Conducting a Project for Safety Improvement
mecanoo
New with that type of project, I was assigned to conducting a project for safety improvement on our facility;
how to begin? how to implement that project?
are there a standard methodology for that type of project?
Thanks for your help
Jen Kirley
Quality and Auditing Expert
Welcome to the Cove!
I would approach it like implementing 5S, by starting with an area where the changes would, if possible, recognizably improve people's lives.
You might also ask people what they would like to see you start with. People generally know what's unsafe but maybe are not likely to speak up on their own.
Changes should focus on engineering first, such as installing rails for fall protection and guards to keep people from lopping off their fingers in machinery. Light curtains are effective. After that, use administrative controls such as switching tasks to prevent fatigue and the risk of absent mindedness of rote routine tasks (I lost a finger tip with one of those). Lastly are behaviors, such as inspecting and wearing fall protection harnesses. Lockout tagout is a very important program but it requires much discipline in some applications so expect a learning curve and long term behavior shift.
I hope this helps!
RoxaneB
Congratulations on your first post, mecanoo! :applause:
Jennifer has given some great ideas on project topics and methods of addressing potential safey opportunities.
Are you also asking about format and how to document the project?
If that is the case, it should be no different than the project management or action plan process currently employed by your organization. If your organization does not have such as system, well, here's your opportunity to create one! Let us know if that is also part of your request.
mecanoo
I started by auditing work sations, shop floor, warehouses; it's not based on audit check list or any simular sheet, just observations recorded on a sheet;
I ended up by recording a list of different failures that will be used for action plan establishment;
Impress Managers and Responsibles could be very helpful for convincing people adopting this plan ( budget and time); and among the tools will be the quality of supporting documents; without forgetting the quality of actions set on plan;
so, sheets that cover items on this project will be very helpful; also a presentation for implementation methodology could help on first meeting;
thanks
K
kgott
I was assigned to conducting a project for safety improvement on our facility; how to begin?
Another approach to take is to start off by asking these 3 questions;
  1. What gets done?
  2. How could people get hurt by what gets done?
  3. What can be done about it?
In other words identify hazards, assess the degree of risk in each hazard and develop suitable controls for those risks. Start with high level risks first then work down.
A hazard is a source of harm. A risk is 'what are the chances of the harm being realised'
Use a consequence and severity matrix to assess the risk.
Select controls using the preferred order of control where elimination of the hazard is the most preferred control and personal protective equipment is the least preferred control.
The reason personal protective equipment is the least preferred is because if it fails the person is then directly exposed to the hazard.
Make up a list of hazards you have controlled and call it a risk register if you like so it will conform to the requirements of OHSAS 18001
M Lean: Conducting Capacity Study, calculating Cycle times on laser cutting machines Lean in Manufacturing and Service Industries 2
atitheya Need of conducting medical trials in European Union EU Medical Device Regulations 2
M Informational IMDRF draft document – Requirements for Regulatory Authority Recognition of Conformity Assessment Bodies Conducting Medical Device Regulatory Reviews Medical Device and FDA Regulations and Standards News 0
Pmarszal ISO 19011:2018 - Risk Based Approach for planning, conducting and reporting of internal audits Internal Auditing 8
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
P Suggestions on conducting Internal Audit of a new site Internal Auditing 15
dubrizo Internal Audit Value - What is the point of conducting internal audits to a checklist Internal Auditing 40
S Conducting an MSA study for ICT(HP3070) and Functional Testing Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q AS9100 Repairs - Approval from a non-aerospace customer prior to conducting a repair AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
A Is conducting of all MSA studies required, even if not required by the customer? IATF 16949 - Automotive Quality Systems Standard 23
B Best Methods for conducting Shadowgraph MSA Studies Quality Manager and Management Related Issues 2
M Sample size when conducting capability analysis with OK and NOK parts Statistical Analysis Tools, Techniques and SPC 3
N Who is responsible for conducting Root Cause investigation? Problem Solving, Root Cause Fault and Failure Analysis 8
H What information do I need to collect when conducting 2nd party audit? General Auditing Discussions 6
drgnrider Suggestions for conducting a Spill Clean-up Exercise Miscellaneous Environmental Standards and EMS Related Discussions 8
O Conducting MSA on Multiple Measurement Mystems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
C What kind of information you provide when conducting QMS Orientation? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
G Conducting a Bias Study for a CMM with no Traceable Master or Reference value Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
M Conducting Limited Internal Audits of QMS Elements - Simple question I hope ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
K Conducting ISO 9001:2008 and ISO 14001:2004 New Supplier Audit Supplier Quality Assurance and other Supplier Issues 5
D Anyone use an iPad for conducting Audits? Internal Auditing 18
T Conducting the "are all points within the control limits" test when there is no LCL? Statistical Analysis Tools, Techniques and SPC 2
J Need help calculating actual Ppk - Result of % GR&R=11.8% when conducting MSA Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 11
automoto Excel (xlsx) spreadsheet for conducting Type 1 MSA Analysis. Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 23
L Conducting Gap Analysis for ISO 27001 IEC 27001 - Information Security Management Systems (ISMS) 4
A Conducting a DOE in Minitab - Improving Surface Finish of an Impeller Using Minitab Software 10
K Advisable Period of Records to be Checked in Conducting an Audit Food Safety - ISO 22000, HACCP (21 CFR 120) 2
B Conducting a study on Hexagon Nuts "turned" on a multi-spindle automatic lathe Statistical Analysis Tools, Techniques and SPC 9
W Conducting Audit and Audit Report in accordance to 21 CFR 820 and ISO 13485 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 13
Q Design of Experiments Using Subgroup Data - Conducting a 2^3 factorial DoE Quality Tools, Improvement and Analysis 6
M Send a Supplier an Audit Plan prior to conducting an audit at their premises? General Auditing Discussions 8
P Suggestions on conducting an Internal Audit on 7.5.1.6 Production Scheduling IATF 16949 - Automotive Quality Systems Standard 2
D Forms and Templates used for Conducting Internal Audits (API Q1/TS 29001) Oil and Gas Industry Standards and Regulations 5
S Time Study Std/Books that define minimum requirements for conducting time study? Capability, Accuracy and Stability - Processes, Machines, etc. 9
Y Conducting a Mock Recall on a Medical Device Product ISO 13485:2016 - Medical Device Quality Management Systems 6
H Gathering the Data before Conducting GR&R (Gage R&R) Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Colin Conducting audits without procedures Internal Auditing 8
J Conducting Gage R&R - 300 plug gauges - Different diameters - One for each plug gage? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
F Conducting an ISO 9001, Clause 5.xx audit General Auditing Discussions 12
T Conducting an Energy Usage Audit - Seeking template or form Miscellaneous Environmental Standards and EMS Related Discussions 3
P Conducting a MSA - Measurement of plaster by use of a scoop - I need Help Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
A Goods-In Process Audit - Any pointers or hints for conducting a 'good' audit? Process Audits and Layered Process Audits 3
Marc Conducting Internal Audits vs. Third Party (Registrar) Audits Internal Auditing 11
J ISO 9001 'Compliant' Company - Conducting a supplier audit on a major supplier Supplier Quality Assurance and other Supplier Issues 17
L Conducting general overview training on ISO 14001 Training - Internal, External, Online and Distance Learning 1
L Project Managers - Questions For You Career and Occupation Discussions 0
Felony Melony Project Milestone Plan-Development to Mass Production APQP and PPAP 2
R Project Transfer to New Factory ISO 13485:2016 - Medical Device Quality Management Systems 6
S Need guidance on project ISO 13485:2016 - Medical Device Quality Management Systems 2
