Contract manufacturer seeking help understanding ISO 13485 Validation requirements
E
Earlene
We are a contact manufacturer who does not
> design products merely manufactures to a design and are trying to get
> a grasp of what we are required to do in regard to ISO-13485 product
> realization.
Don Palmer
Bump Thread
Hi Earlene,
Welcome to the Cove. I've bumped your post to the top of the list. Maybe someone with answers can address your question.
Al Rosen
> realization.
Everything but 7.3. Do you have a more specific question that we might address?
Al Rosen
Zeissuser said:
Inspection and Test - to prove your parts meet customer requirements.
ZeissUser
This can't be excluded. What is your reasoning for excluding it?
cbearden
Sorry.....maybe I missunderstood the question.....I didn't mean exclude it, I meant execute it.......among other things in 7.1
Zeissuser
Al Rosen
Zeissuser
I think it was my misunderstanding.
G
Gerry Quinn
The title of your thread asks about Validation but your question asks about product realization.
With respect to Validation, 13485 only asks you to validate processes where the resulting output cannot be verified by subsequent monitoring or measuring. So with this understanding you need only assure that a process that cannot be inspected is proven to produce acceptable results.
This is like a sulfur analysis. Sulfur analysis requires that the sample be destroyed as a part of the process. In order to assure that the equipment that is used to perform the analysis is giving accurate results it is common to analyze a sample of material that has a known sulfur level. then analyze the unknown sample and then to follow up with another anlysis of the known sample. If the first and last tests are accurate it is reasonable to assume that the test on the unknown is accurate.
Validation is defined by ISO as: "Confirmation through the provision of objective evidence that the requirements for a specific intended use have been fulfilled."
Validation of processes performed by a Contract Manufacturer for Medical Device clients is generally understood to mean that prior to production and whenever you make any change to the process or equipment you will ensure that your processes, and equipment are producing products in accordance with the design specifications. If you run two shifts you will ensure that each shift is in compliance. If you change machines, machine speeds, dies, suppliers etc. you will run a proccess/equipment validation again before you resume production.
We have experienced inferior products from suppliers that have moved a process from type of machine that produced good product to another faster machine that they didn't validate. Once validated they discovered that the second machine introduced an error into the process that they weren't inspecting.
All of this must be documented.
Q
qualitygoddess - 2010
Ditto!
Based on what I read in the original post and the replies so far, I concur with Gery Quinn's reply.
--QG
blooddevice
Re: Contract manufacturer seeking help understanding ISO-13485 Validation requirement
Validation of a process is to ensure that the process is consistant and requires documentation (eg: IP,OP,PQ) for the process and when ever a change to the process occurs documentation of the change must take place. and availabe to the customer for review and approval prior to the change taking place.
D What does a contract manufacturer have to do to comply with for MDR? EU Medical Device Regulations 2
Q ISO 13485 Contract Manufacturer Controls and Quality System Requirements ISO 13485:2016 - Medical Device Quality Management Systems 4
D Can a contract manufacturer own the technical file EU Medical Device Regulations 1
S OEM- Virtual Manufacturer contract MDR Quality Management System (QMS) Manuals 0
S FDA Contract Manufacturer and Applicant US Food and Drug Administration (FDA) 0
Melissa Contract Mfg--to Manufacturer with the FDA ISO 13485:2016 - Medical Device Quality Management Systems 4
M FDA Medical device reporting (Manufacturer in US; contract manufacturer OuS) US Food and Drug Administration (FDA) 0
I Is SRN required for a contract manufacturer (CE-Marking product)? EU Medical Device Regulations 2
H Contract Manufacturer as Design Owner ISO 13485 ISO 13485:2016 - Medical Device Quality Management Systems 6
MedicalDevicesCanada How to find a medical device contract manufacturer, MDSAP certified? Canada Medical Device Regulations 6
shimonv Working with a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
S Who is technically and legally a "Contract Manufacturer"? ISO 13485:2016 - Medical Device Quality Management Systems 4
E Component manufacturer or contract manufacturer ? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
M How Specific in an ISO 13485:2016 Scope for a Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 9
H Obligations as a contract manufacturer during an MDSAP audit ISO 13485:2016 - Medical Device Quality Management Systems 11
H 510k with Contract Manufacturer Other US Medical Device Regulations 2
E Contract manufacturer FDA requirements foreign company US Food and Drug Administration (FDA) 6
M We are looking for a Contract Manufacturer US Food and Drug Administration (FDA) 2
L Sample Procedure from Contract Manufacturer Prospective ISO 14971 - Medical Device Risk Management 1
I Is the contract mfg. mentioned in legal manufacturer EC certificate? CE Marking (Conformité Européene) / CB Scheme 4
S Can a Contract Manufacturer "release" product on behalf of client to the market? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 11
R FCC certification (contract manufacturer) TL 9000 Telecommunications Standard and QuEST 1
M Contract manufacturer MDR Quality Management System (QMS) Manuals 1
K Reporting a Change of Contract Manufacturer for a 510(k) cleared device Other US Medical Device Regulations 5
O Identifying KPI for AS9100 8.1.4 - Prevention of Counterfeit Parts - PCB assembly contract manufacturer AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
M Medical Device Master File - We are a contract manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 10
D Software Validation - Contract manufacturer of Components (PCBA's) Qualification and Validation (including 21 CFR Part 11) 7
J Contract Sterilization - Our company is a contract manufacturer Manufacturing and Related Processes 8
R Contract Manufacturer/OEM Supplier - We are a specification developer for a kitted product 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
S Legal Manufacturer FDA Reporting Obligations for Using New Contract Sterilization Site Other Medical Device Regulations World-Wide 0
leftoverture REACH Compliance - Small, family-owned contract manufacturer REACH and RoHS Conversations 16
R 21 CFR Part 820 Contract Manufacturer of Medical Device Component 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
Ed Panek Bringing Production in house from Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 3
M ISO 80079-34 certified contract manufacturer needed Other ISO and International Standards and European Regulations 2
Ed Panek Observational Audit of Contract Manufacturer Production ISO 13485:2016 - Medical Device Quality Management Systems 5
S Is it okay to store the design files (device drawings) at contract manufacturer location? ISO 13485:2016 - Medical Device Quality Management Systems 6
M Contract Manufacturer of a Finished Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 5
D EU MDR - Contract Manufacturer vs Legal Manufacturer EU Medical Device Regulations 4
I Certificate of Exportability - Contract manufacturer located outside the US 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
S Is company “A” a contract manufacturer, a labeler, or a repackager 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
S Integrating a Contract Manufacturer's documentation into our Quality System ISO 13485:2016 - Medical Device Quality Management Systems 3
J Medical Devices sourced from Contract Manufacturers - Who is the legal manufacturer? EU Medical Device Regulations 13
S Question about ISO 13485:2003 - Production Provisions - Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 10
S Contract Manufacturer Question - Whether or not the reference to the ex-CMO ISO 13485:2016 - Medical Device Quality Management Systems 6
R Sterilization Adoption - Design House - Adoption Letter from Contract Manufacturer EU Medical Device Regulations 3
Ajit Basrur Can a Contract Manufacturer Delist a Device upon Discontinuation of Manufacturing? Other US Medical Device Regulations 1
H Who is the Legal / Labeled Manufacturer? (Contract Manufacturers shipping to the EU) ISO 13485:2016 - Medical Device Quality Management Systems 1
N "Sterile" missing on the CE Certificate - ISO 13485 Certified Contract Manufacturer ISO 13485:2016 - Medical Device Quality Management Systems 5
N UDI implementation with contract manufacturer Other US Medical Device Regulations 2
