Component Placement Per hour in Pick & Place Machine
kellyong
I'm going to setup this Pick & Place Machine, I'd be grateful if someone can show me the way how to do it, The questions are :
1. How to take Component Placement Per Hour(CPH) for this Pick & Place Machine (SMT) ?
2. As I knew, this CPH might be difference due to PCB board size, then am I going to determines CPH ?
3. What about this Cycle time for Pick & Place Machine, does this Cycle time is same as CPH ?
Hope someone can help because I need it desperately
Steve Prevette
Deming Disciple
I've run a lot of cycle time analyses - but will need to ask some questions / make some assumptions about your question.
1. Does this include soldering the components onto the PCB (especially if they are surface-mount) or is that the next step by another machine?
2. I would assume PCB board size would affect component placement given how much movement from pickup to placement that the machine would need to make, and I assume also that if several components are the same, that would take less time that if every component to be placed was different from each other. I would assume you would want to plan the load to minimize the distance moved by the machine.
3. I would ASSUME that "cycle time" would be the time to place ALL components on the PCB in question from receipt of the empty PCB board to kicking out a filled PCB board. I would assume you would need to take into account rework time for any missed locations, wrong placements, or skweed (not seated) placements.
4. What does "SMT" stand for?
An important question is - do you have any past data / experience with this machine that you could use as a starting point? Short of that, you could estimate off of the manufacturer's specs.
ScottK
Not out of the crisis
get a copy of IPC 9850 which attempts to standardize this process.
this article is useful too.
What is CPH?.
M Importing a custom component for our medical device 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
D Component vs Device ISO 13485:2016 - Medical Device Quality Management Systems 5
C Biocompatability Testing - Electric Breast Pumps , Silicone Component EU Medical Device Regulations 3
K ISO 13485 Design Requirement with respect to "component" manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 11
K Medical Device file and "Component" Manufacturers? Other Medical Device and Orthopedic Related Topics 6
J Regulatory path to enter EU market for non medical 60601 component Other Medical Device Regulations World-Wide 2
L Automatically considered Critical Component when within a fire ENCLOSURE? IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
S Reintroduce packaging component/med device from white room back to class 7 clean room Manufacturing and Related Processes 1
J Medical Device Component Change - Testing, Sampling Criteria ISO 14971 - Medical Device Risk Management 3
S Reliability issue - Frequent component failure of the product Reliability Analysis - Predictions, Testing and Standards 2
S Device with different options for a sub-component - CE marking implications EU Medical Device Regulations 2
E Component manufacturer or contract manufacturer ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M Accessory or a Component Other US Medical Device Regulations 6
F Component maintenance qualification - Regulation (EU) No 1321/2014 Article 5 EASA and JAA Aviation Standards and Requirements 6
D SINGLE FAULT CONDITION, short circuit and open circuit of any component (IEC 60601-1 3.1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
K Regulatory requirement of SaMD with machine learning component IEC 62304 - Medical Device Software Life Cycle Processes 3
D Relabelling a component that will be sold as a spare part - Do I become legal manufacturer? EU Medical Device Regulations 2
Anonymous16-2 Dietary Supplement Raw Material/Component Storage and Production Manufacturing and Related Processes 1
S PSW - Requirements for "off-the shelf" component that has multiply manufacturing locations Off the Shelf Item Manufacturing and Related Processes 1
V Process, component or full product re-qualification: leaded to unleaded solder Qualification and Validation (including 21 CFR Part 11) 8
J Traceability of component parts - Bolts, screws and washers ISO 13485:2016 - Medical Device Quality Management Systems 3
R When does the FDA consider a component a medical device? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 17
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
J What is the minimum standard for automotive component traceability? Manufacturing and Related Processes 2
M Informational US FDA – URGENT/11 Cybersecurity Vulnerabilities in a Widely-Used Third-Party Software Component May Introduce Risks During Use of Certain Medical Dev Medical Device and FDA Regulations and Standards News 0
D Standard guide for shelf life determination of non sterile component with degradation materials Reliability Analysis - Predictions, Testing and Standards 1
F Component Molding and Over-molding - Handling Resin Inventory Manufacturing and Related Processes 2
S REF and CE mark symbols on multi-component device EU Medical Device Regulations 3
J EC REP information and CE Mark - Component of a system that is not a medical device EU Medical Device Regulations 2
A Domain of the component (EASA CM No.: CM-SWCEH-001 Issue 01 Revision 02) Point 9.3.3 (Usage domain aspects) EASA and JAA Aviation Standards and Requirements 0
R IMDS for double sourced component RoHS, REACH, ELV, IMDS and Restricted Substances 3
C PCBA Hardware Component different failure types - How to rate detection? FMEA and Control Plans 8
N FDA Traceability Requirements - Component lots ISO 13485:2016 - Medical Device Quality Management Systems 2
P Electronic component failure analysis turnaround time Reliability Analysis - Predictions, Testing and Standards 0
S Medical Device Supplier Component Qualification Service Industry Specific Topics 0
A Is a Manufacturing Process Sheet required for each Component? Manufacturing and Related Processes 4
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
D Design FMEA for a component - Should I make the following assumptions? FMEA and Control Plans 7
I Medical device manufacturer and component supplier miscommunication Other Medical Device Related Standards 5
M Methods of reducing/eliminating the systematic component of error General Measurement Device and Calibration Topics 0
birds1027 Non Applications in ISO 13485:2016 for component contract manufacturers ISO 13485:2016 - Medical Device Quality Management Systems 3
S The difference between a Medical Device Accessory and Component Canada Medical Device Regulations 2
K Biocompatibility Testing - Component Level or Assembled Medical Device? ISO 13485:2016 - Medical Device Quality Management Systems 7
S Who compiles the Critical Component List, Insulation Diagram etc.? IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
MDD_QNA What is the function of the Critical Component List? ISO 14971 - Medical Device Risk Management 2
M Cleanliness and Contamination question (Medical Device Component Manufacturer) ISO 13485:2016 - Medical Device Quality Management Systems 2
M Component Manufacturer of Food Stuffs Mfg. Equipment Parts - Eat Drink Policy ISO 13485:2016 - Medical Device Quality Management Systems 1
E Updating DHF (Design History File) to include Alternative Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
S ISO 13485 Definitions - Medical Device Component Supplier ISO 13485:2016 - Medical Device Quality Management Systems 4
