Control charts of finished product characteristics..NonSense?
G
guyramesh
My dear quality gurus;
I have always believed in plotting and monitoring control charts of input parameters which directly affect characteristic of process output or end product.
However, my supplier is providing 'control charts'? based on characteristic of end product batches packed on different dates,complete with USL, UCL, LSL, LCL.
Does charting end product characteristics over many batches considered SPC control?
Please refer to attached chart example. Need your support to face my mgmt and straighten this thing once and for all.
rgds,
Ramesh.
DsqrdDGD909
rgds,
Ramesh.
I'm sorry, but I don't understand. Is the chart showing individual lots or averages of lots?
G
Geoff Withnell
rgds,
Ramesh.
What your supplier is giving you is evidence that his process is in control and the characteristics charted are within the requirements you have set. I would not myself send outside my organization the actual "process control" charts. How I control my process is proprietary. What you as a customer need is evidence that the process producing the product is in control (evident from the output characteristics being in control) and the product meets the specs (evident from the control limits on the output characteristics).
Geoff Withnell
bobdoering
Stop X-bar/R Madness!!
rgds,
Ramesh.
Well, it is a type of charting methodology called "report card charting". It indicates that the aggregate of controls prior to the finished product is effective. Is it the best use of charting? No...but is is one use. If the aggregate is so far in control, then it may be suitable for verifying outgoing product quality level and significant changes, when they occur. The best use is plotting and monitoring control charts of input parameters which directly affect characteristic of process output or end product! :tg:
Darius
IMHO, while is the same product (and no change whatsoever on it) and no special filtering on the data, could show the control your supplier have on the process, so SPC, your supplier could give you a cpk or ppk value, but is giving you the actual data in order to show that that property is a don't-worry characteristic for you. You may say that you can't actually do nothing on a death corpse, but as a statesman said more or less "the country that doesn't know it's history is condemed to repite it"
:2cents:, the stats hide information if the data doesn't behave in a "normal gaussian way", so no trends or "non gaussian distribution" that can be hiden on an indicator. I am agree that SPC is more or less distribution sensitive (without the rules), but the indicator is not, but we (I include my self) are more confortable with a number than with a chart in order to compare the actual behaviur against the previous ones.
btw. the chart looks with very few data (bad thing, so the chart is telling you nothing) and a little close to the limit (not centered on specs), remember that "Quality is low variation on target".
Geoff Withnell
I've seen situations where suppliers didn't want to send a customer a PFMEA and sometimes a control plan--documents that do include proprietary information, but I've never had one refuse to supply control charts, especially where PPAP is concerned. There's nothing that should be considered proprietary or secret in a control chart, unless the supplier is trying hide something.
Yes! But it's also important to note that the thing that's missing from ex post facto charts is the chronological element.
bobdoering
It is grossly chonological...but, I agree, it will provide very little information for adjusting the process - or even saying where in the process there needs an adjustment- if an out of control condition occurs. It can only initiate a corrective action investigation. Clearly, report card charts are the weakest....but better than nothing.
I actually require these charts from our suppliers. I think Context is important here. Bob/Jim: you are correct that for the supplier control charts on inputs are much more valuable especially when the intent is to control the process (as you say Bob for adjustment). However, for the Customer, as the Customer, I really need to know that the supplier is meeting my drawing requirements and is stable and capable. This way I can get rid of incoming inspection of parts and have some confidence in their ability to meet my delivery requirements. I also have to remember that sometimes the factor that goes wacky and makes my parts not meet spec isn't oen that is on the control plan and so a control chart on the output (blueprint) characteristic makes sense and has value.
Now I do require the supplier to understand his input characteristics and how they effect the output, set appropriate tolerances and have the appropriate controls in place for those inputs. I will aslo audit those charts on occassion but I do incoming inspection on the output control charts not the parts.
E Control Charts ISO 17025 related Discussions 7
PQ Systems Understanding Capability and Control Charts Series Using SQCpack Software 0
PQ Systems Control Charts & Capability Analysis 101 Using SQCpack Software 0
D How to calculate the A4 constants in Median/Range control charts? Statistical Analysis Tools, Techniques and SPC 2
S Use of Attributes Control Charts Statistical Analysis Tools, Techniques and SPC 1
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
N Injection Molding - Median individual control charts Statistical Analysis Tools, Techniques and SPC 6
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
M Interpreting X bar and R Control Charts Statistical Analysis Tools, Techniques and SPC 2
M Large Sample Size - up to 32 - for Control Charts Capability, Accuracy and Stability - Processes, Machines, etc. 2
T Is the use of Control Charts Mandatory or Optional? ISO 17025 Requirements ISO 17025 related Discussions 6
E Minitab for hourly patient census - Control Charts Using Minitab Software 6
J Using P-Charts for Glass Manufacturing to Monitor and Control Attributes Statistical Analysis Tools, Techniques and SPC 2
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
S Help with Table of Constants and Formulas for Control Charts Statistical Analysis Tools, Techniques and SPC 5
Q Monthly Data Review through Control Charts - Monitoring Complaints ISO 13485:2016 - Medical Device Quality Management Systems 3
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Suitability of Attribute Control Charts for ppm Level Control Statistical Analysis Tools, Techniques and SPC 6
R Metrology Control Charts for Reference and Working Standards General Measurement Device and Calibration Topics 6
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
E Performance Charts - Purchasing Department and Material Control Department Preventive Action and Continuous Improvement 6
J Control Charts for 29 Devices that I tested Reliability Analysis - Predictions, Testing and Standards 10
J Control Charts with different Sample Sizes Reliability Analysis - Predictions, Testing and Standards 2
T why CPK <1.0 regarding two pieces of control charts of torque wrench? Statistical Analysis Tools, Techniques and SPC 2
R Electronic Templates for making Paper Control Charts Document Control Systems, Procedures, Forms and Templates 9
S Multivariate Control Charts in Chemical Batch Processing Statistical Analysis Tools, Techniques and SPC 7
G Control Charts - Plotting Unwanted Data Excel .xls Spreadsheet Templates and Tools 5
Y Control Charts + Ishikawa Manufacturing and Related Processes 26
N SPC Light Program - Easy way of Cpk extraction from multiple control charts Statistical Analysis Tools, Techniques and SPC 4
K Calculating Control Limits in Average and Range Charts Statistical Analysis Tools, Techniques and SPC 3
G Adjusted Control Limits - Usage of Control Charts Statistical Analysis Tools, Techniques and SPC 26
U P Charts - Subgroup Sizes? Process Control Indicator Statistical Analysis Tools, Techniques and SPC 3
E Which control charts to monitor waste produced on the shop floor Statistical Analysis Tools, Techniques and SPC 5
J Control limits for one sided control charts using WECO rules Statistical Analysis Tools, Techniques and SPC 5
T Rules for interpreting control charts Statistical Analysis Tools, Techniques and SPC 2
D Control limit calculation (Xbar R charts) using Minitab Statistical Analysis Tools, Techniques and SPC 14
H How to create Stoplight Control charts with excel? Excel .xls Spreadsheet Templates and Tools 16
S Calculating 1 sigma and 2 Sigma limits in Control Charts Statistical Analysis Tools, Techniques and SPC 1
M Control Charts - Points TOUCHING Limits = Stable? Statistical Analysis Tools, Techniques and SPC 12
T What is Average Run Length & Average Production Length when used in Control Charts? Statistical Analysis Tools, Techniques and SPC 4
T Using SPC Control Charts to Reduce AQL Sample Size AQL - Acceptable Quality Level 16
B Recommendation for a book to Explain Control Charts Book, Video, Blog and Web Site Reviews and Recommendations 6
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
K Understanding Control Charts Methodology for Attributes like Plug Guages. Statistical Analysis Tools, Techniques and SPC 1
J Selection Procedure for the Use of Control Charts (Apendix C) Statistical Analysis Tools, Techniques and SPC 2
B Reaction to Out of Control SPC Charts Statistical Analysis Tools, Techniques and SPC 14
