The harness board is analogous to an injection mold or die casting mold. You should control the harness board the same way you would control the mold. This is to prevent making the harness to the wrong revision.
I agree with Mr. Al Rosen
I worked before in a cable harnesses factory with customers such as BMW, VW, Daimler Chrysler.
It’s very logical that you should control your boards to be sure that the board drawing is in the same version with the product drawing. In plus when the board is build or change you should check that all the nails, pins (or whatever technology you use) and all info from the Board have the same change level with the product drawing.
How is made the control is up to you. In my previous company the control was made by the persons who was in charge also for product audit or by the quality inspectors (and were qualified for this).
The engineer who is responsible for board drawing print a small label in which is describe what type of board is, for which product(s) can be use and the revision level. He signs this label.
If are some problem are found during the control, the person who made the control should inform the board drawing engineer and this must fix all the problems.
After all the problems are fixed the person who made the control also sign the label and the board is approved and can be use to produce harnesses.
I wish you all the best,
Alin
