Complying with ISO 9001 7.6 - Customer Provided Computer and Software
N
nmcelrath
Here is the scenario. We build a product for our customer. The customer consigns the test equipment which may be a computer with test software installed. The test procedure says to turn on the computer, install a device to be tested and click on an icon. If the computer says pass then the device is good. If the computer says fail then the device is not good.
With what I know; I have a computer and it has software.
And what I don?t know; what the requirements of the computer are, what the software is doing or what the customer (supplier and owner of the computer and software) has done to verify or validate the test.
My question is; what is my responsibility in my QMS to satisfy the requirements of ISO9001:2008 7.6?
Stijloor
Re: Complying with ISO 9001 7.6
And what I don’t know; what the requirements of the computer are, what the software is doing or what the customer (supplier and owner of the computer and software) has done to verify or validate the test.
I am not a computer software expert. :nope:
But this is what the Standard says:
When used in the monitoring and measurement of specified requirements, the ability of computer software to satisfy the intended application shall be confirmed. This shall be undertaken prior to initial use and reconfirmed as necessary.
NOTE Confirmation of the ability of computer software to satisfy the intended application would typically include its verification and configuration management to maintain its suitability for use.
N
nmcelrath
As I understand it then… if I have a procedure that requires the test set up is verified and a known good (gold board) be tested and passed prior to running the production lot, I should meet the requirement.
Stijloor
As I understand it then? if I have a procedure that requires the test set up is verified and a known good (gold board) be tested and passed prior to running the production lot, I should meet the requirement.
That's one way to do this. Let's see what other Members have to say...
Mikishots
If the test equipment is provided to you by the customer as part of the verification of product for that customer, the customer bears the responsibility for ensuring it can adequately satisfy the requirements for which it is intended. If the customer did not provide you with any other information on the test gear or its functions, they cannot expect you to be responsible for verification or validation of the test.
The monitoring and measuring requirements are stipulated by the customer and are clear from your post: "turn on the computer, install a device to be tested and click on an icon. If the computer says pass then the device is good. If the computer says fail then the device is not good."
Any other wording in the contract?
insect warfare
QA=Question Authority
Your test procedure should be all you need to show compliance to 7.6. It is the basis used for verification, and it is recorded per subparagraph (a). If the software itself or its configuration changes (such as a new SW version or bundle is made available by the customer) then the test procedure can simply be updated to include the new requirements.
The part of 7.6 dealing with "the ability of computer software to satisy the intended application" would also tie in with 7.5.4 Customer Property, since your customer provides the software and equipment, and they must be maintained in accordance with those requirements, plus any other applicable customer requirements.
Brian :rolleyes:
N
nmcelrath
Thank you to all who posted. I believe this dicussion has provided me a sound understanding.
qualprod Shortening processes complying with process approach ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
qualprod Complying with ISO 9001:2015 - 9.1.1 b - Monitoring, measuring, analyzing and evaluation ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q ISO 9001 Certified but not complying with ISO clauses ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
J Control of Records - Complying with ISO 9001 Clause 4.2.4 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
W Complying with ISO 9001 Calibration Requirements - Report Before and After Data General Measurement Device and Calibration Topics 12
F Complying with ISO 17025 by UNIDO ISO 17025 related Discussions 0
S Suggestions or advice on complying with ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 3
B Complying with ISO 14001 Clause 4.4.4 "Document Interaction" ISO 14001:2015 Specific Discussions 9
I Complying ISO 13485 - Require other documentation specified by regional regulations? ISO 13485:2016 - Medical Device Quality Management Systems 5
N Competitor not complying with regulations (EU) EU Medical Device Regulations 1
R Advice needed: Shall I report my not complying company to NB / competent Authority (Europe) EU Medical Device Regulations 6
S Complying with IATF 16949 Cl. 8.4.2.1 - Type and extent of control IATF 16949 - Automotive Quality Systems Standard 1
M Complying with AS9100 D Section 8.4.3 m. Ensuring that persons are Aware of... AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
I Does being a subsidiary fully absolve company B from complying with 21 CFR 820? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R Failure of X-Capacitors complying with IEC 60384-14 IEC 60601 - Medical Electrical Equipment Safety Standards Series 13
S Unified Quality Policy sample complying to 9001-14001-18001 Misc. Quality Assurance and Business Systems Related Topics 18
I Acceptability of Existing Devices complying to IEC 60601-1 2nd Edition after Jun'2012 IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
N Complying with AS9102 when the supplier is using 3D Model Based Definition (3D MBD) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Customer Focus - Complying with TS 16949 clauses 7.2.1 and 8.2.1 IATF 16949 - Automotive Quality Systems Standard 5
J Complying with Change Notification Requests - Wholesale Distributor Quality Manager and Management Related Issues 7
K Complying with Ford customer requirement 4.35 Variable Gage Studies General Measurement Device and Calibration Topics 3
S Deadline for complying/replying to a Customer Complaint Customer Complaints 6
V Purchase Order Clauses - Complying with AS9100 clauses 7.4.2 e & f AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
S Configuration Management Simplified - Complying with AS9100 Clause 4.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
S CE Marking Question - Class IIa device by complying with Annex V & VII EU Medical Device Regulations 10
D Complying with TS 16949 and QS-9000 Supplier (Subcontractor) Development Requirements Supplier Quality Assurance and other Supplier Issues 43
K Complying with the requirement for Contingency Plans - 4.9.b.2 QS-9000 - American Automotive Manufacturers Standard 44
D Question on Documented Calibration versus ISO 17025 Accredited Calibration ISO 13485:2016 - Medical Device Quality Management Systems 0
M Customer Property - ISO 13485:2016 Clause 7.5.10 ISO 13485:2016 - Medical Device Quality Management Systems 6
pbojsen ISO 13485 Requirements versus FDA product classification and GMP exemptions - Audits ISO 13485:2016 - Medical Device Quality Management Systems 3
D "certified" in ISO 19011, as well as IATF required? IATF 16949 - Automotive Quality Systems Standard 4
S ISO/IEC 15408 - Is this is Certifiable Standard? Other ISO and International Standards and European Regulations 2
D Lead time to schedule an ISO 13485 audit Auditing Quality and Environmental Management Systems 2
T Do we need an SOP for ISO 9001? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
K ISO 9001 Auditing in a Healthcare setting Auditing Quality and Environmental Management Systems 15
S Does anyone have a checklist to prepare for ISO 13485, Stage I audit? ISO 13485:2016 - Medical Device Quality Management Systems 1
H QMS ISO 13485:2016 - ISO14971 IEC60304 etc ISO 13485:2016 - Medical Device Quality Management Systems 2
Y How can i integrate ISO 13845 into ISO 27001? ISO 13485:2016 - Medical Device Quality Management Systems 4
vickyva ISO 14155:2020 CIP CIR templates Other Medical Device Related Standards 0
C ISO 9001:2015 8.3.2. h) Design and Development Planning - What is required? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Employee Handbook in ISO 9001:2015 Section 7 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
B Operational Procedures for ISO 13485:2016 ISO 13485:2016 - Medical Device Quality Management Systems 7
Q ISO 9001/IATF 16949 Audit Finding Question - Document Retention IATF 16949 - Automotive Quality Systems Standard 10
D ISO 14971 applicability in ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 7
G Trying to get a financially reasonable ISO Certification Body Registrars and Notified Bodies 8
L ISO 45001:2018 - Clause 5.4: Consultation and Participation of Workers Process Maps, Process Mapping and Turtle Diagrams 1
E ISO 13485 in Clinical Trial conduct: Applicable or No ISO 13485:2016 - Medical Device Quality Management Systems 2
G ISO 13485 Certification - Can we get the ISO 13485 certification prior to shipment of the device? ISO 13485:2016 - Medical Device Quality Management Systems 6
Richard Regalado Informational ISO/IEC DIS 27001:2021, to be published soon. IEC 27001 - Information Security Management Systems (ISMS) 0
Q Audit report template ISO 9001/14001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
