Confused: IEC 60601-1-2:YYYY and Required Compliance Dates
qu1nn
Reference Link
Is it me or is the setup (and notes) of the Office Journal for the harmonized standards falling under medical devices just plain confusing with regards to when conformity to a particular spec is REQUIRED?
Question 1) Is it still acceptable to have a product on the market (that was tested by a main test house in June 2007) which lists that the standard used for EMC was EN 60601-1-2:2001?
On another note:
From my understanding compliance with:
EN 60601-1-2:2007 and 60601-1:2006 will be required june 2012 (assuming all of the 61000 series can be updated)... is this correct?
Thanks for your time
qu1nn
Marcelo
Standards are voluntary, they are not "required".
Please see further discussions in this topic: http://elsmar.com/Forums/showthread.php?t=37925
Anyway, you can have a product which complies with an old version of a harmonised standard IF your risk management shows that all the risks are managed in the same level and thus you still comply with the essential requirements; in practice this is a little more difficult because notified bodies tend to rely on standards and standards revisions for control.
N
nikolaos
IEC / EN 60601-1-2:2007 describes the same test levels so there in no update test necessary, unless your risk management changes the essential performance criterions or the compliance levels, in this case retest is required.
qu1nn
Thanks for the responses. Sorry for the delay...
so basically i can still make use of the (2001) without physical retesting as it is at the same test levels, AND I can still make use of that date listed as a referenced in my Essential Requirements Report as long as I add a blurb stating the reasoning. The original essential requirements report made use (and references) the Risk Management 14971(2007) and was in full effect at the time of its writing.
Question 1:
With regards to the original question is the harmonized standard listing for the MDD confusing with regards to the presumed compliance dates or is it me?
Question 2:
SO what date did presumption of conformity for 60601-1-2(2001) end?
Question 3:
Am I correct that presumption for conformity for 60601-1-2(2007) and 60601-1:2006 will be required june 2012 (assuming all of the 61000 series can be updated)?
thanks for your time
qu1nn
Marcelo
1 - your original question was: "plain confusing with regards to when conformity to a particular spec is REQUIRED?". The point is, conformity is not required. I´m not sure if it was confusing because of that. Anyway, what is confusing is the date of cessation of presumption of conformity of the old standard..i think this is what you were talking about.
Tha date on the column "Date of cessation of presumption of conformity of superseded standard" is the date that any claim of compliance with the old version (this old veersion is the one appearing in the column Reference of superseded standard) was or will loose the effect of "presumption of conformity", which is a mechanism of the medical devices directives (and of the whole new approach directives) regarding the using of standards in regulations.
As mentioned in Note 1, generally this is the date of withdraw of the superseded standard, but not always.
Also, what might be confusing you is that the presumption of conformity date is related to the amendments. So, the 01/03/2009 date on EN 60601-1-2:2001/A1:2006 is the date that presumption of conformity with the standard, WITHOUT THE AMENDMENT, cessed.
2 - EN 60601-1-2:2001 + EN 60601-1-2:2001/A1:2006 have no cessation date yet, because the new edition does not have a date. Maybe the FAQ presented here could help in the understanding.
3 - Again, presumption of conformity is not required. You CAN use harmonized standards to CLAIM presumption of conformity if you wish, but you do not have to (although it surely is the easiest method).
Anyway, for the new general standard and new collaterals, June 2012 will be the date, but only after publication in the official journal, which did not happen yet. Also, this date will be set regardless of the update of the whole series. Again, please take a look at the FAQ.
B IEC 60601-1: EMC problems: Confused about 915MHz ISM band in Europe IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
T Confused by chapter numbering scheme in new standard (IEC EN-60601-2-37:2007) IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
D Software as risk control - Confused on one aspect of IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 20
WCHorn ISO/IEC 17025 Registrars - I'm confused about "accredited" registrars for ISO 17025 ISO 17025 related Discussions 18
D Essential performance, accompanying documents....confused IEC 60601 - Medical Electrical Equipment Safety Standards Series 4
E European Weld Callouts - Confused with the "/C" and the "a2" portions Various Other Specifications, Standards, and related Requirements 7
R Still confused on OPRP and CCP in an ISO 22000 Catering Business Food Safety - ISO 22000, HACCP (21 CFR 120) 3
S Pressure from Directors - confused! ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
R ISO 9001 Implementation in the Bus/Coach Industry - Confused and Help needed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Confused about Document Levels and Quality Manual ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Confused about application of ISO 13485 - Manufacturer of Medical Equipment & Device ISO 13485:2016 - Medical Device Quality Management Systems 14
T TS 16949 Process Audit Help - Confused Process Audits and Layered Process Audits 8
K So confused with AQL - How does AQL (Acceptable Quality Level) fit with my company AQL - Acceptable Quality Level 7
N ISO 9001 Implementation - I am still confused on where to start ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
J Certification Audit - Confused Newbie Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T Confused on Work Instruction Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Confused with 7.4 Purchasing - We provide a "service" which is our "product" ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Confused about Writing Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
B Gage R&R Spreadsheet Results - Confused as to what the results mean Inspection, Prints (Drawings), Testing, Sampling and Related Topics 28
S Confused: Accreditation / Certification? General Measurement Device and Calibration Topics 13
K An MR (Management Representative) who's as confused as he* Career and Occupation Discussions 14
M Confused about Control Plan and PFMEA Retention Period Document Control Systems, Procedures, Forms and Templates 2
K Developing a PFMEA - Confused about Potential Failure modes FMEA and Control Plans 7
H Confused over the notion of "offline (engineering) analysis" Statistical Analysis Tools, Techniques and SPC 3
I Confused on PPAP re-submission - Help on PSW (Part Submission Warrant) APQP and PPAP 3
C CAP for Medical Device Class Is product - Slightly confused - ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 3
A Confused - Medical Device Reports and Corrections/Removals 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
Wes Bucey FWIW: FDA confused? US Food and Drug Administration (FDA) 3
M Confused about measurement of software - Section 7.6 of ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M Predictive Maintenance - Confused about what can be considered predictive maintenance IATF 16949 - Automotive Quality Systems Standard 8
W Confused under what ISO 9001 clause would I place my Quality Process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Totally confused over changes to issue numbers - Quality & procedures manuals Document Control Systems, Procedures, Forms and Templates 12
J Confused about Calibration Tolerances of Plug Gauge, Ring Gauge & Snap Gauge General Measurement Device and Calibration Topics 4
S PPM vs. DPMO - Confused on how to use Six Sigma 2
A Still Confused About "Controlling Suppliers Records" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
Q Confused about the machine capability index Cmk Capability, Accuracy and Stability - Processes, Machines, etc. 1
C Confused with Regression Analysis - What about the P-value? Six Sigma 2
B I am confused, which Cmk value should I take and use? Statistical Analysis Tools, Techniques and SPC 6
N Confused by calibration concepts - Seeking help with the basics General Measurement Device and Calibration Topics 9
D Confused about registration scope - Engine accessories supplier IATF 16949 - Automotive Quality Systems Standard 3
K Level 1, Level 2 Very Confused ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Confused over product=service=transport Service Industry Specific Topics 2
S Confused about the TS 16949 Deadline - Presumably a Big 3 mandate? IATF 16949 - Automotive Quality Systems Standard 4
D Strategies for Going In Blind - My employer is probably confused why I'm here Misc. Quality Assurance and Business Systems Related Topics 11
W I'm confused about the term 'processes' in the revised (2000) ISO 9001 standard ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
Marc NIST Traceability Numbers - Confused Yet? General Measurement Device and Calibration Topics 5
E Test report to certify compliance with IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 1
B 3-phase supply, overvoltage catogory, line-to-neutral and working voltage (IEC 61010-1) IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
B European Harmonized vs IEC standard IEC 62366 - Medical Device Usability Engineering 2
