Control Charts for 29 Devices that I tested
jdm2008
I have 29 devices that I tested. I am trying to generate a control chart for this study. These devices take a measurement. When testing them, I know for certain the measurement in reality is zero. So at two points I read the devices and see what they indicate. These are after 3 minutes and 15 minutes.
I am fairly certain that in this case that “n” would be 29 and this number is what all of the constants I would need are. When I put the data into a control chart calculator I’ve discovered the constants for n=2. Am I correct?
What are you trying to find out? What sort of "control chart calculator" are you using? What kind of chart do you want to produce? Are you charting the 3-minute data and the 15-minute data separately? Are the data in chronological order?
Jim is correct: let's take a step back and understand the question you are trying to answer. It doesn't sound like a 'control chart' is the analytical tool you need to answer your real question.
jdm2008
I want(I've been instructed) to produce a control chart. The control chart calculator just gives the the control limits.
The 3 minute data and 15 minute data are not charted seperately.
At this point all we know is that you want to produce a control chart and you're using a calculator of some sort. Without knowing (a) what you're trying to learn about the data, (b) the nature of the "calculator" and the underlying assumptions of the software and (c) why you have two data sets that you're lumping together, there really isn't much we can say that would be helpful. Please provide as much detail as you can.
jdm2008
Thanks for the reply I was debating whether to include more I guess i should have.
I have 29 devices that measure a quantity. I set the quantity measure independently of each device at zero. There are reports that the devices measure a quantity other than 0 when they should measure 0. This defect supposedly happens during the begining of its operation(ie if the device sits on for 30 minutes and does nothing this problem disapears). The data sets are lumped together because there should be no change from data taken at 3 minutes versus data taken at 15.
However there may be variation. They should both be 0(or some number close to 0), we are testing this point. I am trying to learn how close the numbers are too zero, and whether they are different outside of normal random variation.
As to the calculator, I'm not so much concerned about the calculator because I can do the control limits by hand. I'm concerned about whether in this case D4 and A2 would be for n=29 versus n=2.
I'm sorry, but maybe I'm a little thick because I still don't have a clear picture of what's going on, although I think I'm a little closer now. Some of the things we still don't know:
  • what's being measured;
  • how it's being measured--it is a continuous stream of data into the devices, or periodic measurements, e.g.;
  • why you've gathered two sets of data (3-minute & 15-minute) if you're not concerned about differentiating between them in your analysis;
  • why you're apparently trying to do calculations for subgrouped data (hence your questions about A2 and D4) when there don't appear to be rational subgroups involved;
  • if you're trying to find out if the devices are producing spurious readings--giving results >0 when you think that the input value should be 0, or if you're trying to find out if the 29 devices produce acceptably similar results, or what.
It still appears that a control chart isn't appropriate here, but if it is, it's bound to be an I/MR chart you're looking for. Have a look through this thread and see if there's any help there.
jdm2008
-specifically nuclear activity is being measured inside an enclosed space. Since the source of nuclear activity isn't present we know the reading should be 0 or close to i.
-A reading off the device. At a particular point.
-In theory the readings should be the same. We have a suspicion(or more correctly a suspicion was relayed) that they are not however.
-I would say acceptably similiar results both being 0.
For purposes of clarity I've combined my questions (Q) and your answers (A) and added my responses in italics (R):
Q: What's being measured?
A: Specifically nuclear activity is being measured inside an enclosed space. Since the source of nuclear activity isn't present we know the reading should be 0 or close to it.
R: This calls the function of the measurement devices into question; if you're dealing with radiation (what I assume you mean by "nuclear activity) detection, why are the devices registering detection of the target phenomenon if you know that it isn't present? I this what you're trying to find out?
Q: How is it being measured--it is a continuous stream of data into the devices, or periodic measurements, e.g.?
A: A reading off the device. At a particular point.
R: So I assume now that it's a continuous data stream and readings were taken at intervals.
Q: Why have you gathered two sets of data (3-minute & 15-minute) if you're not concerned about differentiating between them in your analysis?
A: In theory the readings should be the same. We have a suspicion(or more correctly a suspicion was relayed) that they are not however.
R: You have two data sets, and you want to compare them? To what end? This is still not clear to me. Are you trying to chart the two sets individually (this goes back to your original question regarding n=2 or n=29)?
Q: Why are you apparently trying to do calculations for subgrouped data (hence your questions about A2 and D4) when there don't appear to be rational subgroups involved?
A: Not answered
R: An answer to this question would be good.
Q:
Are you trying to find out if the devices are producing spurious readings--giving results >0 when you think that the input value should be 0, or are you trying to find out if the 29 devices produce acceptably similar results, or what?
R: It now seems certain that control charts of any variety are not going to help you.
Although I'm still not clear on the whole thing (such as why there are 29 measurement devices, a question I didn't ask), it seems to me that you need either some sort of controlled experimentation, or perhaps some form of measurement system analysis (MSA) or some combination of the two.
Sturmkind
I agree with Jim. This seems more like an attribute case of either the radioactivity is present and detectable or not. Readings close to zero probably represent the measurement 'noise' within the system and are likely to be considered as gage uncertainty. Otherwise, the light is either on/off and we would be uninterested in knowing if the light is 'almost' on or off.
With the data already in hand, then the device with the maximum range or value from zero should be known. The remaining question would be whether that device varies over time.
S Use of Attributes Control Charts Statistical Analysis Tools, Techniques and SPC 1
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
N Injection Molding - Median individual control charts Statistical Analysis Tools, Techniques and SPC 6
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
M Interpreting X bar and R Control Charts Statistical Analysis Tools, Techniques and SPC 2
M Large Sample Size - up to 32 - for Control Charts Capability, Accuracy and Stability - Processes, Machines, etc. 2
T Is the use of Control Charts Mandatory or Optional? ISO 17025 Requirements ISO 17025 related Discussions 6
E Minitab for hourly patient census - Control Charts Using Minitab Software 6
J Using P-Charts for Glass Manufacturing to Monitor and Control Attributes Statistical Analysis Tools, Techniques and SPC 2
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
S Help with Table of Constants and Formulas for Control Charts Statistical Analysis Tools, Techniques and SPC 5
Q Monthly Data Review through Control Charts - Monitoring Complaints ISO 13485:2016 - Medical Device Quality Management Systems 3
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Suitability of Attribute Control Charts for ppm Level Control Statistical Analysis Tools, Techniques and SPC 6
R Metrology Control Charts for Reference and Working Standards General Measurement Device and Calibration Topics 6
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
E Performance Charts - Purchasing Department and Material Control Department Preventive Action and Continuous Improvement 6
J Control Charts with different Sample Sizes Reliability Analysis - Predictions, Testing and Standards 2
T why CPK <1.0 regarding two pieces of control charts of torque wrench? Statistical Analysis Tools, Techniques and SPC 2
R Electronic Templates for making Paper Control Charts Document Control Systems, Procedures, Forms and Templates 9
S Multivariate Control Charts in Chemical Batch Processing Statistical Analysis Tools, Techniques and SPC 7
G Control Charts - Plotting Unwanted Data Excel .xls Spreadsheet Templates and Tools 5
Y Control Charts + Ishikawa Manufacturing and Related Processes 26
N SPC Light Program - Easy way of Cpk extraction from multiple control charts Statistical Analysis Tools, Techniques and SPC 4
K Calculating Control Limits in Average and Range Charts Statistical Analysis Tools, Techniques and SPC 3
G Adjusted Control Limits - Usage of Control Charts Statistical Analysis Tools, Techniques and SPC 26
U P Charts - Subgroup Sizes? Process Control Indicator Statistical Analysis Tools, Techniques and SPC 3
E Which control charts to monitor waste produced on the shop floor Statistical Analysis Tools, Techniques and SPC 5
J Control limits for one sided control charts using WECO rules Statistical Analysis Tools, Techniques and SPC 5
T Rules for interpreting control charts Statistical Analysis Tools, Techniques and SPC 2
G Control charts of finished product characteristics..NonSense? Statistical Analysis Tools, Techniques and SPC 8
D Control limit calculation (Xbar R charts) using Minitab Statistical Analysis Tools, Techniques and SPC 14
H How to create Stoplight Control charts with excel? Excel .xls Spreadsheet Templates and Tools 16
S Calculating 1 sigma and 2 Sigma limits in Control Charts Statistical Analysis Tools, Techniques and SPC 1
M Control Charts - Points TOUCHING Limits = Stable? Statistical Analysis Tools, Techniques and SPC 12
T What is Average Run Length & Average Production Length when used in Control Charts? Statistical Analysis Tools, Techniques and SPC 4
T Using SPC Control Charts to Reduce AQL Sample Size AQL - Acceptable Quality Level 16
B Recommendation for a book to Explain Control Charts Book, Video, Blog and Web Site Reviews and Recommendations 6
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
K Understanding Control Charts Methodology for Attributes like Plug Guages. Statistical Analysis Tools, Techniques and SPC 1
J Selection Procedure for the Use of Control Charts (Apendix C) Statistical Analysis Tools, Techniques and SPC 2
B Reaction to Out of Control SPC Charts Statistical Analysis Tools, Techniques and SPC 14
J Run Charts and Alternative Process Control Parameters Statistical Analysis Tools, Techniques and SPC 5
Steve Prevette Example SPC Control Charts posted by the Department of Energy EFCOG Statistical Analysis Tools, Techniques and SPC 1
B Why is the Mean preferred over Median in Control Charts? Statistical Analysis Tools, Techniques and SPC 12
R 100% Control and Control Charts Statistical Analysis Tools, Techniques and SPC 4
