Consolidating results of LPA (Layered Process Audit) for Management Review
Celtic Warrior
I am currently defining an LPA process for my site. I have overcome many of the challenges so far with the information and experiences shared in this forum, however the one topic I am still unsure about is the consolidation of results for management review.:confused:
I believe I have the case won with the manufacturing guys to actually undertake the LPA, as they can see the potential benefits of 'fast feedback' checks. The case for consolidating the results for management review is a whole other story!
I would be grateful of any experiences in this area that anyone could share..... Thanks
CW
Jen Kirley
Quality and Auditing Expert
Re: Consolidating results of LPA for Management Review
CW
Good day Celtic Warrior, please forgive me but I am drawing a blank on the meaning of LPA process. Can you please define this acronym?
LPA means Layered Process Audits.
It is structured such that supervisors audit certain items daily, managers audit items weekly up to the plant manager who audits items monthly.
Celtic Warrior
Thanks Miner for the explanation.
The one area of this process I am looking for some help with is the consolidation of layered process audit results. This is so the efficiency and effectiveness of the overall process can be evaluated and proposals made for improvment in the management review.
This is a requirement of my certification as LPA is one part of my internal audit (system, process, product, LPA).
I am particularly interested in audit result and NC reporting as this would form the basis for identifying repeating deviations or where layered process audits are not identifying deviations where the process is unstable or producing defects that are not being either prevented or identified early.
I want to develop some better process metrics than for example audits completed to schedule. Whilst this is useful to assure process completion it does not give any indication of the effectiveness of the LPA in identifying manufacturing process weaknesses. So I am looking for metrics that can truly monitor the LPA process and its use as a tool to drive improvement.
CW
We are attempting to implement a LPA process. The CQI-8 guide is very helpful, but there are still some things that need clarified.
As I understand, the LPA is not an audit of the entire process but focuses only on the critical points in a process.
Do I understand correctly? Does anyone have an example of an LPA?
Thank You,
tori2432
We have a simple form and I have used the same at other automotive manuf plants. Very simple form, on one side there are questions about Safety, Process Documents, Job Specific and Other. There is a column next to it to place a check mark for OK, a circle for finding and an X for finding.
Regarding some of the questions: Is employee wearing proper Personel Protective Equip?
Does employee know where closest fire extinguisher, first aid station and tornado shelter are?
Is the Job card complete?
Are tools Calibrated?
Then I have a log sheet to track the corrective actions that need to be addressed and when they are completed.
I have a chart that shows how many are done in a month, how many findings and how many were not done (accountability is always an issue getting management to go out on the floor to complete them!)
Chance
CW
Celtic Warrior, how do you consolidate your results for Management Review? I am interested and want to know so I can implement this in my company.
V
vinny
CW
The system we use to bring LPA results to Management review is two fold. First all LPAs for the month are copied to the department admin who talies number of audits and number of findings and issue identified. Those results are forwarded to QA who puts together a summary chart for the monthly management KPI review (Ford QOS process). Summary chart includes plant wide number of LPAs, and % findings by area. There is a pareto for findings by cause and department. Specific LPA finding action plans are assigned and reviewed with each department and audited by the internal auditor. Any shortcomings would result in a finding for the QMS management review and an action plan assigned thru it. Hope this helps
qusys
CW
This quality tool is useful together with the other types of internal audit.
Automotive customers usually ask for this.
Here is a link of a searc done in the post attachment list:
http://elsmar.com/Forums/fileslist....name&pageamt=1&criteria=layered+process+audit
You could report the result grouping for most common clauses violeted according to the ISO TS standard and put in place action to reduce them over the time:bigwave:
JaxQC
I would suggest reporting both number of non-conformances (audit findings) and well as repeat issues. Break it out by layer. It’s no good if the 1st layer group leader finds none, 2nd layer supervisor finds 10, and 3rd layer quality finds 50. Should be the other way around.
The core items should be the same all the time but you can get great benefits from having a dynamic one. Add and remove as needed. New check based on Customer return, failed calibration or higher scrap seen on a particular machine, checks specific to a particular process/line that is different than others, verification period for a new control or machine repair. As the verification period passes…the checks can drop off or go to reduced control.
Marc Consolidating Inter-Plant Documentation Document Control Systems, Procedures, Forms and Templates 0
lanley liao How to understand this words that the planning of internal audit shall take into consideration the results of previous audits? Oil and Gas Industry Standards and Regulations 10
Nihls When the MSA results show no operator influence Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
Q IATF audit - Root Cause Analysis results IATF 16949 - Automotive Quality Systems Standard 5
P Ppk results shown as asterisk after the transformation of Non-normal data Using Minitab Software 4
S Documenting Design Verification Test Results (ISO 9001) Design and Development of Products and Processes 1
A MSA results differences - Supplier results vs. My results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J Audit Finding For Not Retaining Test Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
F ISO 17025:2017 Clause 7.7 Ensuring the validity of results - Threshold ISO 17025 related Discussions 9
P AS9102 Form 3 Dimension Results Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
H Graphical analysis of results - Confidence level bands nomenclature Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
G What information to put on measurement Dimensional Results APQP and PPAP 7
A Calibration Certificate Results General Measurement Device and Calibration Topics 3
F Measurement Audit and ILC for ISO 17025 Clause 7.7.2 - Comparison with results of other laboratories ISO 17025 related Discussions 0
KCalaba21 ISO 9001:2015 6.2.2 E - "e) how the results will be evaluated." ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
shimonv Referring to previously submitted biocompatibility results in a new 510(k) submission Other US Medical Device Regulations 1
J ISO 17025 - Please share a sample procedure for monitoring the validity of results ISO 17025 related Discussions 1
A Acceptance p-value for linearity and bias analysis in minitab results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
Marc European universities dismal at reporting results of clinical trials - 2019 Other Medical Device Regulations World-Wide 0
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
V Recording CMM dimensional results on CFG-1003 APQP and PPAP 3
Prashant G AS9100 Requirement - Verification of characteristics results with drawing requirements AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A Supplier Audit Results - when do you prepare? General Auditing Discussions 10
U ISO 17025:2017 Clause 7.7 Ensuring the Validity of Calibration Results ISO 17025 related Discussions 6
M FDA News FDA Safety communication – Interim Results of Duodenoscope Reprocessing Studies Conducted in Real-World Settings Medical Device and FDA Regulations and Standards News 0
A Definition Intended Results - What does "Intended Results" mean? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
G ISO 9001:2015 - Management Review 9.3.2 c) 5) - Monitoring and Measurement Results ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
R Tensile Test Strain Rate - Impact on the Test Results Manufacturing and Related Processes 3
K Taguchi Experiments for Factorial Design Analysis - Reliability of Minitab Results Using Minitab Software 1
B How to interpret Grindometer Gage R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
J What results need to be defined in IATF 16949 Clause 8.3.4 IATF 16949 - Automotive Quality Systems Standard 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W MR Inputs (9.3.2) - "Monitoring and Measurement Results" vs. "Process Performance" Management Review Meetings and related Processes 8
S Is it mandatory to provide the results of the validation report in handwriting? ISO 13485:2016 - Medical Device Quality Management Systems 5
Ajit Basrur CDRH Customer Satisfaction Results at 87% US Food and Drug Administration (FDA) 1
T Results from conducting a Capability Studies Statistical Analysis Tools, Techniques and SPC 4
V CMQ/OE exam results - March 7 2015 Professional Certifications and Degrees 10
W Results of the ASQ CSSBB Exam March 07 2015 Professional Certifications and Degrees 62
T OES Global Results Drift Quality Manager and Management Related Issues 1
Ron Rompen Quick question on results of Student-t test Statistical Analysis Tools, Techniques and SPC 7
G Interpreting Type 1 MSA (Measurement Systems Analysis) Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
L Release of Audit Results Report to 3rd Party ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
M ANOVA for S/N ratio gives different results Statistical Analysis Tools, Techniques and SPC 5
V Analysing Results after DOE Using Minitab Software 1
B Tolerance Calculator Based on R&R Results Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
C How to handle Action Results in a new FMEA Review once we have a new RPN? FMEA and Control Plans 1
V Analysis of DOE Results and Model Finalization Using Minitab Software 4
B MSA (Measurement System Analysis) - Results and Actions Taken Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
