Conflict of Interest if I audit the QC department?
Armen
Hello All,
I appreciate your responses to my question. Recently, I have been promoted to be the QA manager of a small medical device company. I'll be responsible QC department as well. I'd like to know if it would be a conflict of interest if I audit the QC department since I am responsible for activities at this department.
Thank you
John C. Abnet
Teacher, sensei, kennari
Hello All,
Thank you
Good day @Armen ;
Short answer: No
Searching by key words on this forum will reveal a lot of discussion on this topic. ISO 9001 7.2 requires that "you" "...are competent ..."
ISO 9.2.2 c) specifies "select auditors and conduct audits to ensure objectivity and the impartiality of the audit process".
Do these things and demonstrate the effectiveness and you are fine.
Hope this helps.
Be well.
By the way @Armen...congratulations on the promotion !
John
John C. Abnet
Thanks John,
Speaking of effectiveness, how do you know your auditing process is effective?
I can give you some possible examples but I would be curious to know what you think would be...
evidence that the internal audits are determining the effectiveness of the management system and conformance to internal and international standard requirements.
Thoughts?
Armen
QAM is also responsible for internal auditing. Basically, I am auditing my own department, unless, I request the audit be done for example by validation department.
Thoughts?
I don't know the answer myself, yet one possible way could be developing post-audit checklist for auditors and auditee seeking to understand what went well during the audit, areas of improvement, lessons learned, etc.
mmasiddiqui
Thanks John,
You should find an effective way to tie your audit findings to the Quality KPIs.
If your audit score is really good but your scrap, rework data, First Pass Yield data tells a different story, then there is surely some gap in the way you are auditing or your scope of audit is wrong.
John C. Abnet
Good day @Armen, nothing wrong with that but not sure how that will show that the management system is effective and internal/external requirements have been met. In addition, every checksheet that is created and committed to will add an additional layer of effort and documentation that then needs sustained
Top management have ultimate responsibility for the effectiveness of the management system. (Top Management's job to assign the direction and resources to fix it...not the auditor's responsibility)
The internal audit is to simply provide information. (ISO 19011Guidelines for auditing management systems is NOT necessary for you to procure but you may find it helpful).
The results of audits are a required input into management reviews. If I were Top Management in your organization I would want to understand ..
* summaries of the type of nonconformances found
* what are the categories of repeat nonconformances if any.
* things gone right/things gone wrong (general summary) of the audit process
You can show evidence / examples of how audit non-conformance findings are being manifested into corrective actions and/or continual improvement.
One idea is to "tick"/identify the corrective action requests and/or the continuous improvement activities that were initiated as result of internal audit findings. Corrective actions should be reviewed for effectiveness. If resultant corrective actions and/ or continuous improvement activities, were effective, then your internal audits were obviously effective.
Don't overthink it.
Hope this helps.
Be well
Big Jim
Good day @Armen ;
Short answer: No
Hope this helps.
Be well.
I'm having a hard time understanding why so many seem to not realize that "auditors cannot audit their own work" was removed from ISO 9001:2015.
Is it possible that the writers had a reason for leaving it out?
The best guidance on this topic is probably contained in ISO 9002:2016. I suggest you read it. It provides an explanation about how to handle the "select auditors and conduct audits to ensure objectivity and the impartiality of the audit process" issues when a company determines they do need to let someone audit themselves. I suggest you read it.
I would also like to speak on the determination of objectivity and impartiality. It is my belief that it is up to the organization, not an auditor, to determine if someone can be objective and impartial. Factors likely would include the individuals character and integrity as well as company culture, topics that an outside auditor is not likely to be able to determine as well as the organization.
So the short answer would be more like: you should try to avoid it, but if necessary proceed cautiously to ensure objectivity and impartiality.
outdoorsNW
Since the OP has just been promoted, there is less potential for auditing their own work. Much to most of what will be audited is the predecessor's work.
The OP is not completely clear if this was an internal promotion from a subordinate role to manager or this was an outside hire. If this was an internal promotion, only work that the OP worked on previously has the potential to be a conflict.
If others performed the same tasks, focusing on the work of others can avoid any potential conflict. And I think the OPs prior work can be supporting evidence of things such as different interpretations of the same work instructions.
While many companies only have quality people as internal auditors, I think auditors from outside the quality department bring value both because they start with a better understanding of how some other areas work and they gain a better understanding of how a different part of the company works. We often try to assign auditors to audit areas that either create inputs to or handle outputs of the auditor's job.
J Conflict of Interest Registrar/Notified Body/Testing House Quality Manager and Management Related Issues 4
J Lead Auditor and Quality Manager - Conflict of Interest? Career and Occupation Discussions 4
S Conflict of Interest in Business Quality Manager and Management Related Issues 7
R Quality Manager Reporting to Director of Manufacturing - Conflict of Interest? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
T Internal Conflict of Interest in Managing Suppliers Supplier Quality Assurance and other Supplier Issues 2
C Can we choose to not allow auditor back on site? Conflict of Interest? Supplier Quality Assurance and other Supplier Issues 11
D Internal Auditing Resource Conflict of Interest Internal Auditing 8
M Quality Control Reporting to Manufacturing - Conflict of Interest Quality Manager and Management Related Issues 6
V ISO 9001 Consultant + Welding Inspector for Same Client - Conflict of interest? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Sidney Vianna Does The Cove aid in conflict of interest? Registrars and Notified Bodies 14
R Independent Auditor - Conflict of interest question Internal Auditing 19
H Can our QMS Consultant Perform Internal Audits on our behalf (Conflict of Interest)? Internal Auditing 69
D Waivers - Deviations - Responsibility -- Potential departmental conflict of interest? Manufacturing and Related Processes 6
Q Auditing Procedures we Authored - Conflict of Interest? Internal Auditing 17
A Does auditor have conflict of interest? Should we ask for different auditor? Registrars and Notified Bodies 12
B Dual Role Question - Metrologist AND Quality Manager - Conflict of Interest? Career and Occupation Discussions 14
CarolX Integrity lost? Conflict of Interest? ISO 9000 'Keepers' Profit from their books Philosophy, Gurus, Innovation and Evolution 42
Jerry Eldred Many Hats - Responsibilities Conflict of Interest General Measurement Device and Calibration Topics 4
Marc ISO Conflict of Interest - Duh... (This is New???) Registrars and Notified Bodies 5
T Conflict Mineral Regulations Reliability Analysis - Predictions, Testing and Standards 1
M Taking over Conflict Minerals responsibilities RoHS, REACH, ELV, IMDS and Restricted Substances 1
S Conflict Minerals - Tin Suppliers CMRT Miscellaneous Environmental Standards and EMS Related Discussions 13
F Conflict Mineral Smelter Question RoHS, REACH, ELV, IMDS and Restricted Substances 8
K EU MDR Rule 11 - Does the 'Risk logic' used in Rule 11 conflict with that used in the other rules? EU Medical Device Regulations 2
D How do I show compliance to RoHS, REACH and Conflict Minerals? REACH and RoHS Conversations 6
T Interview Question - Conflict between Production and Quality Career and Occupation Discussions 9
T When T&C's (Terms and Conditions) conflict with the ISO standard Manufacturing and Related Processes 8
Wes Bucey Conflict Resolution (without bloodshed) Misc. Quality Assurance and Business Systems Related Topics 1
S FDA and Customs Label Conflict Other US Medical Device Regulations 10
Q Conflict Management - Systemic way to manage conflicts within Teams Book, Video, Blog and Web Site Reviews and Recommendations 6
F Quality Manager - Conflict of interests in organisational structure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Law restrictions in each country [REACH, CONFLICT MINERALS, Canada Gazette] RoHS, REACH, ELV, IMDS and Restricted Substances 2
C How to handle this Inspection conflict? Second Shift Inspector? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
P EU Conflict Minerals Regulation Interpretation RoHS, REACH, ELV, IMDS and Restricted Substances 3
Q Conflict Minerals Reporting for Electronics Manufacturing AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
Q Conflict Minerals - A question on Scope RoHS, REACH, ELV, IMDS and Restricted Substances 3
B Conflict between department of MSA and Capability Study Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Conflict Minerals reporting template for PPAP approval APQP and PPAP 3
WCHorn AS9100 and Sampling - ANSI ASQ Z1.4 C=0 Conflict AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
M Conflict between TS 16949 clauses 7.1.4 and 7.5.1.1 IATF 16949 - Automotive Quality Systems Standard 9
K Key Employees and Officers - How much conflict is tolerable? Quality Manager and Management Related Issues 19
M ISO 14969 - Conflict in ISO 13485 - Measureable Objectives ISO 13485:2016 - Medical Device Quality Management Systems 4
R 5S Red Tag and ISO Procedure Red Tag - Tag Color Conflict Document Control Systems, Procedures, Forms and Templates 7
J Supplier Conflict Minerals Disclosure Information and Reporting Law RoHS, REACH, ELV, IMDS and Restricted Substances 58
S Is being the QMS Representative and a Union Member a conflict? Misc. Quality Assurance and Business Systems Related Topics 3
J Traceabilty Conflict? Existing Inventory AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
M IAF Technical Comittee meeting on AB/CB conflict General Measurement Device and Calibration Topics 3
W Conflict with External Auditor in ISO 9001- Number of Fire extinguishers General Auditing Discussions 48
E Conflict? 2 Technical Managers identified (one for EMC, one for Reliability) ISO17025 ISO 17025 related Discussions 8
ScottK Top QA Manager reporting to VP of Sales - Conflict? Career and Occupation Discussions 2
