Continual Improvement - What is CI and what is CI not?
Jim Howe
WALLACE said:
Jim,
If you're open to analysing and using the ISO 9004 model. You may wish to use the 9004 model as your benchmark for current and future process definitions and opportunities for improvement.
Just my thoughts.
Wallace.
Thanks Wallace, you have been a great help. We are open to all suggestions! In a recent mailer from my local ASQ section a consulting service placed an article that talks about the continual improvement cycle. It states that "Auditors need to be aware of what continual improvement is and what it is not." I dont know if this should be a new thread or not but I pose this question to you and the whole gang at the cove.
What is continual improvement vs what is not? Any takers? The consultant did not offer any further explanation.
RoxaneB
I like the idea of a new thread for this...CI is not limited to audit results alone.
RoxaneB
Couldn't resist starting a new thread for this. It started of in a thread discussing Continual Improvement (CI) from audit results. My opinion is that CI is not just limited to audit results alone, so I thought I'd start a new (yet related) discussion.
To me, CI is raising the level of performance....but first you need to know what your performance capability is.
Again I'll say "There can be no improvement without first establishing routine."
If there is a problem in the conducting of Routine Practices - be it found during an Internal/External Audit, monitoring/measuring of process/product, etc. - CI is not an option. Routine means establishing a consistent level of performance with consistent results. No consistency ensures that there is no foundation upon which to improve.
Once the Routine is consistently under control, then we can focus on Improvement to the Process. The data collected from the Routine Process shows how we are doing....Improvement is the analysis to show us what we can do.
I always think of a line from a Star Trek movie....Chekov and Sulu are in a forest and Chekov states that they're lost. Sulu's response is something like "Alright, I admit it. We're lost. But at least we're making good time."
If the data is showing that we have an out-of-control process, requirements are not being met, and/or results are inconsistent....we can not determine what we are capable of or where we can be, seeing as we do not even know where we are.
The Taz!
Your analysis is no different than improving a manufacturing process through statistical techniques. You first have to wring out all special causes or sources of abnormal variation. Once you have done that, you have a process that should be stable and only showing indications of normal variation.
A process for systemic processes is essentially the same. . . you have to have a stable and standardized process that is in control. One technique that is used is "Standard Work". . . or a standardized methodology that all players use.
Once you have a stable and consistent process, you can implement a change and see the effect of that change. Without that level playing field, any changes made will be hidden in all the "noise" induced by NOT being stable and standardized. This is not a new concept but has been around for a long time. Unlike a manufacturing process though, the effect will show up over time, and needs to be monitored for effectiveness (The CHECK).
JMHO
That subject should be worth a thread of its own. :agree1: Here we are: Over to the group...
/Claes
Added later... Oops! Rox beat me to it, so I merged the posts I split from Continuous Improvement from Audit Results into this one instead. Sorry about any confusion caused by this.
W
WALLACE
I'm nearly finished reading through a book titled Kaizen by Masaaki Imai
ISNB # 0-07-554332-X.
This publication has again challenged me to take another look at the various formats, tools and techniques of (What we commonly term) CI.
CI is many things to many people. The cultural aspect to CI is very important and, the reason (I believe) why the Japanese form of CI (Kaizen) has been so successfull is that, Japanese culture is so Homogenized.
Roxane quoted "There can be no improvement without first establishing routine." I agree totaly. Look at the the Homogenized manner of the Japanes culture and glean something from that regarding infusing routine (Read standardization).
The Kaizen model is an excellent model for benchmarking. I have to say that, as I read through the book, I became aware that the Ford Production System (FPS) has indeed been benchmarked on the Kaizen model.
Homogenizing or standardizing operating processes and procedures using a CI measure by, continuously assessing the process and procedural capabilities by cross functional work groups is IMO FWIW the way to go.
One discussion forum in the UK states that, After initial assessment of process and procedural capabilities in relation to system have been mapped out, it then becomes neccessary to De-fragment (Unfragment) a system. This is IMO the key to CI. This is where Continuous improvement and the use of basic statistical tools works hand in hand.
Attached is a visual that I worked on through a quality work group. the visual speaks of Fast track improvements and, after looking at the visual again (After reading the book), I realize that, the Kaizen aspect is eveident throughout the visual.
Wallace.
Hershal
Metrologist-Auditor
I agree. Audits are a monitoring tool to keep track of how you are doing......like when your pulse is checked.
The real improvement comes from people. Management can and certainly should support, lead, and provide input, but the folks doing the work often have the best ideas of how to get things done. Now, sometimes they can use a little help to get things done and make sure that the idea/method complies with the organization's requirements.
Improvements should also be reviewed in Management Review, and translated into currency-speak.....after all, one has to keep Exec Management interested, and their job is to make money for the organization.
A little recognition for the folks suggesting and imlementing the improvements should also be a part of CI.
Just my thoughts.
Hershal
Rob Nix
I hope I'm in the right thread now Claes... :confused:
I'll start with this:
Continous Improvement - Perpetual (Webster = "uninterupted extension") improvement made every day, hour, and minute. This term was unrealistic and therefore changed in the standards to continual improvement.
Continual Improvement - Non-ceasing (Webster = "recurring in steady succession") acts to enhance value, excellence, quality, or simply: to make things better than they were before.
Instead of it being an entity of its own in an organization, e.g. having its own procedure or "process" or other such thing, it should be an evident and intrinsic part of the management environment. A chief goal of top management should be that no process in the organization ever stagnate. Everything must get better over time.
Evidence of continual improvement can then be found in MANY areas:
- Strategic Business Planning
- Benchmarking
- Training & Education Initiatives
- Corrective & Preventive Actions
- Audit OFIs
- SPC
- Reliability Growth
- Waste reduction
- ETC.
Anyway, these are my thoughts. I look forward to more on this.
RoxaneB
:agree1: That's exactly what we do!
We do not have a procedure or "process", per se, for CI. It is a concept or, the word used here, methodology for ensuring we never accept the status quo as being our best.
We have established tools in place to help us sustain our CI initiatives. Some of the tools focus on the Routine...but this provides us with a solid foundation to build upon. Other tools are dedicated to CI.
Over the past few years, we started to notice that our gains were getting smaller and smaller...i.e., it was becoming more difficult to improve. Introducing some new CI tools into our "toolbox" has allowed to identify areas we never thought of before and the movement upward has increased. :D
B Four Key Performance Indicators for Continual Improvement (Dec. 3 2019) [Deleted] Training - Internal, External, Online and Distance Learning 2
R Linking the Processes of Continual Improvement, Change Management, Risk Management, Action Planning, etc? Preventive Action and Continuous Improvement 5
A A Question about Continual improvement process in AS9100 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
B Ranking Continual Improvement Projects Quality Tools, Improvement and Analysis 5
J Understanding ISO 9001:2015 - 10.3 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
P CA,PA, Continual Improvement - How to start in a Service Company Quality Tools, Improvement and Analysis 1
Marc How will "continual improvement" be audited? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Internal Audit Question - 8.5.1 Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
M Continual Improvement Procedure - Please review Document Control Systems, Procedures, Forms and Templates 1
P Document Control vs Continual Improvement Document Control Systems, Procedures, Forms and Templates 11
C Continual Improvement in the context of ISO 22000:2005 Preventive Action and Continuous Improvement 2
Q Process Approach & Continual Improvement Clauses and Evidence of its Effective Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Continual Improvement vs. Ineffective Actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Definition Continual Improvement vs. Kaizen - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 6
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
T TS 16949 Continual Improvement Requirements vs. QS-9000 Requirements IATF 16949 - Automotive Quality Systems Standard 16
somashekar Environmental and OH&S Management Continual Improvement Miscellaneous Environmental Standards and EMS Related Discussions 7
V Continual Improvement of the Organization - TS 16949 Clause 8.5.1.1 IATF 16949 - Automotive Quality Systems Standard 10
S Continual (Continuous) Improvement - Different Standards, different requirements Occupational Health & Safety Management Standards 12
I Process Improvement/Continual Improvement "Idea Stage-gate" process? Misc. Quality Assurance and Business Systems Related Topics 3
N Continual Improvement Tools Preventive Action and Continuous Improvement 3
R Definition Continuous Improvement and Continual Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 21
A Clause 8.5 Continual Improvement - What is intended by the standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
B Quality Policy - Need to include "Customer Satisfaction & Continual Improvement? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
somashekar Temperature Cycling Process - Continual Improvement and ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
M Continual Improvement & KPI's (Key Performance Indicators) - ISO 14001 REACH and RoHS Conversations 23
V Gearing up GMP based systems for continual improvement. US Food and Drug Administration (FDA) 4
Anerol C What can I show as evidence of Continual (Continuous) Improvement? Preventive Action and Continuous Improvement 81
B 8.5.1 Continual Improvement - What Quality Objectives can I add? Construction ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Z Continual Improvement based on a Company's Characteristics Preventive Action and Continuous Improvement 6
L Introduce Continual Improvement in a Mining Equipment Service Company ? HOW? Quality Tools, Improvement and Analysis 5
R Jump Start Continual Improvement Process - What works? Preventive Action and Continuous Improvement 9
V TQM - Implementing Continual Improvement of Product, Processes and System Misc. Quality Assurance and Business Systems Related Topics 1
B Continual Improvement Requirements - No expected completion date listed - 8.5.1 IATF 16949 - Automotive Quality Systems Standard 10
B Continual Improvement form - Does anyone have a CI form they will share? Preventive Action and Continuous Improvement 2
C Process Goals - Stretch or "Do-able": Corrective Actions or Continual Improvement Preventive Action and Continuous Improvement 6
M Setting Objectives and Targets for the EMS - Is continual improvement required? Miscellaneous Environmental Standards and EMS Related Discussions 23
J Continual Improvement - Service Company - Carpool, manpower, purchasing, logistics Service Industry Specific Topics 1
P Continuous vs. Continual Improvement - The Differences Preventive Action and Continuous Improvement 9
L Records of continual improvement - How do you keep auditors happy on this topic? Records and Data - Quality, Legal and Other Evidence 11
Marc The Continual Improvement Process (vs. Continuous Improvement?) Book, Video, Blog and Web Site Reviews and Recommendations 6
C Continual Improvement Book Book, Video, Blog and Web Site Reviews and Recommendations 14
Q Difference between Continuous and Continual Improvement IATF 16949 - Automotive Quality Systems Standard 8
C Evidence of Continual Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
R Anyone have a procedure to share for TS 16949 - 8.5.1 Continual Improvement? IATF 16949 - Automotive Quality Systems Standard 3
A Is reduction of scrap a valid Continual Improvement Project? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
K Continual Improvement & Preventive Action Differences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L ISO 14001 - Environmental Management Program - To govern continual improvement? ISO 14001:2015 Specific Discussions 6
A Continual Improvement of Production Processes - TS 16949 IATF 16949 - Automotive Quality Systems Standard 11
J Continual Improvement vs. Continuous Improvement - Terminology Semantics ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
