Search the Elsmar Cove!
Contradictions in Medical Device Verification vs. Validation - ISO 13485
tantan
Hi, i am currently writing the SOPs for design control and am at a stuck with verification and validation. i have found lots of good sites with great definitions, inlcuding this forum but when i go to practically apply it I get confused. For example...validation is supposedly testing that the user requirements are satisfied...where eslewhere a verfication process will say convert user needs/ req to specs, develop a test protocol from this to verify design input to output. Isnt this a contradiction in terms as its essentially doing the same thing!?
Or could i look at it this way-requirements are composed of 3 aspects...functional, performance and interface requirements. These in turn are converted into engineering specfications. The testing of the functional components completes the validation, and the testing of the performance and interface requirements, as well as other means such as code walkthroughs etc completes the verification.
If anyone else could shed some light it would be greatly appreciated!!
Tania :)
cuadra - 2010
Re: contradictions in verification v validation
Verification:
The act of reviewing, inspecting, testing, checking, auditing, or otherwise establishing and documenting whether products, processes, services, or documents conform to specified requirements. The process of evaluating a system or component to determine whether the products of the given development phase satisfy the conditions imposed at the start of that phase.
Validation:
The process of evaluating software at the end of the software development process to ensure compliance with software requirements. The techniques for validation is testing, inspection and reviewing. Determination of the correctness of the products products, processes, services with respect to the user needs and requirements.
cuadra
Ajit Basrur
Thanks Tania :)
Tania, in simple words,
Verification simply is the process where you come to know if its OK or not OK, while
Validation is the process to ensure that the steps when performed under the predetermined conditions give a satisfactory product. In short, this stands for reproducibility and can ensure an acceptable product over a given period of time.
Hope this clarifies.
Coury Ferguson
Moderator here to help
If you are talking about ISO9001:2000 use the definitions in ISO9000:2000.
tantan
im trying to harmonise our certified ISO 13485 to the FDA QSR...needs a much more detailed design control procedure, and im just trying to make sure I do it right!
Coury Ferguson
I really am no expert in 13485, but the definitions stated in ISO9000:2000 are a good place to start. Does 13485 have a series that has definitions?
tantan
i think the definitions are pretty similra. i think my problem is that intellectually i understand the definitions...it is when i come to applying it to how things are run in my company that im having problems...ie is this a verification document or validation document.For example, we have gone through and tested all the functions of the software program ie does file open when you hit file open, does file close etc...is this validating the functionality...or verifying the specfication that this is what must happen when a user hits file open..
this is why i am a bit confused...
K
Kiran Sridhar
Tania,
I will give you the example:
Consider a mechanical part, like a sheet metal bracket. Here are the differences of verification and validation:
Verification:
I will inspect the part against the drawing, which includes material, dimensions, dimensional & geometric tolerances, finish. I am not bothered whether this part is performing well in the assembly or not, which is ultimately the user's needs.
Validation:
I will assemble the part onto the system; check for fitment and function. This is validation. Here, I don't have any drawings, but I have user needs in my mind.
I believe this example can be extrapolated to any extent.
Let me know if you have any queries beyond this.
Thanks & Regards,
Kiran
tantan
thats a really good mechanical example !
does anyone have similar examples for software?
Coury Ferguson
Let's look at the definitions:
ISO9000:2000 said:
Validation confirmation, through the provision of objective evidence (3.8.1), that the requirements (3.1.2) for a specific intended use or application have been fulfilled
Note 1 The term "validated" is used to designate the corresponding status
Note 2 The use conditions for validation can be real or simulated
This example, in my opinion would fall under validation. The objective evidence would be the testing of opening and closing the file.
ISO9000:2000 said:
Verification confirmation through the provision of objective evidence (3.8.1) that specified requirements (3.1.2) have been fulfilled
Note 1 The term "verified" is used to designate the corresponding status
Note 2 Confirmation can comprise activities such as
- performing alternate calculations,
- comparing new design specification (3.7.3) with similar proven design specification,
- undertaking tests (3.8.3) and demonstrations, and
- reviewing documents prior to issue
In my opinion, when you compare any other existing software programs to see if it does what the other proven software has done, you have verified the program.
These are in my opinion, and someone else might have a better understanding of the differences.
