Constant for thread gage calibration with the three wire system
Milorey
Hi to all, Im new in this forum,
i need your help, Im calibrating an thread gages with the three wire system,
but i havent the constant for Pitchs:-27, -11.5, -8, I need it,
i have only for -18(0.04814) and -14(.06186).
Thanks in advance for your help
stefanhg
Hi Milorey,
For precise calculation of the pitch diameter of threads when measuring with wires or balls you need to specify:
- pitch
- number of starts
- flank angles
- measuring force
You can use the freeware QMSYS Thread – PD.
The program QMSys THREAD-PD enables the user to determine the pitch diameter of threads when the indicated values are specified as well as to determine the indicated values when the pitch diameter is specified. It is suitable practically for all types of threads:
- external and internal
- symmetrical and asymmetrical
- single-start and multiple
Indicated values and pitch diameters are determined using measuring wires or balls by Berndt’s iteration formula from the publication EA - 10/10 "Guidelines on the Determination of Pitch Diameter of Parallel Thread Gauges by Mechanical Probing" – the most precise method.
Download-link:http://www.qsyst.com/html/software_en.htm
Milorey
Hi Stefanhg, thanks for your help,
in my work I cant open some web pages, unfortunely i cant open your link,
look, i need calibrate a plug gages NPT from 1 1/16 -27NPT to 3 -8NPT,
I only need measure the pitch diameter and L1, we will have an audit nearly and I want to have in orden my system.
Do you know the constant than I am searching (-27, -11.5, -8)?
thanks.
stefanhg
Threads; Pitch ; Best wire size ; Constant
27 ; .037037 ; .02138 ; .032075
11,5 ; .086957 ; .05020 ; .075307
8 ; .125000 ; .07217 ; .108253
Wayne
Gage Crib Worldwide
... I need calibrate a plug gages NPT from 1 1/16 -27NPT to 3 -8NPT. I only need measure the pitch diameter and L1,...
Hi Milorey;
I see you are calibrating NPT. Measuring the pitch diameter using thread wires. Do you have a sine block?
If not, how are you compensating for the thread taper in the pitch diameter measurement?
Milorey
Wayne, we have 50 gages NPT, and I need calibrate it, I never do calibrated NPT, I was searching how calibrate it, due a my short time, I think than only need measure the pitch diameter and the L1, I read than the tolerance for these plug gages is ± half turn, then the pitch diameter should be on this turn, whether I am wrong please help me, thanks.
Wayne
Gage Crib Worldwide
Milorey;
Calibrating NPT by using thread wires is a tricky process because of the taper of the thread. There is a special calibration block which is needed. It is not an on-the-shelf item and will take weeks to have manufactured. This method is best left to professionals.
The easiest way to calibrate NPT in a manufacturing plant is to use qualified master gages. Remember to send your master gages to a calibration laboratory for verification on a regular basis.
Getting NPT masters is not a quick proposition; it takes weeks, but in the long run it will be the most simple way for you to maintain calibration of your NPT gages.
In the short run I suggest that you send your NPT gages to a local calibration laboratory.
In the long run, because you have so many NPT gages, I suggest that you purchase the master gages.
DietCokeofEvil
Chiming in late on this one.
You cannot provide a constant without knowing what the OP's actual wire diameter is. These are the nominal constants for the best wire size, not the constants the OP should be using.
J Unbiasing Constant "d4" formula Statistical Analysis Tools, Techniques and SPC 4
V How to Calculate Unbiasing Constant C4 Statistical Analysis Tools, Techniques and SPC 1
3 K1 K2 K3 constant of Gage R&R - Please advice Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
J Macro Question: Get Column Name by Column Number / or Use Text constant to link on a Using Minitab Software 1
B Searching for the Best Smoothing Constant using a Grid Search Using Minitab Software 2
B Calculation of c4 unbiasing constant - Capability results from Minitab in MS Excel Statistical Analysis Tools, Techniques and SPC 25
T Constant for a M3x.35 Set Plug using the "Three-Wire Method" Calibration and Metrology Software and Hardware 2
F Reliability of a System - Estimation of R(t) having constant failure rate "Lambda" Reliability Analysis - Predictions, Testing and Standards 2
F Calculation of Failure - Constant Failure Rates of Parallel System Reliability Analysis - Predictions, Testing and Standards 11
T Control Chart to use when Sample Size is Constant Statistical Analysis Tools, Techniques and SPC 4
J Evaluating a Regression Model Using the Constant Variance Assumption Six Sigma 8
O MSA Guidelines Appendix C - Value constant K3, which depends upon the number of parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
D Understanding ANSI Z1.9 Origin and the Acceptability Constant (k) Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
A Formula for I Control Chart Limits - Different values for E2 constant of IMR? Statistical Analysis Tools, Techniques and SPC 5
M D4 constant 2.58 vs. 2.57 - MSA III manual vs. SPC II manual differences Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
M X bar R Charts - d2 constant, "g" and "m" definitions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
N Repeatability Variation and Constant d2* - What is d2* and how is it calculated? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
C Calculating Savings from Standard Deviation when Mean remains constant and SD changes Statistical Analysis Tools, Techniques and SPC 4
N Is alpha in UCI LCI formula constant or depend on sample size? (MSA Manual) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
M Gage R&R K1 constant - Changing of the constant affect the gage study result? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
A Measurement Brain Teaser - What constant is the basis for the meter? General Measurement Device and Calibration Topics 16
D Number of Distinct Data Categories:nDC: Where does the constant 1.41 come from? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
D Accurately measuring Full Thread Length Inspection, Prints (Drawings), Testing, Sampling and Related Topics 11
DuncanGibbons Additive Manufacturing Processes Thread Manufacturing and Related Processes 5
C Aluminum galling on thread plug gauge Manufacturing and Related Processes 10
ScottK Measuring thread flank angle on a screw Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
G Oversized Threads - What sized stab pin would be best to quickly check for oversized thread holes General Measurement Device and Calibration Topics 5
H Thread Plug Gauge Tolerances General Measurement Device and Calibration Topics 3
A Cost effective thread gaging with ISO 9001 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
APHX02 Thread Roll Process Verification w/in AS9100 (i.e. BSP-F-69/AS8879) Manufacturing and Related Processes 2
C Thread Tolerance - Can I use a 3A Ring on a part that the drawing calls out for a 2A? Manufacturing and Related Processes 5
M Error trying to Start a New Thread Elsmar Cove Forum Suggestions, Complaints, Problems and Bug Reports 2
M NPT thread gauging and the "rapping" process Manufacturing and Related Processes 1
Marc Basic - How to Start a New Discussion Thread Elsmar Xenforo Forum Software Instructions and Help 1
S What the difference is between Stub Acme & Acme thread? Oil and Gas Industry Standards and Regulations 1
Marc Printable Discussion Thread View Elsmar Xenforo Forum Software Instructions and Help 0
S Thread Ring Gauge verification General Measurement Device and Calibration Topics 6
O Thread Diameter as a Datum Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
O ISO 9001:2015 Transition Internal Audit completion thread ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
R Thread plug chip groove - Thread plugs without the chip groove General Measurement Device and Calibration Topics 0
S Unique ID Required for Thread Gage Replacements? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Calibration of Thread Plugs and Ring Gages - Various Thread Standards General Measurement Device and Calibration Topics 3
P Thread recommendation for Cast Iron part Manufacturing and Related Processes 1
K Thread callout - M22 x 1.0-6H 0.100R Thread Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
4 In-House Thread Wire Calibration General Measurement Device and Calibration Topics 5
C Manufacturing Thread Ring Gages Manufacturing and Related Processes 3
E External Thread Cosmetic/Appearance Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Thread Gage Training? Training - Internal, External, Online and Distance Learning 3
C Measuring Solid Thread Ring Gages General Measurement Device and Calibration Topics 17
