Contents of PPAP Control Plan - Product & Process Characteristics?
L
lenbh
Hello, everyone.
I'm wondering if I can get a bit of advice on the content of a control plan. I understand the concepts, I think, but some of the fields seem a bit vague as to how to fill them in, and exactly what needs to be in there. I'm very new to PPAP, and I'm trying to prepare a submission to our customer.
I don't entirely understand the content of the "Characteristics - Product" and "Characteristics - Process" fields. From the few samples I've found, I see, for example, "bolt torque" in the product field and "torque driver torque monitoring" in the process field. So, just what is meant by "Product"?
The second question is to do with content. It seems that every process, from incoming inspection to outgoing shipment, is entered, along with the control methods. So, as an example, for a process that involves putting the part into an oven for some time to bake, do I need to note how the oven temperature is set by the operator, and also how it is controlled (by the hardware of the oven), and also how we might calibrate that hardware periodically? Is that the kind of detail I need?
Thanks for the help!
Len
bobdoering
Stop X-bar/R Madness!!
Re: PPAP control plan
Hello, everyone.
Perhaps this example will help. If you were machining a bolt, the "Characteristics - Product" would be the hex dimensions, length dimensions, even some of the thread dimensions - those characteristics found on the product itself. The "Characteristics - Process" would be the machine controls - feeds and speeds, chuck pressures, etc. - those characteristics that might affect the outcome quality that are not directly on the part.
Every sequence of your process should show up on the control plan, Any verification you do, or control you have in place, you need to take credit for on the control plan. The last column should state what you really do if the process goes wrong for that line item. The detail needs to make sense. If it appears to be too much detail, it can be spun off into a work instruction (step-by-step stuff) and referenced int eh control plan.
Hope that helps....
L
lenbh
That makes a lot of sense, and clarifies it. I didn't think it was that complicated... just needed to understand what was expected.
Thank you very much!
bobdoering
One other thought - do not look at the control plan as info to satisfy an auditor or customer. Think of it as a guide for your own people. If you walked up to an operation, it should be a simple guide as to what you need to check to verify the parts and process, how you are going to do it, with what gage, how often, and what to do if you run into a problem. Really, that was all the chart was designed to do.
L
lenbh
Ahhh... Right. It's often too easy to think "what does the auditor want" and not "what do we want".
Thanks again!
Len
DrM2u
I agree with Bob's example for Product & Process characteristics.
Here is some food for thought regarding the 'content' of the control plan. There is no written specification, rule or requirement that forces you to list all your process steps (from receiving to shipping and anything else in between) on the same control plan. As a personal preference I like to develop control plans for every major process then compile them as they apply to a particular part. This enables me to have CP's for standard/common processes (i.e. receiving, storage, handling, shipping, etc) and not re-create them for every new part. Of course that does not mean that I shouldn't review them to ensure that they are still valid and effective. As a side note, this approach also implies process-specific PFMEA's as opposed to a cover-all PFMEA, since the CP is derived from the PFMEA. Some of the benefits of such an approach:
- smaller and easier to manage control plans (fewer sheets of paper) for each process
- reduced CP development time on new products
- ability to modify one process without modifying the CP for all other processes
- have only relevant information at every process (i.e. receiving CP at machining process does not help any)
Another bit of food for brain ... It is advisable to focus your controls on process parameters/charactereistics in order to build the quality into the part, as opposed to using part characteristics to detect quality. Use the part characteristics primarily to validate and re-validate your process.
Hope this helps some.
L
lenbh
What you suggest makes a lot of sense. I have several sets of processes that the part has to go through - receiving, forming, machining, etc. and we could easily break up the control plan into blocks like that.
Thanks for the ideas.
Cheers.
Len
bobdoering
Conceptually, I agree. My preference is to have them in the same file (for easier document control), but be able to print them out by operation. Few people care to look at other operation's controls - they just want to know their own. You could even make them individual tabs, if your preference is Excel.
Hope that helps....
It's all good advice. :agree1: I've seen far too many control plans where the process characteristics column is completely blank, and what you have is an inspection plan, which defeats the purpose in large measure. It should be a process control plan.
Stijloor
I agree with Jim. :applause: Most control (quality) plans are reactive in nature.
Also, the relationship between process characteristics and product characteristics is poorly understood and/or ignored.
Stijloor.
Q Simple overview of the contents of APQP and PPAP APQP and PPAP 2
A Help needed for PPAP submission requirements including contents APQP and PPAP 3
D Contents of a 510k Q submission Other US Medical Device Regulations 1
D Questions about the contents of a Design History File 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
R US FDA Mandatory Labelling contents for an OTC medical device US Food and Drug Administration (FDA) 0
M Informational IMDRF final document – Assembly and Technical Guide for IMDRF Table of Contents Submissions Medical Device and FDA Regulations and Standards News 4
M Informational Publication of Draft Health Canada Implementation Guidance for the International Medical Device Regulators Forum Table of Contents Format Medical Device and FDA Regulations and Standards News 0
B IATF 16949 Table of Contents IATF 16949 - Automotive Quality Systems Standard 1
M List of Packaging Contents - Medical Devices - Interpreting EU Directive 93/42/EEC CE Marking (Conformité Européene) / CB Scheme 3
elkel Control Plan Contents - Part Number / Latest Change Level FMEA and Control Plans 2
M How to best prioritize Medical Device Label Contents Other Medical Device and Orthopedic Related Topics 16
A What should be the contents of the New Gage Introduction Form ? General Measurement Device and Calibration Topics 3
T Traceability of the Contents in Gas Cylinders General Measurement Device and Calibration Topics 5
A Should the Table of Contents be held to a revision? Document Control Systems, Procedures, Forms and Templates 3
R FDA 510(k) Cover Letter Contents US Food and Drug Administration (FDA) 2
alonFAI Design Approval Tests Procedure Contents AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
Q Auditor found Form with Identical Contents but different Format - is this an NC? Document Control Systems, Procedures, Forms and Templates 28
C Lean Sigma Manufacturing Handoff Package Contents FMEA and Control Plans 8
J Contents of DMR (Device Master Record) when manufacturing is by 3rd party 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
somashekar Label Details and Contents for Reusable Surgical Instruments EU Medical Device Regulations 7
B How to copy rows to another worksheet based on the contents of a column Excel .xls Spreadsheet Templates and Tools 6
B Checklist Contents - Do ISO clause references need to be included? Internal Auditing 4
S Control Plan Details vs. Operator Instruction Sheets - Document Contents IATF 16949 - Automotive Quality Systems Standard 9
M What do the asterisks (*) in the table of contents mean? IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
S Quality Policy Contents for Power Sector - Biomass Power Generation Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
R Assembly Procedure (Work Instruction) Contents and Requirements Manufacturing and Related Processes 10
howste Calibration Certificate Contents: How to report Measurement Uncertainty? Measurement Uncertainty (MU) 18
A Unlabled Containers as to the Contents from my Suppliers - Labeling Requirements Miscellaneous Environmental Standards and EMS Related Discussions 2
J Does my company's Business Plan Contents comply with requirements of TS 16949? IATF 16949 - Automotive Quality Systems Standard 2
Q Inspection and Test Plan Contents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S Technical File Contents ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 5
M Environment Policy Statement Contents ISO 14001:2015 Specific Discussions 15
M APQP Timing Plan Details and APQP Package Contents (e.g.: floor plan) - Batch Mfg. APQP and PPAP 5
B Test Package Contents Requirements - Hydraulic Piping and Pressure Testing Other ISO and International Standards and European Regulations 3
Ajit Basrur Pre Filled Syringes (PFS) - Effect of Containers on the Contents 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
E "Sales Packaging" contents - Medical Device company Other ISO and International Standards and European Regulations 1
Chennaiite Contents of a 'Past trouble' data base Records and Data - Quality, Legal and Other Evidence 5
D Suggestions and inputs for title and contents of Company Newsletter Misc. Quality Assurance and Business Systems Related Topics 4
D In-house Internal Auditor (ISO9001 & ISO13485) Training & Course Contents Training - Internal, External, Online and Distance Learning 5
M In-Process Non-Conformance Report Contents ISO 13485:2016 - Medical Device Quality Management Systems 12
V When to add contents to Quality Manual amendment table? Quality Management System (QMS) Manuals 3
H Management Review contents for Multiple Standards ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M FDA - "Net Quantity of Contents" - Manufacturing Filling Process Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 12
J Management System Presentation Contents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
G Restructure of Procedures - Need Table of Contents Examples Document Control Systems, Procedures, Forms and Templates 5
S A detailed ISO 17025 'Table of Contents' ISO 17025 related Discussions 9
S Contents of the RABQSA QMS Gap Exam General Auditing Discussions 4
J Drafting a Quality Manual - Contents Quality Management System (QMS) Manuals 4
B Technical File for CE Mark declaration - Template or Sample of required contents EU Medical Device Regulations 24
J What determines the contents of an FMEA (Failure Modes and Effects Analysis)? FMEA and Control Plans 12
