Control Charts - Points TOUCHING Limits = Stable?
misguided_will
hiall
i have a control chart that has data points that TOUCH but do not breach the control limits.
by touching, not breacing.. is the process considered stable or unstable?
thanks
Re: Control Chart: points TOUCHING limits = stable?
It is important to remember that Shewhart developed the control chart for the economic control of processes. He recommended 3 standard deviation limits as the best economic balance between false alarms (a signal that the process is out of control, but is not) and failure to alarm when the process is actually out-of-control.
Therefore, it is legitimate for you to define this economically in your procedures. What action should you economically take to this point. Ignore it or react? Define it accordingly in your procedures.
Note: Use the same judgement on the extended rules (trends, runs, etc.). Each rule has an individual error rate (false alarm rate) of approximately 0.3%-0.4%. The more rules that you use the greater the overall false alarm rate. If you use all of the extended rules, the overall false alarm rate will be approximately 3%. That is, 3 of every 100 subgroups will be out-of-control by random chance alone.
I recommend that you decide which extended rules add value and use only those rules. Base this on your process. If your process does not trend out of control, or drift slowly out-of-control creating runs, do not use these rules. Again, this is an economic decision.
Stijloor
Miner,
Excellent response! :applause:
Keep in mind that the OP claims to be a student.
sorry if i'm a little vague...totally newbie..just a colleage student.
He may not in a position to make "economically-based decisions" about when to adjust the process or when to leave it alone.
He, in this case, should consider various hypothetical decision-making scenarios...
FWIW, just my :2cents:
Stijloor.
I am guessing that this was from a post in a different thread as I don't see it in this thread, but good catch.
In that case, I would treat this similar to the criteria for a hypothesis test where the null hypothesis is not rejected unless p < alpha. By this reasoning, the null hypothesis is that the process is in control and you do not reject the null unless p < alpha, so a point must be beyond the limit to reject the null.
Stijloor
That's right. I read his other posts. He is working on a "home work" assignment.
Stijloor.
Steve Prevette
Deming Disciple
I've settled on the interpretation that the point must be outside of the limit to count. Generally in a variables chart it would be rare that a point would exactly be on a limit. On a c-chart, the most common problem is when the average works out to be a perfect square, such as 1.0, 4.0, 9.0; and the three, two, and one standard deviation lines are whole numbers.
P
pagnonig
I have a variable sample size p-chart where 2 points are exactly equal to the respective UCL.
In order to discriminate about noise ans signal I've decided to plot a normalized Z chart and both points are above +3s limit... so, maybe some special cause here...
Do you think this can be a good approach?
Regards.
G
Geoff Withnell
Regards.
The way i would look at it is that points at the limit should, if the process is stable, be fairly infrequent. If you have two in a short period of time, it seems worth investigating.
Geoff Withnell
bobdoering
Stop X-bar/R Madness!!
Two things:
1. Is there a rate at which the process approached the control limit, or did it jump there? Do any of the Western Electric rules apply?
2. I guess my biggest question is, what if it is out of control? What is you response to the out of control action? If it is that close, is it effective to begin the response now?
Are you overthinking this? It depends....:cool:
S Use of Attributes Control Charts Statistical Analysis Tools, Techniques and SPC 1
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
Rameshwar25 Other types of Control Charts described in Chapter II of SPC Manual Statistical Analysis Tools, Techniques and SPC 6
S Standard Deviation Selection on Control Charts - Minitab "pooled deviation" Statistical Analysis Tools, Techniques and SPC 3
N Injection Molding - Median individual control charts Statistical Analysis Tools, Techniques and SPC 6
Chennaiite Do Attribute Control Charts really help? Statistical Analysis Tools, Techniques and SPC 9
B Setting Lower Control Limit on Attributes Charts Statistical Analysis Tools, Techniques and SPC 9
M Interpreting X bar and R Control Charts Statistical Analysis Tools, Techniques and SPC 2
M Large Sample Size - up to 32 - for Control Charts Capability, Accuracy and Stability - Processes, Machines, etc. 2
T Is the use of Control Charts Mandatory or Optional? ISO 17025 Requirements ISO 17025 related Discussions 6
E Minitab for hourly patient census - Control Charts Using Minitab Software 6
J Using P-Charts for Glass Manufacturing to Monitor and Control Attributes Statistical Analysis Tools, Techniques and SPC 2
M On Subgroups in Control Charts and Process Capability Statistical Analysis Tools, Techniques and SPC 3
S Help with Table of Constants and Formulas for Control Charts Statistical Analysis Tools, Techniques and SPC 5
Q Monthly Data Review through Control Charts - Monitoring Complaints ISO 13485:2016 - Medical Device Quality Management Systems 3
R "Control" as used in 4.1 c) - Process Flow Charts (Process Sequence Chart) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D Suitability of Attribute Control Charts for ppm Level Control Statistical Analysis Tools, Techniques and SPC 6
R Metrology Control Charts for Reference and Working Standards General Measurement Device and Calibration Topics 6
D One-Two-Three Sigma Control Limits - Calculating Control Limits for X-bar Charts Statistical Analysis Tools, Techniques and SPC 3
bobdoering Myth or Mythunderstanding: Implications of the Economic Design of Control Charts Statistical Analysis Tools, Techniques and SPC 1
E Performance Charts - Purchasing Department and Material Control Department Preventive Action and Continuous Improvement 6
J Control Charts for 29 Devices that I tested Reliability Analysis - Predictions, Testing and Standards 10
J Control Charts with different Sample Sizes Reliability Analysis - Predictions, Testing and Standards 2
T why CPK <1.0 regarding two pieces of control charts of torque wrench? Statistical Analysis Tools, Techniques and SPC 2
R Electronic Templates for making Paper Control Charts Document Control Systems, Procedures, Forms and Templates 9
S Multivariate Control Charts in Chemical Batch Processing Statistical Analysis Tools, Techniques and SPC 7
G Control Charts - Plotting Unwanted Data Excel .xls Spreadsheet Templates and Tools 5
Y Control Charts + Ishikawa Manufacturing and Related Processes 26
N SPC Light Program - Easy way of Cpk extraction from multiple control charts Statistical Analysis Tools, Techniques and SPC 4
K Calculating Control Limits in Average and Range Charts Statistical Analysis Tools, Techniques and SPC 3
G Adjusted Control Limits - Usage of Control Charts Statistical Analysis Tools, Techniques and SPC 26
U P Charts - Subgroup Sizes? Process Control Indicator Statistical Analysis Tools, Techniques and SPC 3
E Which control charts to monitor waste produced on the shop floor Statistical Analysis Tools, Techniques and SPC 5
J Control limits for one sided control charts using WECO rules Statistical Analysis Tools, Techniques and SPC 5
T Rules for interpreting control charts Statistical Analysis Tools, Techniques and SPC 2
G Control charts of finished product characteristics..NonSense? Statistical Analysis Tools, Techniques and SPC 8
D Control limit calculation (Xbar R charts) using Minitab Statistical Analysis Tools, Techniques and SPC 14
H How to create Stoplight Control charts with excel? Excel .xls Spreadsheet Templates and Tools 16
S Calculating 1 sigma and 2 Sigma limits in Control Charts Statistical Analysis Tools, Techniques and SPC 1
T What is Average Run Length & Average Production Length when used in Control Charts? Statistical Analysis Tools, Techniques and SPC 4
T Using SPC Control Charts to Reduce AQL Sample Size AQL - Acceptable Quality Level 16
B Recommendation for a book to Explain Control Charts Book, Video, Blog and Web Site Reviews and Recommendations 6
C Designing Control Charts - Variable with Small Variation and Tight Control Limit Statistical Analysis Tools, Techniques and SPC 20
K Understanding Control Charts Methodology for Attributes like Plug Guages. Statistical Analysis Tools, Techniques and SPC 1
J Selection Procedure for the Use of Control Charts (Apendix C) Statistical Analysis Tools, Techniques and SPC 2
B Reaction to Out of Control SPC Charts Statistical Analysis Tools, Techniques and SPC 14
J Run Charts and Alternative Process Control Parameters Statistical Analysis Tools, Techniques and SPC 5
Steve Prevette Example SPC Control Charts posted by the Department of Energy EFCOG Statistical Analysis Tools, Techniques and SPC 1
B Why is the Mean preferred over Median in Control Charts? Statistical Analysis Tools, Techniques and SPC 12
R 100% Control and Control Charts Statistical Analysis Tools, Techniques and SPC 4
