Constant for a M3x.35 Set Plug using the "Three-Wire Method"
  • Thread starter TED KNICKERBOCKER
  • Start date
TED KNICKERBOCKER
Hello everyone, can some1 provide the Constant I would use for a M3x.35 Set plug using the "three-wire method"..Thanks to all.:cool:
TED KNICKERBOCKER
RE:Answer M3x.35 Set Plug
OK, for those who have read this thread, I have found the Constant by the simple breakdown of a few #'s. The Constant you would use to Calibrate this particular setplug is: .012031"..Any input or questions are welcome. Thanks to all for viewing.
DietCokeofEvil
You can't calculate the constant unless you know the average wire diameter of the wires being used to measure the gage. How did you come up with that number?
J Unbiasing Constant "d4" formula Statistical Analysis Tools, Techniques and SPC 4
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
3 K1 K2 K3 constant of Gage R&R - Please advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Macro Question: Get Column Name by Column Number / or Use Text constant to link on a Using Minitab Software 1
B Searching for the Best Smoothing Constant using a Grid Search Using Minitab Software 2
B Calculation of c4 unbiasing constant - Capability results from Minitab in MS Excel Statistical Analysis Tools, Techniques and SPC 25
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
F Calculation of Failure - Constant Failure Rates of Parallel System Reliability Analysis - Predictions, Testing and Standards 11
T Control Chart to use when Sample Size is Constant Statistical Analysis Tools, Techniques and SPC 4
J Evaluating a Regression Model Using the Constant Variance Assumption Six Sigma 8
O MSA Guidelines Appendix C - Value constant K3, which depends upon the number of parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M Constant for thread gage calibration with the three wire system General Measurement Device and Calibration Topics 7
D Understanding ANSI Z1.9 Origin and the Acceptability Constant (k) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Formula for I Control Chart Limits - Different values for E2 constant of IMR? Statistical Analysis Tools, Techniques and SPC 5
M D4 constant 2.58 vs. 2.57 - MSA III manual vs. SPC II manual differences Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M X bar R Charts - d2 constant, "g" and "m" definitions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N Repeatability Variation and Constant d2* - What is d2* and how is it calculated? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Calculating Savings from Standard Deviation when Mean remains constant and SD changes Statistical Analysis Tools, Techniques and SPC 4
N Is alpha in UCI LCI formula constant or depend on sample size? (MSA Manual) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Gage R&R K1 constant - Changing of the constant affect the gage study result? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Measurement Brain Teaser - What constant is the basis for the meter? General Measurement Device and Calibration Topics 16
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
P Best european location to set up for a virtual medical device manufacturer? EU Medical Device Regulations 4
S Is QMS like a set of rules and regulations that a company follows? ISO 13485:2016 - Medical Device Quality Management Systems 10
W Regarding Requirement for Hi pot & Leakage Current test Station Set-up IEC 60601 - Medical Electrical Equipment Safety Standards Series 6
G CE marking of MD and IVD set EU Medical Device Regulations 3
J How to Set Microbial Limits in Food Supplements Food Safety - ISO 22000, HACCP (21 CFR 120) 3
qualprod To set frequency to review documents in ISO 9001 7.5? Document Control Systems, Procedures, Forms and Templates 13
M IATF 16949 8.5.1.3 Verification of job set-ups - Do we need secondary check? IATF 16949 - Automotive Quality Systems Standard 7
B Set RH spec from dewpoint spec General Measurement Device and Calibration Topics 2
S Is Optical Parallel Set required calibration? ISO 17025 related Discussions 1
R Gauge R&R on pre-set torque wrench Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
N Internal Audit Schedule – Who gets to set the schedule? Internal Auditing 16
G Comparing Gauge Blocks - Translating the calibration between the master set and the QA set General Measurement Device and Calibration Topics 2
L How to evaluate the process capability of a data set that is non-normal (cannot be transformed and does not fit any known distribution)? Capability, Accuracy and Stability - Processes, Machines, etc. 12
N When to record values if a spec for a mfg process is set Manufacturing and Related Processes 3
Marc Time Zone - Set your Time Zone Elsmar Xenforo Forum Software Instructions and Help 1
D As a newcomer to QMS, I really appreciate how ISO is set up. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C IATF 16949 Cl 8.5.1.3 - Verification of job set up IATF 16949 - Automotive Quality Systems Standard 4
D How to set equipment calibration/verification criteria General Measurement Device and Calibration Topics 1
S GRR on ID with set of pin gauges Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4
G What to Check - Set Up vs. In Process Inspections Inspection, Prints (Drawings), Testing, Sampling and Related Topics 6
N The known set of all root causes Nonconformance and Corrective Action 11
G What degrees of freedom means in uncertainty budget and how do I set the value Measurement Uncertainty (MU) 2
D What is the exact Temperature Coefficient Value to be set on a Conductivity Meter? General Measurement Device and Calibration Topics 2
G Training Employees about Quality - Philosophy / Mind set Misc. Quality Assurance and Business Systems Related Topics 1
renenatasha MDD Classification for Pressure Monitoring Set CE Marking (Conformité Européene) / CB Scheme 1
U Are all manufacturers required to set up eMDR system? Other US Medical Device Regulations 4
S Gage Block Verification or buy a new set (cost aspect) General Measurement Device and Calibration Topics 1
