Contactless Hospital Bed Sensor Certification
maxishev
Hello all!
We are working on bed sensor that can be put at the bottom side of the bed and that able to measure heart rate, respiration rate and some other parameters of patient who is lying on the bed. There are no any contact between sensor and patient/operator. The sensor itself work from 5V DC that it get at his input. The 5V produced from external power supply of 220V that we ordered and that have simple certification of CE. The sensor also have battery for back-up when grid is no available, that can be recharged from input 5V supply. The measured data transferred from the sensor to Mobile phone/tablet via BLE or to special data server via Wi-Fi wireless connection.
Now we want to make to this sensor IEC 60601 certification.
Is it possible to make IEC 60601 certification for sensor that I described above? Although the sensor no have straight contact to patient/operator - at some point the contact can be possible - for example patient fall at floor and somehow touch the sensor at bottom of bed. So according to subclause 3.8 it can be defined as APPLIED PART and need to make all the tests that need to be done to APPLIED PART. Our sensor don't have metal parts at it packing. The problem is that at our sensor we don't have earth pin. The sensor receive only 2 pins - 5V and GND and earth pin may be available only at power supply - the part that we buy and that need to make certification itself. Is the power supply must be earthed? As the sensor itself receive only 2 pins - 5V and GND.
But anyway I am a little confused what tests we should to do? We maybe need to make IEC 60601 certification to power supply and sensor together as one product. Or find suitable power supply with all needed certifications and only need to do certification tests to sensor itself. And what are those tests? Except some tests like short-circuit of 5V and GND and see if this no cause hazard situations. Are we need to do hort-circuit to all components at our board to check is it no make hazard situations? To charger, to booster DC-DC converter, to buck DC-DC converter? Also we need to make thermal and humidity tests as described at the document. Also need to make radio safety tests. What else?
Thank you in advance for your response
Peter Selvey
Under Clause 3.8 it is only parts that must (necessarily) contact the patient which make applied parts.
There is a separate clause 4.6 which deals with parts that could contact the patient, but your case would struggle to fit in there as well (it is really intended for parts like cables of a sensor that are not applied parts but could reasonable contact the patient in normal use).
So, strictly your device does not fall under IEC 60601-1. But, you could use the standard for reference (there are still many reasonable requirements e.g. essential performance, waterproofing etc), but there would be no applied part, MOPP etc.
If you want certification, you would have to negotiate with your test agency first. Often they allow out-of-scope application for IEC 60601-1 because it is seen as a more strict standard, but you need to check first.
maxishev
Thank you!
Yes, we are already at process with test agency about our product.
M It is Possible to apply a wall plug power adapter to provide power from the actuators of a dialysis chair or hospital bed? IEC 60601 - Medical Electrical Equipment Safety Standards Series 1
E Does IVD need to integrate with hospital IT infrastructure? Medical Information Technology, Medical Software and Health Informatics 2
P MedWatch Report from a hospital due to a quality issue US Food and Drug Administration (FDA) 5
F Hospital Rebrand & Name changes Document Control Systems, Procedures, Forms and Templates 4
R Product Recall - medical devices in the hospital warehouse Canada Medical Device Regulations 2
D Hospital Decontamination and the MDR - Technical Files, UDI and PMS EU Medical Device Regulations 3
F Risk for Quality Assurance Department in a Hospital - Hospital Incident Reporting ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
O Hospital-Developed, In-House Device - FDA Clearance? Other US Medical Device Regulations 19
A Hospital IT expectations for connected medical device using WIFI Medical Information Technology, Medical Software and Health Informatics 0
K Hospital UDI requirements Other Medical Device and Orthopedic Related Topics 7
M Oxygen enriched environment applicability - Operating table used in general surgeries in hospital IEC 60601 - Medical Electrical Equipment Safety Standards Series 0
D How to Calibrate any Digital Sphygmomanometer under use for 2 years in a Hospital Forum News and General Information 1
R IVD regulatory requirements for different hospital environments Other Medical Device and Orthopedic Related Topics 1
Q Mexico Medical Device Registration - Private Hospital Exemption Other Medical Device Regulations World-Wide 1
Wes Bucey Hospital Turns Down Malcolm Baldrige National Quality Award World News 0
S Selling a CE Marked Product to a Hospital in Bulgaria Other Medical Device Regulations World-Wide 4
I What is an Ideal Control Chart for Hospital Surgery Infections? FMEA and Control Plans 2
2 Discussion about Hospital Carts Medical Information Technology, Medical Software and Health Informatics 7
S Lean Hospital - Implementing a quality/lean/six sigma program Lean in Manufacturing and Service Industries 3
Ronen E Cybersecurity for Medical Devices and Hospital Networks Medical Information Technology, Medical Software and Health Informatics 1
R EU requirements for Hospital Use Health IT software CE Marking (Conformité Européene) / CB Scheme 2
I Hospital Product/Service Realization and Monitoring/Measurement (ISO 9001) Hospitals, Clinics & other Health Care Providers 4
D ISO 13485 for Hospital Sterilization Departments ISO 13485:2016 - Medical Device Quality Management Systems 2
R Hospital Grade Mains Plug US (NEMA 5-15) and Japan IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
L Hospital Laboratory IVD (In Vitro Diagnostic) Transportation Classification in Brazil Other Medical Device Regulations World-Wide 2
R Should be Hospital Grade Plug be used in Class II Medical Equipment? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
Q Posey Bed or Hospital Bed Regulatory Process Japan Medical Device Regulations 1
A Hospital Internal Audit Check List Hospitals, Clinics & other Health Care Providers 5
J Sterilisation Validation of Re-Usable Hospital Instruments ISO 13485:2016 - Medical Device Quality Management Systems 1
B Hospital Operating Room Regulations - Separate Entrances for Clean and Dirty Supplies Hospitals, Clinics & other Health Care Providers 4
B Hospital Wall Mounts (for Display Monitors and other devices) - Requirements Occupational Health & Safety Management Standards 10
J Hospital Laboratory wants to apply ISO 9001 Hospitals, Clinics & other Health Care Providers 10
S ISO 15189 Hospital Laboratory Accreditation - Forms and Templates needed Document Control Systems, Procedures, Forms and Templates 1
T Part 880.5100 AC-powered adjustable Hospital Bed - Applied Parts Marking or Labeling Other US Medical Device Regulations 1
S FCC Rules for Hospital Wireless Medical Devices 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
B Common Sterilization Methods in Hospital - Prevalence? Hospitals, Clinics & other Health Care Providers 2
V Is a Hospital Grade Power Cord Required? Class I Medical Device Other US Medical Device Regulations 4
somashekar Requirements for Patient Gowning & other Hospital Clothes, sheets wrt. static charge? Other Medical Device Related Standards 2
xcanals_tecno-med.es ISO 13485 in Hospital Central Sterilization and Clinical Engineering Services ISO 13485:2016 - Medical Device Quality Management Systems 27
P Class I & II Rx Medical Devices - Pre-Hospital Market Distribution questions ISO 13485:2016 - Medical Device Quality Management Systems 3
D Best Practices for Safe Handling of Rented Hospital Mattresses Hospitals, Clinics & other Health Care Providers 4
M Risk Management Standards - Hospital Information System (electronic health records) Hospitals, Clinics & other Health Care Providers 4
L Hospital Grade and Medical Grade power cord differences? Hospitals, Clinics & other Health Care Providers 2
Sidney Vianna Ball Memorial Hospital - The first Indiana hospital to receive NIAHO accreditation Hospitals, Clinics & other Health Care Providers 1
S Biocompatibility - Hospital Bed ISO 13485:2016 - Medical Device Quality Management Systems 12
B Identifying Peak Demand and Usage with Start/End Time - Hospital Hospitals, Clinics & other Health Care Providers 3
Sidney Vianna Medicare to Cease Payment for Hospital Error Hospitals, Clinics & other Health Care Providers 0
M Possible thread moves? (To the New Hospital and Health Care Providers forum) Hospitals, Clinics & other Health Care Providers 3
Sidney Vianna New protocol for hospital accreditation: NIAHO. Includes ISO 9001 Hospitals, Clinics & other Health Care Providers 10
japayson Why document control matters - Hospital or Health Care Environment Hospitals, Clinics & other Health Care Providers 2
