Continuous Improvement Template wanted
bobdoering
Stop X-bar/R Madness!!
Re: Need Template/ format on Continuous Improvement
Ouch! This is an interesting request. It sounds like one might want to develop a rubber stamp approach to continuous improvement. IMHO I am not so sure that is a good idea. You need a process, but as the inputs enter the process each opportunity should have a very unique circumstance - which tends to preclude a "template" approach. You can use a standard project template, I suppose, that looks at a goal and steps to achieve that goal - but I do not think you can "dial it in" to specifically continuous improvement.
Jen Kirley
Quality and Auditing Expert
It's easy to decide continuous improvement is mysterious, complex, and needs a tool box like Six Sigma. But it doesn't need to be complex. Plan-Do-Check-Act is the only template I will offer you because like Bob, I don't want you to feel locked in to a certain method. Continuous improvement can be as simple as a 5S project. The tricky part is how to understand the impact; some effectiveness measurement should be defined so you can do a before/after analysis.
That said, maybe you just need something to give you confidence. There are some related threads at the bottom of this page, and this list of attachments I found via a key word search in the Post Attachments List - see the green button in the header.
Ted Schmitt
I have always felt that one should "feel" the continuous improvement.... after a full audit of all the organizations processes, the auditor should "feel" this improvement through indicators, customer satisfaction, management involvment, increase in resources and etc....
Provide a template or format for documenting continuous improvement projects / activities
Isn't that what Management Review is for?
The principle is that by looking at the performance of the management system, top management are supposed to be able to determine where improvements should be made! It's their job to provide resources and direction to the people making the improvements.
Then, at subsequent reviews the performance of that improvement can be reviewed and lead to the next improvement.
IMHO - it has little to do with audits etc. (in most organizations audits have little to do with tangible improvements or $$$ saved) and, as Bob correctly says, there shouldn't be a need to apply another document to record improvements - you already have (or should) the most appropriate mechnism in place!
Q
qualitytrec
As alluded to by our fellow covers there are several means to CI ( audits, Preventive and Corrective Action, Lean Initiatives, Six Sigma, Poke-Yoke, etc...). If you are looking for a way to track the various improvements I would suggest developing a simple matrix in a database or excel sheet that lists:
Action
Target Date for completion
Actual Completion Date
Responsible Party
Improvement Driver (Customer CAR, Internal CAR, Audit Finding, 6-Sigma Project, Etc...)
Result (tie this to Cost or a key objective as much as possible)
Obviously, your list may look different but just make it work for you and your company. I am currently setting up tracking this type of information on a large white board in my Lab.
It is being used as a tracking center for improvement, CARs and New Product Development. I was tired of being asked all the time about project status So shortly they will be able to look at the board (or i can just point to it).
Hope this is helpful.
Mark
L
LeanMfgGuru - 2010
I too have been looking for best or good practices in regard to what I call a CI Plan (Continuous Improvement) but have not had much success.
L
LeanMfgGuru - 2010
I don't think this is a request for a "rubber stamp" type approach, although I could be wrong. I know I myself am looking for a CI template, to customize, to meet the KPI's of my current company.
L
LeanMfgGuru - 2010
A typical management review (in my experience with TS 16949, ISO 14001) will not provide enough improvement activities to create a true lean culture. The book by Pascal Dennis, titled "Getting The Right Things Done" , illustrates very well, the concept of strategy deployment. I just finished this book, and would highly recommend it to everyone.
K
krishna007
Hi
As Interesting the topic is, this is also very comprehensive. well my few cents or my personnal opinion is using a 8D report in a way organises all activities in your improvement initiative, including the source of problem, the problem itself and the final disposition of the solution and its effectiveness.
So i would recommend to use your 8D reporting template for CI projecs.
any views from fellow Covers on this?
thanks and regards
J Continuous Improvement Documentation Method/Template Preventive Action and Continuous Improvement 1
D Continuous Improvement Plan - Plastic injection molding IATF 16949 - Automotive Quality Systems Standard 1
G Lean Kaizen: continuous, step-by-step improvement in the Lean direction Lean in Manufacturing and Service Industries 0
S Government MotorPool Continuous Improvement ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Need Continuous improvement Suggestions - Small (30 of us) all-CNC machine shop ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 28
N FDA Guidelines for implementing Continuous Improvement Process US Food and Drug Administration (FDA) 5
L Is there a certifiable Continuous Improvement system? Various Other Specifications, Standards, and related Requirements 6
J Continuous Improvement vs. Preventive Actions - Differences Preventive Action and Continuous Improvement 3
M Continuous Improvement Log vs. Formal CAPA System Preventive Action and Continuous Improvement 3
F Suggestions for quick & effective solution for Continuous Improvement Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
A Continuous Improvement: How it works in your company? How to record the CI actions? Lean in Manufacturing and Service Industries 4
P Benchmarking and Continuous Improvement Tool Benchmarking 3
L How to Document Continuous Improvement Projects Lean in Manufacturing and Service Industries 2
V Which improvement tool/approach do you adopt for driving Continuous Improvement? Quality Tools, Improvement and Analysis 3
Crusader Real World Continuous Improvement Examples for Accounting Personnel? Quality Tools, Improvement and Analysis 3
A Objectives & Targets - Continuous Improvement (ISO14001) ISO 14001:2015 Specific Discussions 8
kedarg6500 Continuous Improvement Course Slide ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D Continuous Improvement Idea Gathering Tools and Software Preventive Action and Continuous Improvement 7
L Decision Matrix to help Operator driven Continuous Improvement Lean in Manufacturing and Service Industries 3
J Continuous Improvement SOP - How to demonstrate we meet TS 16949 Clause 8.5.1 IATF 16949 - Automotive Quality Systems Standard 12
C Continuous Improvement as a Newsletter Topic Misc. Quality Assurance and Business Systems Related Topics 5
M Samples of a Continuous Improvement Program Procedures Preventive Action and Continuous Improvement 3
B CI (Continuous Improvement) Tools and Techniques - What is the state of the art? Lean in Manufacturing and Service Industries 4
D Desk Top CI (Continuous Improvement) form Document Control Systems, Procedures, Forms and Templates 8
L ISO9004:2009 Continuous Improvement Checklist wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
I Changing Career Path - Document Controller to Continuous Improvement Specialist Career and Occupation Discussions 8
L Definition Preventive Actions vs. Continuous Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
S Continual (Continuous) Improvement - Different Standards, different requirements Occupational Health & Safety Management Standards 12
R Definition Continuous Improvement and Continual Improvement - Differences Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 21
Marc --> Related Forum - Preventive Action and Continuous Improvement Nonconformance and Corrective Action 0
Marc --> Related Forum - Preventive Action and Continuous Improvement Problem Solving, Root Cause Fault and Failure Analysis 0
T Polite way to state Continuous Improvement is not a form? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Le Chiffre Great article on how to handle continuous improvement Quality Manager and Management Related Issues 3
B Continuous improvement and Management review process links ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
B What other activities should be included in a Continuous Improvement process? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
C Continuous Improvement Toons wanted for Continuous Improvement Awareness Week Preventive Action and Continuous Improvement 2
Anerol C What can I show as evidence of Continual (Continuous) Improvement? Preventive Action and Continuous Improvement 81
Q Continuous Improvement Form - Really needed? IATF 16949 - Automotive Quality Systems Standard 3
J CI (Continuous Improvement) Induction presentation Lean in Manufacturing and Service Industries 3
C Games for mass participation in Continuous Improvement Lean in Manufacturing and Service Industries 11
G MSSC (Manufacturing Skills Standards Council) Quality And Continuous Improvement Misc. Quality Assurance and Business Systems Related Topics 2
J Measuring the progress of Continuous Improvement Program - Methods and Criteria used? Lean in Manufacturing and Service Industries 6
Y Energy Savings in Glass Tablewares Company - Continuous Improvement Manufacturing and Related Processes 3
kedarg6500 GM specs GP 5 PRR, GP 8 Continuous Improvement Customer and Company Specific Requirements 16
R Deploying Continuous Improvement Plans - Anyone here come from textiles industry? Lean in Manufacturing and Service Industries 3
G The ASQ 'Facilitating Continuous Improvement' course - Takes you thru the PDCA cycle? Training - Internal, External, Online and Distance Learning 0
J Continuous Improvement - A list of the improvements to show the auditor? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Looking for Possible Continuous Improvement initiatives for the CI Process? IATF 16949 - Automotive Quality Systems Standard 7
J How to motivate top management - Fearful of continuous improvement and resist change Misc. Quality Assurance and Business Systems Related Topics 2
