N
nick1980
I want to calibrate a micrometer internally but I have some questions about resolution.
Resolution of:
Micrometer A: 0.001mm (that was calibrated externally proving it had only 0.0002mm difference from 0.001 nominal value)
Micrometer B: 0.001mm
If I use a master equipment to calibrate others, the master one should be at least 1/4 (1/10 best) more accurate than the under-test one.
For the above example, micrometer A was calibrated by a more accurate equipment externally. Micrometer A can be used to calibrate micrometer B in my sense.
However, both A & B have the same resolution,
1. Does it obey the 1/10 measurement ratio rule, even micrometer A was calibrated by a more accurate master externally?
2. Can I use micrometer A to calibrate micrometer B with same resolution?
3. Should I use a micrometer C with resolution 0.0001mm to calibrate micrometer B?
Resolution of:
