Control Chart CpK dilemma - Defect Per Unit data on a single production line
SHARON MYNHARDT
#11
Hi guys
I am new to Elsmar and Quality. My name is Sharon. I need help with the following.
How do you interpret when a process is in or out of control.
CPK 1.33
CPK 1.53
CPK 1.00
Which is in control, which is stable and which is out of control.
Please help.
Sharon
Darius
#12
First...Wellcome to the cove.
The cpk does not explain that issue.
The Cpk just evaluate the variation against the specs and make a penalty for not being the center to them.
The Cpk it self doesn't tell how many samples where taken, the sample size could make the cpk estimate :mg: have large or small confidence interval. As I said in other post is better to use Cpk minimum estimated value so you can compare the Cpk form different sample sizes correctly (or establish a minimum of 100 samples for example)
How can be answered "is the process stable?", is not clear, there are two (at least) phylosofies.
1- Not presenting any pattern on the control chart (well maybe 2 in a 100 sample could be considered stable). The issue here is wich patten apply to your process, not every GE rule applies to any process.
2- I found scarse information about this other one but IMHO the right way. take SPC as statistical hypotesis testing (to compare mean and variation with a "t" and an "F" test) from one period of time to the other (use 90% confidence tables because is not a controlled experiment). The root on this is that if you have the same mean and the same variation, the process could be predicted.
Try to read this... (is not publicity but thanks to Donald Wheeler's SPC Press and their reading room), it's a MUST.
A change in terminology:applause:
Darius
#14
There is not much to say from the file
Cpk 1.47, that according to my calculus is not less than 1.2, nice Cpk
The sample size looks to me a little bit low and the data looks not gaussian (more data on the lower 32 without any data bellow). On the data looks something like a periodic ups and downs but from the sample size is hard to say.
It's not 6Sigma but loks fine
And you can say it's in control, no outliers and no visible patterns from the data (but looks a little bit non natural, maybe can the periodic ups and downs be analized and increase the capability of your system).
janedoe
#15
Hey Scott,
Your situation calls for the use of a C-chart. It measures defects / unit which, in this case, is defects per machine. The particular size of the machine matters little.
Your selection of the proper chart for attribute studies is based on what is know as the Poisson distribution, and it applies to the C and U chart where binomial data reflects the P and NP chart usage.
How to tell when a Poisson based (C or U) chart are needed?
Here's what you do to answer this question. Look at your process and ask yourself: 'If I can track defects...is it also possible for me to track non-defects'? Clearly, you can not track non-defects...such as paint defects or scratches. That is, what would a non-paint defect look like?
See what I mean? You can't track the non-defect or it simply does not have any real meaning.
The correct method would be to use a C-chart since the lot size has been established as a single unit. A U-chart, too, could be used but the C-chart will provide more meaningful information such as "there are 1.4 defects per unit".
Hope that helped.
#16
Please have a look at my attachment
Sharon,
Take a look at the attached histogram of your data. It is non-normal, though does appear stable. You cannot calculate a standard Cpk with this type of data.
Before making any recommendations such as attempting to transform the data, can you explain the process that created these diameters?
This is reminiscent of a screw machine where the diameters are turned down to a hard stop. You can have diameters greater than the stop, but none less than the stop.
F
flyin01
#17
4) Determine root cause(s),
5) implement corrective action(s) (Make it/them go away),
6) continue to monitor to determine if it in fact it/they did go away.
I agree with you. These can not be stressed enough, reliable rca is crucial, the problem is that everyone always has a action plan, but how realistic are they and nr 6 is often forgotten. It is easy to forget to verify that the problem was solved before moving on to other problems.
C Control Chart out of control? Cpk - Process Out of Control Statistical Analysis Tools, Techniques and SPC 26
H How can I calculate Cp & Cpk and make a control chart for maintenance activities? Capability, Accuracy and Stability - Processes, Machines, etc. 3
F Cpk 1.99 But Out of Specification Measurement Detected in Control Chart Reliability Analysis - Predictions, Testing and Standards 36
K What should be the best control chart? Cpk study for assembly length Capability, Accuracy and Stability - Processes, Machines, etc. 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
M What is "setup control chart"? Statistical Analysis Tools, Techniques and SPC 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
F Appropriate Control Chart Statistical Analysis Tools, Techniques and SPC 5
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
L The ARL for an X bar Control Chart (n = 5) Statistical Analysis Tools, Techniques and SPC 5
L P-Chart Control Limit Calculation help Statistical Analysis Tools, Techniques and SPC 1
L A Complete Control Chart Decision Tree Statistical Analysis Tools, Techniques and SPC 5
S Variation Study on Mined Material - What do you call it (not a control chart) Statistical Analysis Tools, Techniques and SPC 7
G I-Chart and X bar Chart Control limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
J Control Chart Pattern Detection Statistical Analysis Tools, Techniques and SPC 3
R Control Chart Constants and Confidence Interval Statistical Analysis Tools, Techniques and SPC 7
P Specification and Tolerance in Stability Control Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I What is an "X-Rs" Control Chart? Statistical Analysis Tools, Techniques and SPC 4
I What is an Ideal Control Chart for Hospital Surgery Infections? FMEA and Control Plans 2
M Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked column Statistical Analysis Tools, Techniques and SPC 2
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
P SPC Data Collection and Control Chart Type question Statistical Analysis Tools, Techniques and SPC 4
R XBar & R Chart Spreadsheet to apply a Control Process Statistical Analysis Tools, Techniques and SPC 1
Chennaiite Control Chart for Non-Manufacturing Process Indicators - Is it worth? Statistical Analysis Tools, Techniques and SPC 1
O Is it an Assignable Cause only if the Control Chart says so? Statistical Analysis Tools, Techniques and SPC 16
C Control Chart Roadmap Template Document Control Systems, Procedures, Forms and Templates 0
T Shewhart Control Chart - ISO/TS 13530:2009(E), Page 22. General Measurement Device and Calibration Topics 3
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
H Control Chart applications in Cement Industries Statistical Analysis Tools, Techniques and SPC 2
T Implementing SPC - Control Chart for Individual Measurements Statistical Analysis Tools, Techniques and SPC 9
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I Control Chart for Mortality Rate on Broiler Farms Statistical Analysis Tools, Techniques and SPC 4
G Control Chart Selection for Crimping Operations for RJ 45 Plugs Statistical Analysis Tools, Techniques and SPC 5
K When to create a new Control Chart? Quick question Statistical Analysis Tools, Techniques and SPC 4
T Control Chart - Salt Spray Test Hours - Powder Coated Parts Statistical Analysis Tools, Techniques and SPC 3
S Calculation of Upper and Lower Control Limits for Control Chart? Statistical Analysis Tools, Techniques and SPC 7
R Control Chart Metrics/KPI - Measuring Effectiveness of Control Charting System Statistical Analysis Tools, Techniques and SPC 4
L Measurement Uncertainty using Control Chart Measurement Uncertainty (MU) 2
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
J What Control Chart should be used for Microbial Limit (NMT 100 cfu/m3) Statistical Analysis Tools, Techniques and SPC 12
