Concerning procedures within Quality Manual
itsbiodiversity
I would love some of your thoughts. In my previous life I had a million procedures outside of the Quality Manual based on 17025 "shall have a procedure etc."; however, I realized that many of those external procedures would fit nicely within the QM itself.
With that said - is there any point in actually assigning a procedure (Such as Quality Procedure 01) to a procedure within the document?
My preference would be to maintain 17025 numbering and just say something along the lines of "the following is the procedure for (example) Internal Audits" and then go in to detail.
My reasoning is the internal audit procedure, for example, will probably not change as it is an annual deal that either results in action or does not.
Looking forward to your thoughts on this technicality.
Jen Kirley
Quality and Auditing Expert
I'm not sure I understand you correctly, but I see no problem with a procedure's sending users to another procedure that was made for a different standard. It is much better to simplify, as there is risk in making the same controls in more than one place.
Marc
<snip> My preference would be to maintain 17025 numbering and just say something along the lines of "the following is the procedure for (example) Internal Audits" and then go in to detail. <snip>
I would avoid any document numbering/ID using a standard, as it may change in the future. Devise a numbering/ID system that is right for your company.
somashekar
Please use the standard and do not lean on to the standard by quoting it across procedures. Your procedures must be useful to you. Devise your own simple numbering system which can be extended in future when a need arises.
The purpose of the manual and the procedures are different and hence its good to keep them different. Just make them for the sake of your organization and your people who use them.
dwperron
I have to agree with Somashekar.
When I have seen a quality manual written to mimic a quality standard (9001 or 17025) I get the impression that the organization is just trying to meet audit requirements - and it is easier to perform an audit with that format.
In reality, I have never seen an organization that runs its business that way. You should create a quality manual based on your operations, not on the numbering system of a standard. This document can be a useful tool.
L
locutus
+1 to somashekar and dwperron. Now and in the near future, your QMS needs to reflect how you do business, not a regurgitation of the standard - already see Registrars challenging companies that take that approach.
itsbiodiversity
I appreciate the replies.
I want to be clear - the procedures within the Quality Manual would be specific to our business practices, not a regurgitation of the standard. The procedures would be in the appropriate location within the standard.
For example, the procedure for assuring the quality of calibration results would be located in section 5.9 of 17025 quality manual. While some verbiage would be directly from 17025 - our procedure would be right beneath the "regurgitation" and directly reflect our practices.
Of course, as some of you mentioned, I am trying to make an audit go as smoothly as possible from a "paperwork" or review perspective. I am NOT trying to regurgitate the standard and call it our procedure.
I am very much appreciative of the replies.
With this being stated - would you still maintain the procedures outside of the QM? And if they are maintained within the QM it seems the consensus here is to assign a numbering value to the procedure (For example 5.9 assuring quality of calibration results (QUALITY PROCEDURE XX)?
Once again - I look forward to your replies.
howste
Thaumaturge
As with anything document related, you should first consider the users. What format will give them the information they need as quickly as possible so they can get back to doing their work. If it's easier for them to find everything in one massive document then do it. If it's easier for them to find it in shorter, more focused documents, then do it. I would say that if you do decide to go for everything in the manual then make sure you have an easy-to-read table of contents or index to link them to the content they're looking for.
itsbiodiversity
With CONTROL+F functionality it has become very simple to search through a long document.
I also have been in touch with registrars concerning this issue and from what I gather it is completely up to the laboratory how to organize and if it makes sense to combine to one document with very few outside quality procedures that is just fine.
Thank you for chiming in.
Hershal
Metrologist-Auditor
The true key is the need. Most quality procedures can in fact be contained in the QM. However, technical procedures such as equipment operation and so forth should be independent. Where there is an accepted Standard (e.g., ATSM), refer to it, and include detail only as needed to complete the requirements.
R Disagreement concerning 4.10.6.5 - National Recognized vs 'Home Grown' Procedures General Measurement Device and Calibration Topics 4
Mr Roo ISO 9001 - 7.1.3 Infrastructure - questions concerning evidence ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 26
L Special Processes - Technical reason concerning torque - Anaerobic compounds Manufacturing and Related Processes 10
M Informational EU – Application of transitional provisions concerning validity of certificates issued in accordance to Directives 90/385/EEC and 93/42/EEC Medical Device and FDA Regulations and Standards News 2
R Endless doubts and questions concerning procedure vs process. Process Maps, Process Mapping and Turtle Diagrams 22
P Study concerning adoption of and migration to ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
T PPAP - Complaint from a Tier One customer concerning Product Dimension IATF 16949 - Automotive Quality Systems Standard 26
V Concerning CQI-15 Welding System Assessment Form Document Control Systems, Procedures, Forms and Templates 1
L New Website from the FDA concerning UDI Exceptions, Alternatives and Time Extensions Other US Medical Device Regulations 0
somashekar Business Process Plan concerning MOH Malaysia Other Medical Device Regulations World-Wide 9
B Very interesting article concerning MSA (Measurement System Analysis) Book, Video, Blog and Web Site Reviews and Recommendations 8
B Is the ISO 13485 auditor being too picky concerning CMDCAS? ISO 13485:2016 - Medical Device Quality Management Systems 5
R Risk Analysis and Hazard Identification concerning Clinical Decision Support Systems ISO 14971 - Medical Device Risk Management 1
A General Controls - GMP interpretation? General Requirements Concerning Records 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
8 Looking for opinions concerning the re-start up of a 5s Program Lean in Manufacturing and Service Industries 22
M Requesting Information From FDA concerning Archived 510K 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
D Standards concerning Medical Device Battery Charging DURING Use Other Medical Device Related Standards 3
Q Brief overview of Standards and Regulations concerning Breast Implants Other Medical Device and Orthopedic Related Topics 2
Q Notification to Registrar Concerning Continuous Dynamics including Restructuring ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Regulations concerning Calibration of Stop Watches used for Testing Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
C Question concerning Medical Devices and Low Voltage Directive EU Medical Device Regulations 5
G Question concerning process troubleshooting and process FMEA usage in job shops FMEA and Control Plans 5
R For ISO/TS 16949 Auditors concerning the Auditor Development Process recertification General Auditing Discussions 4
P Complaints to CB concerning certified organization Registrars and Notified Bodies 17
C XR-charts question concerning R Statistical Analysis Tools, Techniques and SPC 18
C Who are these guys? E-mail from ASQ concerning a contested election for President ASQ, ANAB, UKAS, IAF, IRCA, Exemplar Global and Related Organizations 22
Q Concerning Special Characteristics Interpretation - Semiconductor commodity standard IATF 16949 - Automotive Quality Systems Standard 3
H Seeking Power Point Presentation Concerning Iso 17025 ISO 17025 related Discussions 4
L Concerning "allowable" supplier line accums before starting a corrective action Supplier Quality Assurance and other Supplier Issues 4
S Control chart limit calculation confusion concerning SPC control limit calculation Statistical Analysis Tools, Techniques and SPC 27
Y Procedures on Contract Review Document Control Systems, Procedures, Forms and Templates 3
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
L Where to place the what/when/how/who/where procedures in a multi-regulation AS9110C organisation AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
F Standard Calibration Procedures: Recommended Practice ISO 17025 related Discussions 0
DuncanGibbons Model-Based procedures and Architecting the QMS as a System Document Control Systems, Procedures, Forms and Templates 2
R Scientific Operating Procedures For Sterilization Practices in India PSA/2012/1 Other Medical Device Regulations World-Wide 0
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
DuncanGibbons Are the IQ OQ & PQ procedures applicable to the aerospace industry? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Procedures for Complaint Handling and Post Market Surveillance EU Medical Device Regulations 7
A Recall/Adverse event report procedures in Kuwait/Qatar/Kenya Other Medical Device and Orthopedic Related Topics 3
S Use of "Shall" versus "Should" in Procedures ISO 13485:2016 - Medical Device Quality Management Systems 26
F Recommended practice for furnishing Technical Procedures ISO 17025 related Discussions 1
B Measuring and monitoring equipment - Understanding which procedures to be compliant with ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
F ISO 17025:2017 Clause 7.4.1 - Requirements for Procedures ISO 17025 related Discussions 4
M MDR Annex IX Chapter I, 2.2 (c) - Device identification procedures during manufacture. EU Medical Device Regulations 1
R How to improve a Validation program and procedures to FDA (21 CFR part 820) & ISO13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
N ISO 9001: 2015 - Example standards policies, procedures, acknowledgements and checklists ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Quality System Processes without Documented Procedures Document Control Systems, Procedures, Forms and Templates 39
L IATF 16949 requirements for Product Safety Procedures IATF 16949 - Automotive Quality Systems Standard 14
M FDA News USFDA Final Rule – Medical Device Classification Procedures: Incorporating Food and Drug Administration Safety and Innovation Act Procedures Medical Device and FDA Regulations and Standards News 0
