Control Chart Selection for Crimping Operations for RJ 45 Plugs
G
gautham.nk
I need help in selecting Control chart type for Crimping operations that we are doing for RJ 45 Plugs. We have identified this as a critical process parameter that needs to be controlled and monitored over a period of time.
There are eight points of contact on each plug and the specifications set around the plugs are 6 +/- .08.
I did try with a moving average chart but it did not make sense in taking the average of these eight points as they are not exactly in a plain surface. The heights of teeth follow a U –shaped projection after crimping.
Please see the below data that I had measure for a small interval.
Parts
1st trail
Avg
6
6.041
6.048
6.044
6.4
6.023
6.04
6.046
6.028
6.084
3
6.009
6.028
6.013
6.012
6.001
6.01
6.013
6
6.011
4
5.989
6.001
5.998
6
5.983
6.002
5.994
5.979
5.993
9
6.001
6.004
6.002
5.995
5.988
6
5.998
5.991
5.997
1
6.042
6.053
6.046
6.041
6.035
6.048
6.059
6.047
6.046
7
6.038
6.055
6.027
6.07
6.025
6.033
6.05
6.033
6.041
8
6.017
6.038
6.04
6.042
6.034
6.05
6.046
6.026
6.037
2
6.043
6.055
6.051
6.045
6.038
6.052
6.06
6.04
6.048
5
6.045
6.062
6.05
6.038
6.045
6.056
6.075
6.055
6.053
10
6.006
6.039
6.022
6.021
6.018
6.052
6.042
6.042
6.030
Based on the above data if can one could direct that would be great.
Thanks in advance.
:thanx:
Steve Prevette
Deming Disciple
Re: Control Chart Selection
Are these data for one of the eight points, or are all eight points mixed together?
Also, there seem to be some odd results. Most of the entries are to three decimal places around 6.0. But then there are some integer entries, such as 6, 3, 6, 4. Do these denote batches or data entries?
G
gautham.nk
Hello Steve,
Thanks for the early reply.
Data is from 8 different points on the RJ45 Plug.
The Odd Number posted are the random part numbers picked and measured. Sorry I was trying to paste the data from excel and it seems to have gone wrong. I am trying to repaste data and also attach the file with readings on it
Parts1st trailAvg66.0416.0486.0446.46.0236.046.0466.0286.08436.0096.0286.0136.0126.0016.016.01366.01145.9896.0015.99865.9836.0025.9945.9795.99396.0016.0046.0025.9955.98865.9985.9915.99716.0426.0536.0466.0416.0356.0486.0596.0476.04676.0386.0556.0276.076.0256.0336.056.0336.04186.0176.0386.046.0426.0346.056.0466.0266.03726.0436.0556.0516.0456.0386.0526.066.046.04856.0456.0626.056.0386.0456.0566.0756.0556.053106.0066.0396.0226.0216.0186.0526.0426.0426.030
I
iamtroll
It might help if you submitted in an Excel file or even a Word file so that the numbers could be more easily manipulated. It would also help to carefully identify part numbers, run order and any multiple tooling input. :)Kind of a lot but it can help in analysis.
If I understand the crimp height characteristic, you will have between part variation and within a part variation. You could also have an additional variation input is you are also using multiple tools to crimp with or worse yet, progressive tooling. All of this makes for a challenging analysis since the liklihood of the process being even near normal is very low. Not knowing a lot about your tooling and process, the first step I would take is to analyze the within a part variation amd between tool variation (if there are multiple tools). This will tell you how a lot about your tooling so that you can determine whether or not your tooling is capable of producing withing spec. That's Capable with a large "C". This is not a real capability study, but you have data so you can at least get a feel for what is going on.
G
gautham.nk
Hello IAMTROLL,
Thanks for the reply.
I have attched the results in an excel file.
The results obsereved are from one crimping machine and there is no tool to tool variation here. As you said there is variation from part to part and within each part.
:thanx:
Steve Prevette
Deming Disciple
I took part 10 as an example. First thing to do is simply plot the dots. I put a grand average and control limits through the data using moving range. The data are unstable - and several things can be seen:
The first result done by any operator on any trial is the lowest value, except for operator 3's 2nd trial.
Operator 1's 6th 7th and 8th attempts were of a pattern different thant the 2nd through 5th attempts.
Operator 2 seemed the most consistent, and assuming 6 is the target value, better than operators 1 and 3.
For Operators 2 and 3, the second trial resulted in lower values than the first.
Next step would be to subdivide into smaller groups of data to see which sets are consistent with each other.
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
M What is "setup control chart"? Statistical Analysis Tools, Techniques and SPC 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Control chart applicable? Percentage of compliance with a standard Statistical Analysis Tools, Techniques and SPC 2
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
B How to do a control chart - Machining product that requires flatness control Capability, Accuracy and Stability - Processes, Machines, etc. 1
S Understanding control chart and measurement capability Statistical Analysis Tools, Techniques and SPC 2
F Appropriate Control Chart Statistical Analysis Tools, Techniques and SPC 5
S used excel formula calculated the ARL's with Rule1&Rule2 for Shewhart control chart Statistical Analysis Tools, Techniques and SPC 0
H How to define Root Cause when some points are out of control chart Statistical Analysis Tools, Techniques and SPC 6
L The ARL for an X bar Control Chart (n = 5) Statistical Analysis Tools, Techniques and SPC 5
L P-Chart Control Limit Calculation help Statistical Analysis Tools, Techniques and SPC 1
L A Complete Control Chart Decision Tree Statistical Analysis Tools, Techniques and SPC 5
S Variation Study on Mined Material - What do you call it (not a control chart) Statistical Analysis Tools, Techniques and SPC 7
G I-Chart and X bar Chart Control limits Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
J Control Chart Pattern Detection Statistical Analysis Tools, Techniques and SPC 3
R Control Chart Constants and Confidence Interval Statistical Analysis Tools, Techniques and SPC 7
P Specification and Tolerance in Stability Control Chart Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 9
I What is an "X-Rs" Control Chart? Statistical Analysis Tools, Techniques and SPC 4
I What is an Ideal Control Chart for Hospital Surgery Infections? FMEA and Control Plans 2
M Shewhart Control Chart for SPC In Excel - Explain the yellow and red marked column Statistical Analysis Tools, Techniques and SPC 2
K Advice on Calculating Control Chart Control Limits Statistical Analysis Tools, Techniques and SPC 13
J Statistical Significance and SPC Control Chart Reports Statistical Analysis Tools, Techniques and SPC 9
P SPC Data Collection and Control Chart Type question Statistical Analysis Tools, Techniques and SPC 4
R XBar & R Chart Spreadsheet to apply a Control Process Statistical Analysis Tools, Techniques and SPC 1
Chennaiite Control Chart for Non-Manufacturing Process Indicators - Is it worth? Statistical Analysis Tools, Techniques and SPC 1
O Is it an Assignable Cause only if the Control Chart says so? Statistical Analysis Tools, Techniques and SPC 16
C Control Chart Roadmap Template Document Control Systems, Procedures, Forms and Templates 0
T Shewhart Control Chart - ISO/TS 13530:2009(E), Page 22. General Measurement Device and Calibration Topics 3
M MSA (Measurement System Analysis) - Do we have control of all states in the chart? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
H Control Chart applications in Cement Industries Statistical Analysis Tools, Techniques and SPC 2
T Implementing SPC - Control Chart for Individual Measurements Statistical Analysis Tools, Techniques and SPC 9
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
I Control Chart for Mortality Rate on Broiler Farms Statistical Analysis Tools, Techniques and SPC 4
K When to create a new Control Chart? Quick question Statistical Analysis Tools, Techniques and SPC 4
T Control Chart - Salt Spray Test Hours - Powder Coated Parts Statistical Analysis Tools, Techniques and SPC 3
S Calculation of Upper and Lower Control Limits for Control Chart? Statistical Analysis Tools, Techniques and SPC 7
R Control Chart Metrics/KPI - Measuring Effectiveness of Control Charting System Statistical Analysis Tools, Techniques and SPC 4
L Measurement Uncertainty using Control Chart Measurement Uncertainty (MU) 2
R Calculation Mean for Control Chart -X Double Bar Statistical Analysis Tools, Techniques and SPC 13
J What Control Chart should be used for Microbial Limit (NMT 100 cfu/m3) Statistical Analysis Tools, Techniques and SPC 12
B Color Individual Points on a Control Chart? Using Minitab Software 7
A Organization Chart Control and Quality Manual Integration ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Pre-Control Chart for Single Side Tolerance Statistical Analysis Tools, Techniques and SPC 1
T Control Chart to use when Sample Size is Constant Statistical Analysis Tools, Techniques and SPC 4
C Process Control Chart - Capable, but not stable question Capability, Accuracy and Stability - Processes, Machines, etc. 5
