Considering a Time Limit for Document Approval
Pancho
wikineer
#11
I am the document control coordinator for my company and I've had a lot of issues with documents being held up in pending status for too long. I've got one document that has been in pending status since October! When a document is rejected by any one approver the rejection response and document goes back to the originator, but we have nothing written about non-response. Of course, I email multiple reminders that documents are awaiting their approval, but that does nothing if the approver is unwilling to take decisive action.
I am considering a revision to our document control procedure that approvals or rejections shall be received within two weeks (or possibly longer if circumstances warrant). Documents that are not approved by all required approvers after that period shall be returned to the originator.
Then it will be the responsibility of the originator to meet with the other approvers to see what the hold-up was about, rather than me holding an archive of orphaned revisions.
Does anyone here have a process for handling non-responses or other recommendations?
Think about instituting default approvals.
You have knowledgeable folks editing the documents, right? They take the time to research an issue, talk to the parties affected by a change, and then edit a document, right? Chances are overwhelmingly high that the change is an improvement, right? If so, you could simply deem a change approved unless there is a specific reply from the designated reviewer within a short time period. Whoosh. Your documents will start to improve quickly.
To take it even further, you may want to empower, say, any of a process's participants to approve edits to that process's documents. Or, if you really want to get bold, empower everyone to edit anything in your system. With good version control (such as what you get with any wiki), this is not only practical, but desirable. Process owners should be charged with monitoring their documents, and, for the rare occasions when a change does prove misguided, reverse.
With empowerment comes ownership, responsibility, employee satisfaction and a rapidly improving system.
Good luck!
Pancho
P
PE-2011
#12
Absolutely, company's management culture needs improvement.
I feel, your polite approach to get it done personally, can only improve the situation slowely. Maheswari
K
Ka Pilo
#13
Re: Considering a time limit for approval
In your document control procedure you can say that failure to respond with a given amount of time will be interpreted as approval.
Stating that in your document control procedure won't address the issue of delays on approval.
ISO 9001 4.2.3.a) and b) says ...
define the controls needed to approve documents for adequacy prior to issue,
define the controls needed to review and update as necessary and re-approve documents,
If the approved documents would carry respond within a period of time, non-response indicates that the document is not approved. Why document controller be bothered not to issue unapproved document?
JaneB
#14
We had that issue also, mainly with the program managers. We tried lots of things but now if someone at our company revises a document and the document effects other departments a document review board (DRB) is scheduled. The stake holders of the effecetd areas are sent copies of the revised document and invited to the DRB. It is stated that if the invited person cannot attend then a representative should be sent. We have in our procedure that if you are invited to the DRB and choose not to attend and do not send a representative or coordinate someway with doc. control the people who do attend review/decide/approve/disapprove and thats it. After a couple of things were posted it got attention and we now have very good attendence and input.
That sounds like an intelligent and pragmatic approach. Which is working well for you:yes:.
JaneB
#15
Err... I don't actually understand at all what you are saying here.
I believe Jim's idea was simply one possible suggestion, though you are right that it might not address the issue of delays. But as an idea, it's quite acceptable and definitely not contradicted by any of ISO 9001, if you are saying that.
K
keres
#16
I'll suggest you the opposite. Try with silent agreement. If there is not a rejection in duration of 2 weeks the document is approved.
K
Ka Pilo
#17
Right, that's what I mean. Jim's suggestion conforms to ISO 9001 as far as control of document is concerned. My concern is that it doesn't address the issue of delays which is main concern of the OP in this instance.
Solinas
#18
I worked at a company which had a widespread problem with getting documents reviewed and approved.
The CEO made a mandate:
1) You have 3 days to review and approve or reject.
2) If 3 days pass, and you haven't acted, then you have approved the document.
3) Anyone who has a document approved by 3 days of non-response, and it later turns out to cause a problem, will be fired.
Brutal, but it worked.
Your solution of returning back to the originator, in my opinion, doesn't put the pressure where it belongs. Whatever you do should squeeze the people who are causing the long pending times, not the originator.
AliInMo
#19
Wow...that is brutal! :whip:
But good to work in a company where the CEO would support the QMS so strongly I would think.
V
vpandora
#20
No, you are quite right that it doesn't address the delay at all. However, sending the document back to the originator saying that it was rejected by default serves as notice that something is not working and they need to discuss with the other approvers how to correct it.
The alternative is that a document languishes in "pending" status until everyone forgets about it. When someone does notice a problem later down the road, they either ask me what happened to the revision they sent me, or they make another revision (which will not get approved either).
S Quality manager considering data science Quality Manager and Management Related Issues 19
SKM.Sunil Clinical Investigation considering MDR 2020 EU Medical Device Regulations 2
qualprod Calculate number of people in processes, considering cycle time/takt time = quantity of people Lean in Manufacturing and Service Industries 9
H CER - Considering similar device/other medical devices for as relevant literature CE Marking (Conformité Européene) / CB Scheme 4
O EMC testing per IEC 60601-1-2 for considering new cables CE Marking (Conformité Européene) / CB Scheme 1
D Our company is considering generating a QMS Process to IATF 16949 IATF 16949 - Automotive Quality Systems Standard 1
M How to Measure Paper considering Variation and Humidity General Measurement Device and Calibration Topics 10
R Considering adding ISO 13485 certification - Your thoughts? ISO 13485:2016 - Medical Device Quality Management Systems 4
H Iso in a box - Considering becoming a franchise for them ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
S I am considering an online Black Belt Certification Six Sigma 19
bobdoering Saturn alerts customers it is considering a spinoff World News 1
Marc GM Considering filing Chapter 11 Bankruptcy - 090216 World News 33
H Best ERP, MRP Application, considering Quality? Manufacturing and Related Processes 22
I Considering Mental Condition Related to Ill Health in Risk Assessment Occupational Health & Safety Management Standards 5
L Certificate Retrieval System [CRS] - Considering the purchase of a software package Quality Assurance and Compliance Software Tools and Solutions 8
P Considering Career in Auditing with focus on Social Responsibility Career and Occupation Discussions 23
P Is anyone out there considering using a Third-Party for their FDA Audit? US Food and Drug Administration (FDA) 7
T Control of Forms - Considering removing forms from our procedures Document Control Systems, Procedures, Forms and Templates 7
S Labels identifying accredited standards - Considering making labels with A2LA Logo General Measurement Device and Calibration Topics 4
Q Considering consulting - What do I need? Consultants and Consulting 17
K Radius with specification only Max limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Setting accuracy limit for a read out General Measurement Device and Calibration Topics 4
S Heat Sealers Upper and lower limit setting during OQ for Heat Sealer Qualification and Validation (including 21 CFR Part 11) 0
T The “use-by“ time limit - Terminology discrepancy - MEDDEV & HS EU Medical Device Regulations 0
M Proper way to develop LCL when only given a lower spec limit Reliability Analysis - Predictions, Testing and Standards 7
B Narrow limit gauging Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
shimonv Symbol for temperature limit EU Medical Device Regulations 6
H How to control when control limit is out of Specs limit Statistical Analysis Tools, Techniques and SPC 11
K Small Sample - Lower Limit Probability Statistical Analysis Tools, Techniques and SPC 0
J0anne 90 Day Limit Imposed by NB to complete NCs raised at audit Preventive Action and Continuous Improvement 6
I Cleanroom Actions in case of Actions Limit Alarm Qualification and Validation (including 21 CFR Part 11) 3
S Minitab limit definition from R & R Using Minitab Software 4
L P-Chart Control Limit Calculation help Statistical Analysis Tools, Techniques and SPC 1
Q US FDA Standard Limit for Swab Test Microbial and ATP Other US Medical Device Regulations 1
R How to calculate UCL (Upper COntrol Limit) and LCL (Lower Control Limit) Statistical Analysis Tools, Techniques and SPC 5
R Fixing of tolerance limit - Electronic weighing balance with the capacity of 150 Kgs General Measurement Device and Calibration Topics 5
N More Central Limit Theorem Questions Six Sigma 4
P No-go Ring Over the specifiaction limit Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
J Maximal limit of Aluminum in Polymer Medical Device Implants (EU) Other Medical Device and Orthopedic Related Topics 1
V Are microbial limit tests required for sterile products? Qualification and Validation (including 21 CFR Part 11) 3
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
A 61010-1 Accessible Parts - Limit Values and Crepage and Air Clearance Distances Other Medical Device Related Standards 1
B What is the safe Temperature Limit for Medical Device with blood contact ? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
M Specific Capability case - Target Value is same as the Lower Limit Capability, Accuracy and Stability - Processes, Machines, etc. 9
A CQE exam primer Control Limit question Statistical Analysis Tools, Techniques and SPC 2
S SPC Control Limit Calculation Statistical Analysis Tools, Techniques and SPC 2
J Exceeding the DC Leakage Current Limit IEC 60601 - Medical Electrical Equipment Safety Standards Series 8
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
A MSA (Measurement System Analysis) for Characteristics with One Tolerance Limit Capability, Accuracy and Stability - Processes, Machines, etc. 10
