Control Methods in Control Plan
Hello All,
I'm hoping you can help answer a question I have in regards to the Control Methods column in the Control Plan.
Can you have Control Methods listed in the CP that are NOT listed in the Prevention or Detection Control columns of the PFMEA?
The scenario I'm thinking is this: you start developing the Control Chart and while populating the Control Methods column you come up with additional controls which have not been documented in the PFMEA. Do you need to go back to the PFMEA and update the Detection/Prevention Controls columns?
Is there ever a situation where a Control Method in the Control Plan would not need to be listed in the PFMEA as a Detection or Prevention control?
Thank you very much in advance!
Jen Kirley
Quality and Auditing Expert
Welcome Ralumar!
Chapter 6 of the APQP Manual (2nd Ed.) published by AIAG says, among other things:
In effect, the control plan describes the actions that are required at each phase of the process including receiving, in-process, out-going, and periodic requirements to assure that all process outputs will be in a state of control. During regular production runs, the control plan provides the process monitoring and control methods that will be used to control characteristics.
I would not expect to see any mention of specific product or process monitoring techniques in the pFMEA.
John C. Abnet
Teacher, sensei, kennari
As @Jen Kirley accurately stated...., not expected in the PFMEA
This is often an area of confusion, even amongst some that train PFMEA creation and use. The intent of the PFMEA is not to list the control details (that is why the control plan is called, well,...CONTROL plan.) Often the PFMEA controls can simply point TO the control plan. It is risky at best to redundantly place detail of controls in multiple locations. It becomes a document control nightmare preventing contradictions/inaccuracies.
Hope this helps.
Be well.
Some clarification is needed here. What the OP is apparently referring to is the two columns in the PFMEA form for "Current Process Controls--Prevention" and "Current Process Controls--Detection." Note that this apparently refers to the older version of the PFMEA form.
This has caused some confusion in the past, because for a completely new product there won't be any current process controls. In such a case the proposed process controls should be a part of the "Recommended Actions." In a case where a new product is substantially similar to an existing one, the detection/prevention process controls may be used as "current." The bottom line is that process controls should always form a part of a PFMEA. Remember--the PFMEA precedes and informs the control plan.
To answer the OP's question, the controls listed on the control plan should always be traceable to the PFMEA.
Thank you All for your feedback!
Yes, I am using an older version of the PFMEA. It lists two separate columns, one for current Detection controls and another for current Prevention Controls.
Can I also tune in?
We are thinking about copying:
PFMEA current prevention control (linked to failure cause) --> CP control method
PFMEA current detection control (linked to failure mode or cause) --> CP evaluation technique
Would that be accurate?
They are built in the same software package, so no risk to have incorrect "double" data.
If we find something new during CP review (or reverse PFMEA audit), we update the PFMEA as well.
Yet, some control methods are in place to make sure the evaluation technique is working as planned (e.g. checking the measurement system with a reference part: detection of detection, or is that not correct?), so it would not be linked to prevention controls in PFMEA?
Another option we were thinking of is to put the detection controls in the PFMEA also as process step, with their own failures modes, causes and detections, but if you go that route everything becomes blurry: you can make infinite loops...
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
K Alternate Control Methods (IATF 16949 Cl. 8.3.6.1) IATF 16949 - Automotive Quality Systems Standard 1
Gman2 Control of Records - Lets talk about modern methods Records and Data - Quality, Legal and Other Evidence 5
K Control Plan vs PFMEA Control Methods FMEA and Control Plans 1
M Are 'Error Proofing Methods' required to be mentioned in Control Plans? FMEA and Control Plans 7
T Paper Quality Manual Change Control Methods Quality Management System (QMS) Manuals 5
R Control Methods for Helpdesk Reporting Service Industry Specific Topics 1
J Methods to control Efficiency of Corrective and Preventive Actions Quality Manager and Management Related Issues 9
G Methods for the Control of Forms ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
O Methods used to Control Outsourced Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
L Why the difference in control limit value when using different calculation methods? Statistical Analysis Tools, Techniques and SPC 2
L Customer requirement to create a Guide for defining Control Methods FMEA and Control Plans 9
somashekar Control Over Outsourced Processes - Share some experiences and methods ISO 13485:2016 - Medical Device Quality Management Systems 6
kedarg6500 Guidance List for Control Methods in Control Plans? IATF 16949 - Automotive Quality Systems Standard 3
D 7.5.1.1 - Controls vs. Methods for Monitoring of Control IATF 16949 - Automotive Quality Systems Standard 2
Q Control methods - What exactly are 'control methods' in a Control Plan APQP and PPAP 6
M Process control methods - Seeking Examples ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T Control Methods in Control Plans FMEA and Control Plans 1
R 8.7 Control of Nonconforming Outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
W Document control Document Control Systems, Procedures, Forms and Templates 10
S Control plan - Multiple batches Manufacturing and Related Processes 2
Q Control Plan and the frequency of sampling FMEA and Control Plans 7
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
qualprod Sheets into a spreadsheet document control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
C Control Plan APQP and PPAP 7
D Control of Records ISO 13485:2016 - Medical Device Quality Management Systems 7
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 5
L Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
S Control plan for "highly automated processes" FMEA and Control Plans 3
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
R SCORING OF MILLER MARITAL LOCUS OF CONTROL SCALE Coffee Break and Water Cooler Discussions 2
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
M Design Control Procedure Medical Device and FDA Regulations and Standards News 4
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Humane Pest Control Food Safety - ISO 22000, HACCP (21 CFR 120) 1
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
B QM Plan vs Control Plan IATF 16949 - Automotive Quality Systems Standard 3
N AS 13004 Control Plan and AQL FMEA and Control Plans 1
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
qualprod Traceability with no rules to control labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Doubt about the correct control chart Statistical Analysis Tools, Techniques and SPC 14
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
Z Setting the Control limits on Minitab Using Minitab Software 4
C Elaborating a control chart with skewed data Manufacturing and Related Processes 4
M Who is performing quality control? IATF 16949 - Automotive Quality Systems Standard 2
S Risk control through Information for safety ISO 14971 - Medical Device Risk Management 8
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
Q Control limits Six Sigma 6
