Components Cleaning for Manufacturing Sterilized Medical Device
shivaji141
Hi all,
Need your help for a making a single use medical device, class 1. This will be EtO sterilized.
My question is - Do we need to do any cleaning/ ultrasonic bath of the components before assembling the device. Are there any ISO/ASTM standards for this cleaning process and post-cleaning verification.
All my suppliers are ISO9001 certified, but not ISO13485.
We do not want to do the cleaning of complete device before sending out for sterilization and are therefore making it in the clean room.
Looking forward for your comments.
Regards,
CS
Jimmy the Brit
Hi CS,
In addition to the links provided by Ajit you need to ask why you might need to clean these components. Are you trying to make them chemically clean, by removing particles or release agents etc.. , or are you trying to lower their bioburden? If the latter, are you doing it because a high bacterial count may invalidate your sterility assurance level, or because you don't want to contaminate your clean room?
The answer to these questions will determine what level of cleaning, if any, you require. Chemical cleaning may require ultrasonic washing in a suitable solvent, whereas bioburden control could be addressed with surfactant washing or even low dose eBeam ...... I am happy to try to help further, if you can provide more details about the components and your needs.
Jim
shivaji141
Hi CS,
Jim
We are assemblying the device in class 100K clean room. The reason for cleaning being that I don't want to contaminate the clean room. For my product, I do have plastic parts (all molded in clean room again) and machined parts, wires.. (not from clean room).
I do not know how much will be the bio-burden of components(not got them yet), but I expect parts will be reasonable cleaned and free of dirt when I get them. I "believe" EtO process should be able to sterilize them. So, only requirement for cleaning is that it doesn't contaminate the clean room.
One of my partners is insisting on ultrasonic washing of machined parts- washers, screws etc. If done so, then, it has to be repeated everytime. Additonal process, additional costs. I am worried this implies overdoing things for a class 1 device.
Thanks,
Regards,
CS
Jimmy the Brit
This is a tough one. If the components are visibly clean when they arrive and have a low bioburden then there is no point in washing, however if they come in covered in process chemicals and with either a high, or very variable bioburden they will need to be cleaned. Is there any chance you could set a cleanliness specification with your supplier - "visibly clean" or something like that. For example I used to use a toothpaste test for hypodermic needles - squirt abrasive white toothpaste through the needle using a syringe and examine the line of paste for dirt/inclusions.
I really believe that controlling the supply is a lot easier than trying to clean in-house.
If nothing else, get some samples and check them out before committing yourself to a lifelong cleaning process that may be unnecessary.
I hope this is useful, but if not let me know and I will think again.
Jim
chris1price
I would agree with Jimmy, push the cleaning back to the supplier. Make certain your specification or agreement says that the product must be free from cutting oils, etc and also says how this is going to be tested.
Depending on the cycles used, EtO can be quite sensitive to bioburden, so don't assume it will always be low. I would start routine bioburden monitoring as early as possible to assess the trends and see how consistant your suppliers are.
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
R Components to a finished medical device, MDR requirements Other US Medical Device Regulations 1
U Procedure pack components EU Medical Device Regulations 3
T Sterilized components expiration date ISO 13485:2016 - Medical Device Quality Management Systems 1
T Sterilized components shelf life Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 1
C Warehousing two separate components to a finished device while meeting regulations Other US Medical Device Regulations 7
G Dealing with non conformity caused by Supplier Components detected in the production line IATF 16949 - Automotive Quality Systems Standard 14
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
J Process FMEA Template with examples - Cold and Hot Forged components FMEA and Control Plans 4
F Biocompatibility evaluation for Hardware/Interface Components? Other Medical Device Related Standards 12
K 510K new manufacturer but same components Other US Medical Device Regulations 6
D Using non-conforming components even though the final assembly is conforming? Manufacturing and Related Processes 5
R DHR question: Traceability of components ISO 13485:2016 - Medical Device Quality Management Systems 2
R What is meant by Use of COMPONENTS WITH HIGH-INTEGRITY CHARACTERISTICS in ME EQUIPMENT (clause no 4.9) IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
J Medical Device Components US to EU commercialization EU Medical Device Regulations 7
B IATF 16949 - Is a Deviation required for sample components in a prototype build? IATF 16949 - Automotive Quality Systems Standard 13
A Components of a medical device - Hardware robotic hand EU Medical Device Regulations 3
D IMDS for Like Components (Interior Plastic, Leather/vinyl Armrest, etc.)other than Color APQP and PPAP 1
JoshuaFroud Serial numbers and labelling when sharing device components ISO 13485:2016 - Medical Device Quality Management Systems 1
A How to deal with changed shared components in 510k 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
Nicole Desouza Plastic Extrusion of Medical Device Components - No ISO or AS 9100 Certifications Other Medical Device and Orthopedic Related Topics 7
Q Handling Off-the-Shelf Components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
I PPAP Assembly and Components Manufacturing and Related Processes 3
D CB Certificate - Distributor for a product with electrical components CE Marking (Conformité Européene) / CB Scheme 4
K Selling Medical Device Components to US hospitals and doctors US Food and Drug Administration (FDA) 4
S Need Assistance in Visual Inspection - Tiny electronic components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
R FDA - How to discontinue/obsolete medical devices that share sub-components with others that will still be distributed Other US Medical Device Regulations 5
F Mig Welded Components - IMDS International Material Data System RoHS, REACH, ELV, IMDS and Restricted Substances 1
D Software Validation - Contract manufacturer of Components (PCBA's) Qualification and Validation (including 21 CFR Part 11) 7
G Audit finding - Components being transferred inter-plant Internal Auditing 3
J Referencing Medical Device in FDA records - Package contains several other components Other Medical Device Regulations World-Wide 1
K Article 23 (Parts and components) - Economic Operator EU Medical Device Regulations 1
S How are Medical Device Components and Subassemblies defined? ISO 13485:2016 - Medical Device Quality Management Systems 1
H Classification of a Class IIb Medical Device with 3 Components CE Marking (Conformité Européene) / CB Scheme 1
P REACH - A few of the hundreds components in my product no longer meet requirement REACH and RoHS Conversations 2
C Medical device file for components such as adhesives, gaskets, films, etc. ISO 13485:2016 - Medical Device Quality Management Systems 13
S Do suppliers of prototyping components need to undergo supplier qualification? ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Is it acceptable to mix components from two different lots into an assembly? ISO 13485:2016 - Medical Device Quality Management Systems 1
M CE / FCC Compliance for components + final product CE Marking (Conformité Européene) / CB Scheme 2
D Determining Critical Components for conformity with IEC 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 21
R Components in parallel to creepage\clearance IEC 60601 - Medical Electrical Equipment Safety Standards Series 9
J To Calibrate or not to calibrate electronics rack components Manufacturing and Related Processes 5
T Control of Nonconforming Product Output (Components Parts) IATF 16949 - Automotive Quality Systems Standard 3
H CE Marking on Multiple-Components Medical Products EU Medical Device Regulations 8
Q CE Mark Requirements for Components - Solenoid Actuator Type Devices CE Marking (Conformité Européene) / CB Scheme 3
P Total Variation in Data - Overall Importance of the Principal Components Reliability Analysis - Predictions, Testing and Standards 1
F FDA PMK 510(k) - IEC 62304 Software Components Segregation Other US Medical Device Regulations 3
J Obsolete or Delete - Accepted Components from Suppliers RoHS, REACH, ELV, IMDS and Restricted Substances 3
H Perfusion System - HLM Components with Vendor Neutrality Other US Medical Device Regulations 6
P TSO Parts and Critical Components EASA and JAA Aviation Standards and Requirements 2
