Definition Continuous Improvement and Continual Improvement - Differences
rcm_mech
Hello friends:D
Is there any difference between Continuous and continual Improvements ? Is there any logic behind it?
Thanks in advance.
brahmaiah
Re: Is there any difference between Continuous and continual Improvements ?
Hello friends:D
Thanks in advance.
'Continuous improvement' means improving every movement without stop.Continual improvement means showing a trend of periodic improvement.Continuous improvement is very difficult if not impossible. But Continual improvement is practicable & realistic to expect.
A dictionary will also give you the difference between them.
V.J.Brahmaiah
Hello friends:D
Thanks in advance.
People spend hours debating this. If you are going to explain this to management, there is no real difference. The issue lies purely in whether you make small step improvements (like Kaizen) or use large projects (6 Sigma style) to make those improvements....
You will dig a big hole for yourself if you try to explain the differences to people who haven't any experience of either type of improvement!
somashekar
Yaaa... just be on track with the PDCA with all sincerity and worry not on the english meaning or difference between these words .....
Manix
Get Involved!!!
IMO it's semantics and a debate on the true meaning of one versus the other is pointless and adds no value to anything. I hate to jump to the ISO standard but in this instance it actually gives you the answer, 8.5 of ISO9001:2008 uses "Continual Improvement". End your thought there and concentrate on the essence of what it is for: Always seek improvement across your organisation and it's processes using the systems outputs to highlight areas that may need attention or that may show potential for improvement.
Just my :2cents: pence!
Jen Kirley
Quality and Auditing Expert
I agree there is little point in getting hung up over the differences, which for most of us amount to semantics of language and dialect. Let's suffice to differentiate it from a defined, single project that budges a process, then "walks away" and moves on to the next thing. That said, even that approach can be defended as continuous improvement to a system, since it can be argued that there's limited value in constant tinkering in a single process.
:2cents:
samsung
V.J.Brahmaiah
From Merriam Webster Collegiate Dictionary
CONTINUAL
1 : continuing indefinitely in time without interruption <continual fear>
2 : recurring in steady usually rapid succession <a history of continual invasions>
–con·tin·u·al·ly adverb
synonyms: CONTINUAL, CONTINUOUS, CONSTANT, INCESSANT, PERPETUAL, PERENNIAL mean characterized by continued occurrence or recurrence. CONTINUAL often implies a close prolonged succession or recurrence <continual showers the whole weekend>. CONTINUOUS usually implies an uninterrupted flow or spatial extension <football's oldest continuous rivalry>.
CONTINUOUS
Synonyms: CONTINUAL, ceaseless, constant, endless, everlasting, interminable, perpetual, timeless, unceasing, unending
1 : marked by uninterrupted extension in space, time, or sequence
2 of a function : having the property that the absolute value of the numerical difference between the value at a given point and the value at any point in a neighborhood of the given point can be made as close to zero as desired by choosing the neighborhood small enough
synonyms see CONTINUAL
Hence NO DIFFERENCE.
S Continual (Continuous) Improvement - Different Standards, different requirements Occupational Health & Safety Management Standards 12
Anerol C What can I show as evidence of Continual (Continuous) Improvement? Preventive Action and Continuous Improvement 81
P Continuous vs. Continual Improvement - The Differences Preventive Action and Continuous Improvement 9
Marc The Continual Improvement Process (vs. Continuous Improvement?) Book, Video, Blog and Web Site Reviews and Recommendations 6
Q Difference between Continuous and Continual Improvement IATF 16949 - Automotive Quality Systems Standard 8
J Continual Improvement vs. Continuous Improvement - Terminology Semantics ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
H Continual (Continuous) Improvement - Effectiveness of the Quality Management System ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
G Lean Kaizen: continuous, step-by-step improvement in the Lean direction Lean in Manufacturing and Service Industries 0
S Government MotorPool Continuous Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
N FDA Guidelines for implementing Continuous Improvement Process US Food and Drug Administration (FDA) 5
L Is there a certifiable Continuous Improvement system? Various Other Specifications, Standards, and related Requirements 6
J Continuous Improvement vs. Preventive Actions - Differences Preventive Action and Continuous Improvement 3
M Continuous Improvement Log vs. Formal CAPA System Preventive Action and Continuous Improvement 3
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Continuous Improvement: How it works in your company? How to record the CI actions? Lean in Manufacturing and Service Industries 4
P Benchmarking and Continuous Improvement Tool Benchmarking 3
L How to Document Continuous Improvement Projects Lean in Manufacturing and Service Industries 2
V Which improvement tool/approach do you adopt for driving Continuous Improvement? Quality Tools, Improvement and Analysis 3
Crusader Real World Continuous Improvement Examples for Accounting Personnel? Quality Tools, Improvement and Analysis 3
A Objectives & Targets - Continuous Improvement (ISO14001) ISO 14001:2015 Specific Discussions 8
kedarg6500 Continuous Improvement Course Slide ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Continuous Improvement Idea Gathering Tools and Software Preventive Action and Continuous Improvement 7
L Decision Matrix to help Operator driven Continuous Improvement Lean in Manufacturing and Service Industries 3
J Continuous Improvement SOP - How to demonstrate we meet TS 16949 Clause 8.5.1 IATF 16949 - Automotive Quality Systems Standard 12
C Continuous Improvement as a Newsletter Topic Misc. Quality Assurance and Business Systems Related Topics 5
M Samples of a Continuous Improvement Program Procedures Preventive Action and Continuous Improvement 3
B CI (Continuous Improvement) Tools and Techniques - What is the state of the art? Lean in Manufacturing and Service Industries 4
D Desk Top CI (Continuous Improvement) form Document Control Systems, Procedures, Forms and Templates 8
L ISO9004:2009 Continuous Improvement Checklist wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Changing Career Path - Document Controller to Continuous Improvement Specialist Career and Occupation Discussions 8
L Definition Preventive Actions vs. Continuous Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
A Continuous Improvement Template wanted Document Control Systems, Procedures, Forms and Templates 27
Marc --> Related Forum - Preventive Action and Continuous Improvement Nonconformance and Corrective Action 0
Marc --> Related Forum - Preventive Action and Continuous Improvement Problem Solving, Root Cause Fault and Failure Analysis 0
T Polite way to state Continuous Improvement is not a form? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Le Chiffre Great article on how to handle continuous improvement Quality Manager and Management Related Issues 3
J Continuous Improvement Documentation Method/Template Preventive Action and Continuous Improvement 1
B Continuous improvement and Management review process links ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
B What other activities should be included in a Continuous Improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Continuous Improvement Toons wanted for Continuous Improvement Awareness Week Preventive Action and Continuous Improvement 2
Q Continuous Improvement Form - Really needed? IATF 16949 - Automotive Quality Systems Standard 3
J CI (Continuous Improvement) Induction presentation Lean in Manufacturing and Service Industries 3
C Games for mass participation in Continuous Improvement Lean in Manufacturing and Service Industries 11
G MSSC (Manufacturing Skills Standards Council) Quality And Continuous Improvement Misc. Quality Assurance and Business Systems Related Topics 2
J Measuring the progress of Continuous Improvement Program - Methods and Criteria used? Lean in Manufacturing and Service Industries 6
Y Energy Savings in Glass Tablewares Company - Continuous Improvement Manufacturing and Related Processes 3
kedarg6500 GM specs GP 5 PRR, GP 8 Continuous Improvement Customer and Company Specific Requirements 16
