Configuration Management For Design and Development (Clause 7.1.3)
Tanahy
Hello everyone,
I am preparing for a transition Gap Analysis from AS9100 Rev. B to Rev. C. In the design and development section Clause 7.3 Quote"Design and development changes shall be controlled in accordance with the configuration management process" Unquote.
In my organization, we design some components that we get manufactured by outside contractors. How would you go on complying with this requirement in this case.
Thanks,
ddunn
I'm not sure I understand the nature of the problem.
The configuration management process applies to design and development and would be basically the same no matter where the product is manufactured. The only difference would be coordination of change implementation.
Tanahy
Thank you DDUN and Courey!
I think that flowing down the configuration management requirements to the supplier is what I was missing.
Thanks again,
Tanahy
K
kiwisfly
Hi Tanahy,
Both you and the supplier have Configuration Management responsibilities, you as the designer and the supplier as the manufacturer. You both use 'configuration documents'; the most obvious being specifications and drawings but models and NC programs are also relevant to the right configuration.
As the designer you have the responsibility to control the configuration of your design in a manner that ensures that the supplier receives the correct configuration documents. You want to ensure that two designers aren't working on the same component at the same time, for example. The manufacturer may have a suggested design change that you need to put through your review system for consideration and update.
Both these examples are processes that you might individually control under different names such as document control and engineering change request. However, they both contribute to the wider configuration management system you have in place as part of your aerospace quality management system.
I hope this helps.
Cheers,
Citizen Kane
You should have this by a common flow & official communication channel between you and your supplier. So you must both have configuration management. As tracking, you can have a common intranet solution between you and your supplier to monitor also your ECNs/ECRs (also needed a Change Responsible as a PM to trigger this) - if missing, this will come as an issue later.
C Configuration Management requirements if this facility is not design responsible AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
R Configuration Management - Identifying Documentation IEC 62304 - Medical Device Software Life Cycle Processes 3
H AS9100 D - 8.1.2 Configuration Management for Build-to-Print Service Provider AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
William55401 Distributed By Product - Best Practices for Configuration Management and Purchasing Controls ISO 13485:2016 - Medical Device Quality Management Systems 0
John Predmore Configuration Management as a process instead of a procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
G AS9100-8.1.2 Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Configuration Management in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
N Configuration Management - Physical Audit and Functional Audit for Software and Hardware General Auditing Discussions 4
T Change control and configuration management - When to create a new model/part number? Other Medical Device and Orthopedic Related Topics 0
P Configuration Management Software EASA and JAA Aviation Standards and Requirements 4
Q Configuration management clarification and example AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
A Risk Management and Configuration Management ISO 14971 - Medical Device Risk Management 3
K Example of ISO 10007 - Configuration Management Plan AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A AS9100. 7.1.3 Configuration Management. PCB production. ECN. Revision Control. AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
K Software Configuration Management Audit Questions Quality Assurance and Compliance Software Tools and Solutions 8
Q Configuration Management Audit AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
Wes Bucey Aerospace Configuration Management Webinar Book, Video, Blog and Web Site Reviews and Recommendations 3
Q Understanding Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
B How to define and implement Configuration Management Document Control Systems, Procedures, Forms and Templates 5
Q Configuration Management Form example(s) wanted Document Control Systems, Procedures, Forms and Templates 1
P Configuration Management for Build to Print Company AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L What exactly does Configuration Management in ISO 9001, Clause 7.5.3 means? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S Configuration Management System software that can also be linked to our ERP system AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
N Change Management, Configuration Management or Other Process? Manufacturing and Related Processes 9
G AATT Focus: Configuration Management & Risk Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B AS9100 (FCA / PCA) of section 7.1.3 - Configuration Management - Audit question AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Configuration Management and ISO 10007 (again) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K Configuration Management Procedure Template wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Configuration Management - AS9100 Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
T Upgrading to AS9120A - Configuration Management AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B What is meant by "Configuration Management"? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 36
O Difference between Configuration Management Procedure / Plan in IT context? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Who owns Configuration Management Document Control Systems, Procedures, Forms and Templates 6
C Configuration Management template or db wanted Document Control Systems, Procedures, Forms and Templates 2
B How to ensure Configuration Management and Control manually AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
D AS9100 Configuration Management Procedure example wanted AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
V Configuration Management - Configurable, Managed and Controlled Document Control Systems, Procedures, Forms and Templates 3
M Configuration Management - AS9100 Rev B or C AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
S Is Configuration Management Mandatory? AS9100 Clause 7.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
B Configuration Management - Is Configuration Management a requirement of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 21
N The International Society of Configuration Management (ISCM) certification exam Professional Certifications and Degrees 2
A Configuration Management and On-Hand/In-Transit Inventory Quality Manager and Management Related Issues 3
L Definition Configuration Management - What is Configuration Management? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
J Configuration Management - ISO 9001 - 7.6 Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
S Configuration Management compliance - Adding information to individual procedures AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
W Configuration Management for sub-contractors working to Customer Drawings AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
C Compliance with AS9100 Configuration Management Requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
K Configuration, Risk Analysis and Project Management in one procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
K Configuration Management Basics - AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
N Configuration Management Exemption? AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
