the signer's handwritten signature
dsudduth
Yes, 21 CFR Part 11.100(c). Understand, but do you know if the agency is enforcing this requirement?:thanx:
sagai
Actually I can not recall any warning letter that was addressed any part11 related deficiencies to be honest.
MIREGMGR
I'm unclear on what's being asked. An Establishment is a company that engages in one or more of several regulated activity-types pertaining to medical devices, or something else that FDA regulates. You Register to become an Establishment. Whether or not you need to Register has nothing to do with whether you have an electronic signatures/record system. It would be perfectly acceptable for a company that is not required to Register to have an electronic signatures/records system that technically would comply with Part 11. The fact that that company has such a system has no bearing on whether they are required to Register.
Some Establishments use the electronic submissions capability that FDA has set up, for MDRs or certain other filing types. This capability and Part 11 have essentially nothing to do with each other.
Some Establishments use the electronic submission compilation and formatting software that FDA provides. This software also has nothing to do with Part 11.
Ronen E
Problem Solver
Moderator
Based on the OP's clarification
I believe that "registration" was merely a poor choice of word, while they were actually referring to "certification", as described in 21 CFR Part 11.100(c).
v9991
i agree with MIREGMGR....
This is not an approval process, but instead, it is a way to let FDA knows that the electronic signatures in their systems are intended to be the legally binding equivalent of traditional handwritten signatures.
http ://www. fda. gov/ downloads/AboutFDA/CentersOffices/OfficeofGlobalRegulatoryOperationsandPolicy/ORA/ORAElectronicReadingRoom/UCM059232.pdf - DEAD LINK
further, here's few references of 483/warning letter citations on ER/ES...
"Processes have not been approved. Electronic records are used, but they do not meet employee accountability/responsibility policy and signature manifestation requirements to ensure that they are trustworthy, reliable and generally equivalent to paper records
The document control procedures do not designate an individual to review documents for adequacy and approve them prior to issuance. Electronic records are used, but they do not meet signature manifestation requirements to ensure that they are trustworthy, reliable and generally equivalent to paper records.
Document control procedures were not complete. Electronic records are used, but they do not meet retention requirements to ensure that they are trustworthy, reliable and generally equivalent to paper records.
Specifically,
Gaps are encountered in the RPR record numbers where sequential auto record numbering is used to create the RPR record numbers.
Work orders are generated and implemented without evidence of electronic signature or other evidence of signature and approval date.
http :// www. fda. gov/AboutFDA/CentersOffices/OfficeofGlobalRegulatoryOperationsandPolicy/ORA/ORAElectronicReadingRoom/ucm061783.htm - DEAD LINK
Electronic signatures are being used in the complaint and incoming inspection systems and the firm has yet to certify to FDA that the electronic signatures in their systems are intended to be legally binding equivalent of traditional handwritten signatures.
e electronic records and signatures, there are no procedures addressing the following:
a) Validation of systems to ensure accuracy, reliability, consistent intended performance, and
the ability to discern invalid or altered records.
b) The ability to generate accurate and complete copies of records.
c) Protection of records throughout the record retention period.
d) Limiting system access.
e) And the system can create an audit trail that is computer-generated, time stamped to
independently record the date and time of operator entries and actions.
http: // www. fda. gov/downloads/AboutFDA/CentersOffices/OfficeofGlobalRegulatoryOperationsandPolicy/ORA/ORAElectronicReadingRoom/UCM059232.pdf - DEAD LINK
Mark Meer
so how could it be "certify to agency" ?
This thread talks more about the certification.
Basically, it's just a signed statement. The recommended wording (see FR vol. 62, no. 54, page 13456 (comment 120)) is:
"Pursuant to Section 11.100 of Title 21 of the Code of Federal Regulations, this is to certify that [name of organization] intends that all electronic signatures executed by our employees, agents, or representatives, located anywhere in the world, are the legally binding equivalent of traditional handwritten signatures."
Sign it and send it to the address given in 21 CFR 11.100.
There is no need to wait for a reply.
As far as I know, that is all that is involved.
L Wearables 21 CFR Part 11 compliance Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
Ed Panek Do Cloud services require 21 CFR Part 11 compliance? Qualification and Validation (including 21 CFR Part 11) 7
J Business Intelligence and 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 1
I GMP 21 CFR Part 11 Electronic Records Compliance Project Help Qualification and Validation (including 21 CFR Part 11) 9
N Change Control - Compliance with FDA 21 CFR Part 820 Document Control Systems, Procedures, Forms and Templates 3
I 510(k) Raw Data from Studies - 21 CFR Part 11 Compliance Qualification and Validation (including 21 CFR Part 11) 4
L Design software for a spectrophotometer for 21 CFR Part 11 compliance Qualification and Validation (including 21 CFR Part 11) 1
V Should template/formats be pre configured to claim 21 CFR part 11 compliance? Qualification and Validation (including 21 CFR Part 11) 5
U Compliance with CFR 21 Part 11 vs. ISO 9001 Certification Qualification and Validation (including 21 CFR Part 11) 9
G Original Data Copying to Maintain Compliance with 21 CFR Part 820.180 US Food and Drug Administration (FDA) 2
L Compliance to 21 CFR Part 11 - Where to start?? Qualification and Validation (including 21 CFR Part 11) 20
T 21 CFR Part 11 Compliance - Generation of Complete Copies of Records Qualification and Validation (including 21 CFR Part 11) 3
T 21 CFR Part 11 Compliance - Using PDF files as our documentation masters Quality Assurance and Compliance Software Tools and Solutions 3
N Certificate of Compliance from a Sister Company for FDA 21 CFR 820 Exemption 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Quality Compliance Software to meet ISO 13485 QMS and 21 CFR 820 Requirements Quality Assurance and Compliance Software Tools and Solutions 3
N Upgrading ISO 13485:2003 QMS to FDA 21 CFR 820 Compliance ISO 13485:2016 - Medical Device Quality Management Systems 1
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 3
E Accredited vs. non-accredited labs for 60601 compliance in the US IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
E Accredited vs. non-accredited labs for 60601 compliance in the US Other Medical Device Related Standards 4
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
H Automotive wires - Compliance with USCAR21-4 & USCAR38-1 Various Other Specifications, Standards, and related Requirements 0
M FULFILMENT of compliance obligation versus COMPLY with compliance obligations ISO 14001:2015 Specific Discussions 2
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
L Medical device HIPAA compliance in encryption Medical Information Technology, Medical Software and Health Informatics 1
J Strategy for MDR Regulatory Compliance Procedure ISO 13485:2016 - Medical Device Quality Management Systems 4
G Adopting old product - compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 9
M Advice needed for SEH Compliance Software and ISNETWord Compatabiliy Occupational Health & Safety Management Standards 2
D HIPAA, HITECH and Interoperability compliance route Medical Device and FDA Regulations and Standards News 2
A Environmental Compliance obligations and risks (ISO 14001:2015 6.1.3) ISO 14001:2015 Specific Discussions 3
M Tracking Expiration dates on compliance certifications REACH and RoHS Conversations 2
T Training recommendations? Bringing our RoHS and REACH compliance efforts in-house REACH and RoHS Conversations 2
optomist1 Informational Training IMDS - Management of Product Chemical Regulatory Compliance RoHS, REACH, ELV, IMDS and Restricted Substances 2
G ISO 14001 - 6.1.3 Compliance Obligations ISO 14001:2015 Specific Discussions 1
Ed Panek Compliance with Standards? When a standard is updated/revised CE Marking (Conformité Européene) / CB Scheme 3
K IEC 62304 compliance - Code reviews as part of verification strategy IEC 62304 - Medical Device Software Life Cycle Processes 5
N Which EN ISO 17664 version compliance to EU MDR? Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 3
N Audit non-compliance API Q1 - Use of External Documents 4.4.4 in Product Realization Oil and Gas Industry Standards and Regulations 8
C Compliance with ISO 17025 requirement 8.4.2 - Controls - Records recovery ISO 17025 related Discussions 4
J Management Representative and PRRC (Person Responsible for Regulatory Compliance) ISO 13485:2016 - Medical Device Quality Management Systems 10
N Audit non-compliance - API Spec Q1 9th Ed 5.6.1.2 b Oil and Gas Industry Standards and Regulations 10
J Interesting Discussion Compliance with regulations in exceptional circumstances EU Medical Device Regulations 5
V Preparing the IFU in compliance with MDR 745, Chapter III EU Medical Device Regulations 2
L AS9146 Implementation and Compliance AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P MDR PRRC (person responsible for regulatory compliance) and personal liability EU Medical Device Regulations 3
R Foam mattresses used in hospitals - compliance with MDR requirements? EU Medical Device Regulations 6
E Machines in Europe not in compliance with the EC directive CE Marking (Conformité Européene) / CB Scheme 0
N EUDAMED postponement and compliance with Article 120 (3) MDR for Legacy Devices EU Medical Device Regulations 8
R Role of quality compliance in SAP Software Quality Assurance 2
E Part 11 Compliance, Excel living documents (i.e. document master list, equipment list, approved supplier list) Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 3
