Continuous Improvement Process: Revamp required - advice on the way forward request
Mezzaluna
Good Morning/Afternoon/Evening All,
I hope I'm using the correct forum here.
A little advice before I start on this - if anyone's had to perform similar:
My company has a convoluted, complicated and unworkable Continuous Improvement Process, which I have been tasked with "streamlining".
My job over the next 4 weeks is to visit all our sites and showrooms and to hold meetings with the staff. am to document their gripes with the current system (of which there will be many) and their required improvements to the system. I then have to report my findings and conclusions back to the management team.
I was wondering if anyone out there could suggest the best method of co-ordinating these meets to get the best out of them. Is there a "Quality Tool" I should be employing?
Thanks,
Mezzaluna
Steve Prevette
Deming Disciple
You may want to consider making use of Dr. Deming's Red Bead Experiment as an ice breaker. Sounds like you are in the paradoxical situation of needing to continually improve your continual improvement system:rolleyes:
Andrey
Well, fırst you can look at the sıte of Audıtıng practıces group (can be found through ISO sıte www.ıso.ch)(http://isotc.iso.org/livelink/livel...mprovement.doc?func=doc.Fetch&nodeid=3553366). Here ıs an ınterestıng materıal about the approach to contınual ımprovement. If ın few words, fırst you shall ıdentıfy performance measures for all your management system - how to measure overall system effectıveness. One of possıble solutıons ıs a use of EFQM Model or Boldrıdge Model (results sectıon). After that you can provıde measurements and fınd the gaps - and performıng braınstormıng fıgure out prıorıtıes - areas to be ımproved. You must fully understand what ımpact of these ımprovement ınıtıatıves on the overall company's performance. And ... apply thıs cırcle repeatedly - nothıng new, perhaps, ıt ıs wrıtten ın ISO 9000 sectıon 2.
Andrey Olyenkov, EFQM Levels of Excellence Assessor, BVQI QMS Audıtor.
malasuerte
Re: Continuous Improvement Process: Revamp required - advice on the way forward reque
If you need a tool to help you, the Turtle model is not a bad way to go.
P
Phil Fields
This could be tricky due to possible negative attitudes, try to keep it positive. The following is something that I received from www.enleadership.com it is used for change management.
1. What is already working
a. List all items that are working with the current system (there may be nothing)
2. What is causing it to work
a. Established procedures
b. One person know the system
c. It has to be done
d. Etc
3. What is the objective (of the process you are reviewring)
a. What are you trying to achieve
4. What are the benefits of achieving the objective
a. If there are no benefits, re-look at your objective
b. Be sure the objective is meaningful to the organization
5. What can I begin doing to move closer to the objective
a. What needs to be done
b. Who needs to do what
c. Keep the goals time bound
d. Review to be sure objective is met
e. Celebrate the achievements
This is a method I have used with success, but I begin the meetings by telling the participants that I want to try something new. I stress at the beginning that I want to keep the dialog positive.
I hope this helps,
Phil
Thanks,
Mezzaluna
It seems that there's a component missing. Who's the Process Owner? If you are, then 'good luck'.......If not, then either someone needs to be defined and given ownership or that already assigned person (and we're talking management here, not someone lower down the mine) needs to be part of the solution.
Rather than have you visit each site and talk with everyone - since they will see this as open season on moaning about everything from government policy to the dripping taps in the beathrooms - you should set up a number of sessions and have them visit you - and the CI Process Owner.
You (the team, that is) should map the (convoluted) process 'as is' so that everyone can see it for what it is, and there's no surprises/assumptions in there. Since this 'picture' will reveal the non-value added steps, most people will see where things should be improved and you can use regular brainstorming etc. to work through the changes.
N FDA Guidelines for implementing Continuous Improvement Process US Food and Drug Administration (FDA) 5
B Continuous improvement and Management review process links ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
B What other activities should be included in a Continuous Improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
J Looking for Possible Continuous Improvement initiatives for the CI Process? IATF 16949 - Automotive Quality Systems Standard 7
F Continuous Improvement Process Map - As an individual process? Process Maps, Process Mapping and Turtle Diagrams 5
S Annex B examples of Continuous Improvement Process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S What are the Components of a Good Continuous Improvement Process Preventive Action and Continuous Improvement 6
Marc The Continual Improvement Process (vs. Continuous Improvement?) Book, Video, Blog and Web Site Reviews and Recommendations 6
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
G Lean Kaizen: continuous, step-by-step improvement in the Lean direction Lean in Manufacturing and Service Industries 0
S Government MotorPool Continuous Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
L Is there a certifiable Continuous Improvement system? Various Other Specifications, Standards, and related Requirements 6
J Continuous Improvement vs. Preventive Actions - Differences Preventive Action and Continuous Improvement 3
M Continuous Improvement Log vs. Formal CAPA System Preventive Action and Continuous Improvement 3
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Continuous Improvement: How it works in your company? How to record the CI actions? Lean in Manufacturing and Service Industries 4
P Benchmarking and Continuous Improvement Tool Benchmarking 3
L How to Document Continuous Improvement Projects Lean in Manufacturing and Service Industries 2
V Which improvement tool/approach do you adopt for driving Continuous Improvement? Quality Tools, Improvement and Analysis 3
Crusader Real World Continuous Improvement Examples for Accounting Personnel? Quality Tools, Improvement and Analysis 3
A Objectives & Targets - Continuous Improvement (ISO14001) ISO 14001:2015 Specific Discussions 8
kedarg6500 Continuous Improvement Course Slide ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Continuous Improvement Idea Gathering Tools and Software Preventive Action and Continuous Improvement 7
L Decision Matrix to help Operator driven Continuous Improvement Lean in Manufacturing and Service Industries 3
J Continuous Improvement SOP - How to demonstrate we meet TS 16949 Clause 8.5.1 IATF 16949 - Automotive Quality Systems Standard 12
C Continuous Improvement as a Newsletter Topic Misc. Quality Assurance and Business Systems Related Topics 5
M Samples of a Continuous Improvement Program Procedures Preventive Action and Continuous Improvement 3
B CI (Continuous Improvement) Tools and Techniques - What is the state of the art? Lean in Manufacturing and Service Industries 4
D Desk Top CI (Continuous Improvement) form Document Control Systems, Procedures, Forms and Templates 8
L ISO9004:2009 Continuous Improvement Checklist wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Changing Career Path - Document Controller to Continuous Improvement Specialist Career and Occupation Discussions 8
L Definition Preventive Actions vs. Continuous Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
S Continual (Continuous) Improvement - Different Standards, different requirements Occupational Health & Safety Management Standards 12
R Definition Continuous Improvement and Continual Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 21
A Continuous Improvement Template wanted Document Control Systems, Procedures, Forms and Templates 27
Marc --> Related Forum - Preventive Action and Continuous Improvement Nonconformance and Corrective Action 0
Marc --> Related Forum - Preventive Action and Continuous Improvement Problem Solving, Root Cause Fault and Failure Analysis 0
T Polite way to state Continuous Improvement is not a form? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Le Chiffre Great article on how to handle continuous improvement Quality Manager and Management Related Issues 3
J Continuous Improvement Documentation Method/Template Preventive Action and Continuous Improvement 1
C Continuous Improvement Toons wanted for Continuous Improvement Awareness Week Preventive Action and Continuous Improvement 2
Anerol C What can I show as evidence of Continual (Continuous) Improvement? Preventive Action and Continuous Improvement 81
Q Continuous Improvement Form - Really needed? IATF 16949 - Automotive Quality Systems Standard 3
J CI (Continuous Improvement) Induction presentation Lean in Manufacturing and Service Industries 3
C Games for mass participation in Continuous Improvement Lean in Manufacturing and Service Industries 11
G MSSC (Manufacturing Skills Standards Council) Quality And Continuous Improvement Misc. Quality Assurance and Business Systems Related Topics 2
J Measuring the progress of Continuous Improvement Program - Methods and Criteria used? Lean in Manufacturing and Service Industries 6
Y Energy Savings in Glass Tablewares Company - Continuous Improvement Manufacturing and Related Processes 3
