Confusion between national standard and API related standard.
lanley liao
Hi, Everyone,
I have two NCRs questions that i don`t know to deal with them better, which is as follows:
1.For the calculation letter for JJ315/44.5-K mast, the facility adopted steel wire by the size and type (Φ72 6x84WSNS+FC-1770) according to GB/T 20067-2006 as indicated in the DWG#C0.270.02.28.06 for wire rope assembly. However, API Spec 4F Section 8.1.3 specified that “The size and type of wire shall be as specified in API 9A and by API 9B.”
2.For design Verification Test Report # CBBG-130414 is available for Traveling Blocks and/or Hook Blocks # YG110, PSL 1, SN. TB13006-13008, the facility collected the calibrating certificate #Li-20200548-0817 for loading apparatus of “tubular force-measuring instrument” (Type: LTZ-30). However, the calibration was carried out as per JJG455-2000, not ASTM E4 as per the requirement of API 8C Section 5.6, i.e. “Calibrate the loading apparatus used to simulate the working load on the test unit in accordance with ASTM E4 so as to ensure that the prescribed test load is obtained”.
Thank you so much!
jmech
For anything done to an API product spec, you need to the requirements specified in the API product spec (i.e. wire per API 9A and 9B).
The corrections could include one or both of the below:
1. Verify that whatever you did meets the product spec requirements (if it does meet it - i.e. compare the wire properties and the requirements from API 9A/9B and compare the calibration report with the requirements in ASTM E4)
2. Revise your design with something that meets the product spec requirements (i.e. revise the wire rope assembly to use wires size and type of wire as specified in API 9A/9B and calibrate the force-measuring instrument per ASTM E4 prior to performing the design verification test again.)
Why didn't you ensure that you met the requirements specified in the API product spec? You need to answer this question to figure out the root causes and corrective actions.
lanley liao
Hi, Jmech, Thank you so much! The customer`s contract specified the size and type of wire rope that shall be performed as our national standards agreed, and we also have told that the requirements of API 9A and API 9B to the customer. but the customer still asks us to perform it according to national standards.
jmech
If you don't meet the API requirements, you are not allowed to API monogram it or claim it meets the API standard, regardless of what the customer wants. Did you monogram this product or claim that it met the API standard?
lanley liao
Hi, Jmech,We don`t have monogram this product or claim that it met the API standard and because we have been not received the order for two years.
jmech
If you don't monogram the product and don't claim that it meets the API standard (and there is no legal/customer/other applicable requirement for it to meet the API standard), then there is no requirement for it to meet the API standard.
However, this can be confusing during audits. You need to be very clear with the auditor that you are not claiming that this meets API 4F and there is no requirement for it to meet API 4F (or other applicable API standard), so the API 4F requirements do not apply.
If you are maintaining an API 4F monogram license, the auditor will likely want to see a design package that fully meets API 4F (including steel wire per API 9A/9B). If you don't have a design package that fully meets API 4F, then it is difficult (but maybe possible) to prove that you have the demonstrated capability to meet API 4F, which is what API requires for you to maintain the monogram license.
lanley liao
Hi,Jmech,Thanks! The auditor has checked our design package and found it meet the API 4F requirement.
This non-conformity is the customer's request to design and produce according to national standards, which is the case for this one product, while other types of products are designed and produced according to API 4F requirements. This product is a previously produced product. Our current API 4F certificate has been suspended this year, and we do not use the API monogram and claim to comply with the API 4F certificate.
jmech
There is no requirement for non-API 4F products to meet API 4F, so I recommend appealing this finding.
M Risk Analysis Flow - Confusion between ISO 14971 and IEC 62304 IEC 62304 - Medical Device Software Life Cycle Processes 8
thisby_ Confusion between Software Medical Device and Health Software to do a QM IEC 62304 - Medical Device Software Life Cycle Processes 5
B EMPB (Erstmusterprufbericht) VDA form confusion + PSW VDA Standards - Germany's Automotive Standards 4
S Some confusion about the creepage and clearance distance? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
S CE Mark - Classification Confusion EU Medical Device Regulations 12
A CE mark - Measuring Instruments Directive confusion! CE Marking (Conformité Européene) / CB Scheme 0
B Confusion on the new FMEA guidebook - Are we supposed to replace our FMEAs? IATF 16949 - Automotive Quality Systems Standard 3
Q Buy American Act - COTS confusion Manufacturing and Related Processes 7
M IAS (USA) Accreditation with IAF for ISO 13485 Logo Confusion EU Medical Device Regulations 10
K Design and Development Exemption/NA confusion Design and Development of Products and Processes 6
M Accept/Reject (Ac/Re) Numbers (ISO 2859-1) Confusion Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
supadrai Confusion on 510(k) Transfer Guidance - Device Listing 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
A Informational Confusion about Risks for Processes in ISO 9001:2015 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 44
I Gage R&R confusion on a part that has little variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
M "Single Patient Use" Terminology Confusion Other Medical Device Related Standards 9
M Health Canada Private Label Guidance Confusion - Quality System Required? Canada Medical Device Regulations 5
S Ionograph Testing - MIL-PRF-55110 Confusion AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
N Confusion within CE Mark and European Regulations CE Marking (Conformité Européene) / CB Scheme 5
C Clause 6.3 Infrastructure - Clearing the Confusion ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
T Acronym COP - Acronym Confusion Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 21
O Hazards vs. Hazardous Situation Confusion ISO 14971 - Medical Device Risk Management 11
S EN ISO 13485:2012 vs. ISO 13485:2003 - Confusion? ISO 13485:2016 - Medical Device Quality Management Systems 25
A Documentation Confusion - Agile BOM Structure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Defining what is a Medical Device Accessory and what isn't - Much Confusion EU Medical Device Regulations 8
T Product Realization Confusion - Manufacturer Specifications Aspects and Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B 510k exempt Class I Medical Device - Confusion during the facility registration US Food and Drug Administration (FDA) 3
D Confusion in writing a SIPOC (Supplier, Input, Process, Output, Customer) Six Sigma 5
S Confusion DPU, PPM & DPMO vs. Sigma Level - ASQ Six Sigma Black Belt hand book Six Sigma 14
Hershal Participation...........(Which Clause(s) cause you the most confusion or question?) General Measurement Device and Calibration Topics 6
P Confusion on declared (part of the quality manual) and non-declared documents Document Control Systems, Procedures, Forms and Templates 18
Marc Confusion Reigns As Analog TV Begins Shutdown After Work and Weekend Discussion Topics 2
Q Confusion over REACH Chemical List RoHS, REACH, ELV, IMDS and Restricted Substances 5
V How to use Sampling Plans - Confusion on Lot Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
I Six Sigma - Confusion while creating SIPOC diagram Six Sigma 6
G Health & Safety Executive - ISO 14001 and OHSAS 18001 Confusion Occupational Health & Safety Management Standards 6
T ISO/TS 16949:2002 Audit Confusion Internal Auditing 21
Manix WEEE and the confusion surrounding whether we fall into the scope of the directive! Other ISO and International Standards and European Regulations 9
Domoreto IATF Confusion - Our Registrar bought by another Registrar IATF 16949 - Automotive Quality Systems Standard 6
D Confusion regarding design responsibility - What can arguably be excluded? Design and Development of Products and Processes 10
R Confusion - Which tools are used and why on a daily basis? Quality Tools, Improvement and Analysis 3
M PPAP vs. Annual layout confusion - Customer "emergency PPAP" request APQP and PPAP 14
Randy Confusion and Castor Oil Coffee Break and Water Cooler Discussions 6
Manix Staging Process - Some confusion about what this stage actually is Manufacturing and Related Processes 10
S Control chart limit calculation confusion concerning SPC control limit calculation Statistical Analysis Tools, Techniques and SPC 30
F ISO 9001:2000 Confusion - Process Aspects: Interactions, Inputs, Outputs, Etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Clause 4.2.3 Confusion: Documents that predate the doc control procedure. Document Control Systems, Procedures, Forms and Templates 17
S Numbering Confusion - BS EN ISO 9001:2000 vs. Other national versions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
Q ISO Confusion - Do we comply and other questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
M Procedure for communication between authorized rep and distributor Other ISO and International Standards and European Regulations 0
J Impact Testing--Is conversion between Izod and Sharpy Possible? General Measurement Device and Calibration Topics 3
