Continual Improvement Requirements - No expected completion date listed - 8.5.1
Bigfoot
Hello Covers :bigwave:
During our last external audit a Non compliance was written against cl 8.5.1 with the finding of "More than 50% of Continual Improvement projects do not have the expected completion date listed" - :( - All of the CI projects checked during the audit have completion / or expected completion dates for the steps as the owner works through it. On further review I can't find where this is an actual requirement. :confused: I asked tha auditor for a specific reference and the response offered reference to 7.3 c, 4.1 d, e, & f, 5.4.2 which refers back to 4.1, ISO 9004 Annex "B", & Appedix "B" of Vocabulary (ISO 9000:2000 QMS - Fundamentals & vocabulary) - I have reviewed the areas suggested and find no requirement for the completion date of a project be identified. Do any of you have any ideas or thoughts on this?
Also was wondering is ISO 9000:2000 Quality Management Systems - Fundamentals & vocabulary an auditable document or like ISO 9004 is it a guidance document?
Jen Kirley
Quality and Auditing Expert
While not specifically a requirement, I am not sure but the auditor may have got the sense the projects were stalled, not active or not well enough defined to be called projects, which infers there is structure that one might expect to include a projected timetable in the planning stages.
Bigfoot
Jennifer - :thanx: Thanks for the feedback. In Q4 2005 we had 31 open CI projects - Q1 2006 there are 53 open & 13 closed CI projects. I would find it tough to believe it is stalled, but as with nearly everything there is always room to improve & project definition is likely one of those areas. However that isn't what he identified as the noncmpliance.
P
pldey42
You could contest the finding I suppose, because 8.5.1 has no mention of dates. Auditors should pick one clause to write a finding against, not a random selection of several in the hope that one will stick.
That said, if you _want_ to use the finding to mandate completion dates in your projects, you could look to 8.5.1 or 8.5.2 which both require action to be "appropriate" to the effects of n/cs or problems: timeliness is one aspect of "appropriate" because if a process problem is causing money to be wasted, who wants to waste it longer than necessary?
Section 2 of ISO 9001:2000 refers to ISO 9000:2000. You can't audit to ISO 9000 because it has no formal requirements; but its concepts and vocabulary do apply in an ISO 9001:2000 audit and make the audit process itself (something of) a consistently repeatable process (amongst auditors and across organisations) by removing the room for interpretation that would otherwise exist for words like "quality".
Hope this helps,
Patrick
Jen Kirley
Seems to me the next step is to ask the auditor exactly what was referred to in the nonconformance, and discuss the interpretation of the standard used to arrive at these conclusions.
apestate
There's the bit at the end of internal audit
ISO 9001:2000 8.2.2 said:
... The management responsible for the area being audited shall ensure that actions are taken without undue delay to eliminate detected nonconformities and their causes ... (see 8.5.2)
Bigfoot
pldey42 said:
You could contest the finding I suppose, because 8.5.1 has no mention of dates. Auditors should pick one clause to write a finding against, not a random selection of several in the hope that one will stick. Even in the list of potential clauses & references there is no actual requirement for this. Dates are used to drive the timely completion of the project steps and keep it from getting bogged down.
Section 2 of ISO 9001:2000 refers to ISO 9000:2000. You can't audit to ISO 9000 because it has no formal requirements; but its concepts and vocabulary do apply in an ISO 9001:2000 audit and make the audit process itself (something of) a consistently repeatable process (amongst auditors and across organisations) by removing the room for interpretation that would otherwise exist for words like "quality". As I thought.
Hope this helps,
Patrick
Patrick - Thank you for your response. It does help. I made some added comments above. This was a New Lead Auditor to our site (mandated change by TS) and this was our TS Renewal Audit. IMHO this is not a non-compliance as it is clear that the project owners are using dates to drive completion of the project steps. The only issue stems from the abscence of the expected completion date for the entire project. Acquiessing (sp) to accept this is similar to painting a bulls eye on our chests and walking through a firing range - add the dates as requested and then miss one we'd be noncompliant for failing to meet our expected completion dates. :bonk: :frust:
Bigfoot
I have and the response was the list of clauses that I put into the initial post, (7.3 c, 4.1 d, e, & f, 5.4.2 reference to 4.1 etc.). None of which list this as a requirement.
P
pldey42
Understood.
As a software engineering consultant (in my last career) I dealt with this as follows: rather than give a customer an end date for a complex system I had to build, without really knowing how deep the sh*t was, I'd define up front a planning phase and promise them a date at the end of that first phase. That way, everyone avoided open-ended commitments.
You might try that with the CI projects: give them a date (a reasonable one) by which they have to have a plan. Now, if that includes some pilot trials and plans past that are vague, ok: set a date nearer the time for completion of the next phase. (But I think you know that.)
As for the auditor: how about having a little chat with him about his prospects for returning to your site? (Decent contracts with registrars allow you to negotiate with them the "quality" of your auditor.)
Hope this helps,
Patrick
Cari Spears
Good example ... good suggestion.:agree1:
T TS 16949 Continual Improvement Requirements vs. QS-9000 Requirements IATF 16949 - Automotive Quality Systems Standard 16
S Continual (Continuous) Improvement - Different Standards, different requirements Occupational Health & Safety Management Standards 12
B Four Key Performance Indicators for Continual Improvement (Dec. 3 2019) [Deleted] Training - Internal, External, Online and Distance Learning 2
R Linking the Processes of Continual Improvement, Change Management, Risk Management, Action Planning, etc? Preventive Action and Continuous Improvement 5
A A Question about Continual improvement process in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Ranking Continual Improvement Projects Quality Tools, Improvement and Analysis 5
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P CA,PA, Continual Improvement - How to start in a Service Company Quality Tools, Improvement and Analysis 1
Marc How will "continual improvement" be audited? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Internal Audit Question - 8.5.1 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
M Continual Improvement Procedure - Please review Document Control Systems, Procedures, Forms and Templates 1
P Document Control vs Continual Improvement Document Control Systems, Procedures, Forms and Templates 11
C Continual Improvement in the context of ISO 22000:2005 Preventive Action and Continuous Improvement 2
Q Process Approach & Continual Improvement Clauses and Evidence of its Effective Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Continual Improvement vs. Ineffective Actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Definition Continual Improvement vs. Kaizen - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
somashekar Environmental and OH&S Management Continual Improvement Miscellaneous Environmental Standards and EMS Related Discussions 7
V Continual Improvement of the Organization - TS 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 10
I Process Improvement/Continual Improvement "Idea Stage-gate" process? Misc. Quality Assurance and Business Systems Related Topics 3
N Continual Improvement Tools Preventive Action and Continuous Improvement 3
R Definition Continuous Improvement and Continual Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 21
A Clause 8.5 Continual Improvement - What is intended by the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Quality Policy - Need to include "Customer Satisfaction & Continual Improvement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
somashekar Temperature Cycling Process - Continual Improvement and ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Continual Improvement & KPI's (Key Performance Indicators) - ISO 14001 REACH and RoHS Conversations 23
V Gearing up GMP based systems for continual improvement. US Food and Drug Administration (FDA) 4
Anerol C What can I show as evidence of Continual (Continuous) Improvement? Preventive Action and Continuous Improvement 81
B 8.5.1 Continual Improvement - What Quality Objectives can I add? Construction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Z Continual Improvement based on a Company's Characteristics Preventive Action and Continuous Improvement 6
L Introduce Continual Improvement in a Mining Equipment Service Company ? HOW? Quality Tools, Improvement and Analysis 5
R Jump Start Continual Improvement Process - What works? Preventive Action and Continuous Improvement 9
V TQM - Implementing Continual Improvement of Product, Processes and System Misc. Quality Assurance and Business Systems Related Topics 1
B Continual Improvement form - Does anyone have a CI form they will share? Preventive Action and Continuous Improvement 2
C Process Goals - Stretch or "Do-able": Corrective Actions or Continual Improvement Preventive Action and Continuous Improvement 6
M Setting Objectives and Targets for the EMS - Is continual improvement required? Miscellaneous Environmental Standards and EMS Related Discussions 23
J Continual Improvement - Service Company - Carpool, manpower, purchasing, logistics Service Industry Specific Topics 1
P Continuous vs. Continual Improvement - The Differences Preventive Action and Continuous Improvement 9
L Records of continual improvement - How do you keep auditors happy on this topic? Records and Data - Quality, Legal and Other Evidence 11
J Continual Improvement - What is CI and what is CI not? Preventive Action and Continuous Improvement 32
Marc The Continual Improvement Process (vs. Continuous Improvement?) Book, Video, Blog and Web Site Reviews and Recommendations 6
C Continual Improvement Book Book, Video, Blog and Web Site Reviews and Recommendations 14
Q Difference between Continuous and Continual Improvement IATF 16949 - Automotive Quality Systems Standard 8
C Evidence of Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Anyone have a procedure to share for TS 16949 - 8.5.1 Continual Improvement? IATF 16949 - Automotive Quality Systems Standard 3
A Is reduction of scrap a valid Continual Improvement Project? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Continual Improvement & Preventive Action Differences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L ISO 14001 - Environmental Management Program - To govern continual improvement? ISO 14001:2015 Specific Discussions 6
A Continual Improvement of Production Processes - TS 16949 IATF 16949 - Automotive Quality Systems Standard 11
J Continual Improvement vs. Continuous Improvement - Terminology Semantics ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
