Configuration Management as a process instead of a procedure
John Predmore
Our Director of Engineering has proposed that Configuration Management be elevated from a procedure to a process in our AS9100 QMS. His justification is that Configuration Management is a comprehensive set of activities, has inputs and outputs and KPI’s analogous to other defined processes, covers our product from conception to production and post-delivery, crosses all department boundaries and has many stakeholders. I think establishing Configuration Management as a separate process (we now have 7 process total) is redundant and I’m not sure this revision adds value. Do you have any comment on this idea from an auditor point-of-view? Could this change add clarity?
Seven processes now are Customer Support, R&D, Outsource Control, Product Delivery, Resource Mgmt, Continuous Improvement, Corporate Process. C.M. is currently a procedure within R&D.
John Broomfield
Your process or procedure question puzzled me.
A process is work and the procedure specifies the way the work is done. The procedure may not be documented at all but is documented to the extent necessary for effective planning and control of the process.
CM touches many processes and for effective CM would it not be best to specify the necessary CM controls in your management system’s applicable procedures?
Supported perhaps by the CM database.
After all these years we still suffer under the process/procedure dichotomy, or lack thereof. The two terms may be (and are) used interchangeably in many instances, and what you call it is not nearly as important as what's actually done. Insofar as "the processes of the QMS" is concerned, it would seem to me that configuration management might be comprised of more than one process. For example, there might be a process for handling changes in Purchasing, and another one in Production, and still others in Quality and Production. The important thing is that all of these things are managed such that the integrity of the system (there's another thing we can call it) is maintained throughout.
We are in Manufacturing company , we are only machining as per customer drawings . and there is no assembly.
So is it required to create Configuration management chart?
Randy
Process vs Procedure....
Configuration management in this case could be controlling the changes for original design like leaving out or adding sugar, water or their quantities; maybe adding another flavor or heating instead of using ice.
If you want to re-create the final result you arrived at you've got to manage and control the history of it's creation....
It's only as difficult as you make it.
This is simplified of course, but it's the exact same thing.... Then again I could be totally wrong and out of line. Process or Procedure.jpg
In your application, configuration management would be revision level control. Do what is necessary to ensure you are manufacturing to the drawing revision specified by the customer. Usually (but not always) it is the latest revision.
N Change Management, Configuration Management or Other Process? Manufacturing and Related Processes 9
C Configuration Management Process flow AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
G AS9100-8.1.2 Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Configuration Management in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Configuration Management - Physical Audit and Functional Audit for Software and Hardware General Auditing Discussions 4
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
P Configuration Management Software EASA and JAA Aviation Standards and Requirements 4
Q Configuration management clarification and example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Risk Management and Configuration Management ISO 14971 - Medical Device Risk Management 3
K Example of ISO 10007 - Configuration Management Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A AS9100. 7.1.3 Configuration Management. PCB production. ECN. Revision Control. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Software Configuration Management Audit Questions Quality Assurance and Compliance Software Tools and Solutions 8
Q Configuration Management Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Wes Bucey Aerospace Configuration Management Webinar Book, Video, Blog and Web Site Reviews and Recommendations 3
Q Understanding Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
Q Configuration Management Form example(s) wanted Document Control Systems, Procedures, Forms and Templates 1
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Configuration Management System software that can also be linked to our ERP system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
G AATT Focus: Configuration Management & Risk Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9100 (FCA / PCA) of section 7.1.3 - Configuration Management - Audit question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Configuration Management and ISO 10007 (again) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K Configuration Management Procedure Template wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Configuration Management - AS9100 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
T Upgrading to AS9120A - Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B What is meant by "Configuration Management"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 36
O Difference between Configuration Management Procedure / Plan in IT context? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Who owns Configuration Management Document Control Systems, Procedures, Forms and Templates 6
C Configuration Management template or db wanted Document Control Systems, Procedures, Forms and Templates 2
B How to ensure Configuration Management and Control manually AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 Configuration Management Procedure example wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V Configuration Management - Configurable, Managed and Controlled Document Control Systems, Procedures, Forms and Templates 3
M Configuration Management - AS9100 Rev B or C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C Configuration Management requirements if this facility is not design responsible AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Configuration Management For Design and Development (Clause 7.1.3) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
S Is Configuration Management Mandatory? AS9100 Clause 7.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B Configuration Management - Is Configuration Management a requirement of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N The International Society of Configuration Management (ISCM) certification exam Professional Certifications and Degrees 2
A Configuration Management and On-Hand/In-Transit Inventory Quality Manager and Management Related Issues 3
L Definition Configuration Management - What is Configuration Management? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
J Configuration Management - ISO 9001 - 7.6 Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Configuration Management compliance - Adding information to individual procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
W Configuration Management for sub-contractors working to Customer Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C Compliance with AS9100 Configuration Management Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Configuration, Risk Analysis and Project Management in one procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K Configuration Management Basics - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
N Configuration Management Exemption? AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
