Control of a process that runs in multiple locations
RMedrano
If you have a process that runs on 4 machines...
2 sets of 2 power presses
We use SPC to check a particular dimension on the finished part.
When we had out Paper SPC system we would use one chart for each pair of machines.
Now with our new computerized system there is only one chart. Both machines are now plotting on the same chart.
Should we react the exact same way now as when we had the 2 paper ones?
say if we get a 7 point run above the center line..
would we adjust one set of presses to bring its AVG down? or would we adj both?
all of the parts coming off of the presses all feed into the same machine at the end of the assembly lines.
Bill Pflanz
You don't say if you were involved with the decision when you computerized but what reason do you have for doing both machines on one chart? I would treat each machine as a separate process and control chart them separately since it is unlikely they would behave exactly the same. More than likely, the original reason for 2 separate charts was to identify which machine needed attention or was causing defective parts.
When you plot two or more separate processes on a single control chart, the out of control limit rules would no longer apply. By adjusting one press, I agree you can get the average down but it could be at the cost of making both presses controlled improperly and you could increase your defects in the next process. Many times a histogram of the data can show the two processes in a very visible way (a two humped normal distribution) and could be used as the argument for going back to separate control charts.
Bill Pflanz
Bill Ryan - 2007
I'm with Bill. I'd hope your SPC software requires some type of inputs to start the measuring process. One of those inputs should be "Machine #" and you should be able to sort data/graphs by that variable. Doing it the way you are sounds like it could very easily lead to "tampering" (which causes more variation).
Bill
RMedrano
Bill
Its not so much not being able to separate the data thats the issue... I can do that easily with the software, yes I can have them enter a machine number before they gauge and it will tag that data with the machine number... the issue is more in terms of reaction.
Right now we are testing the software so we are using both paper charts and the computer system. The two paper charts are saying that each process is currently running in control, however in the computer because all of the data is collected together it is telling the operators that they have a 7 point run and need to react, which is confusing them.
I was looking for more of a feeling of how others collect data in thier facilities when they have multiple machines all making the same component.
My thoughts on this were that we have 3 sets of Dies for the presses and to number the Dies somehow that they are easily identifiable, then create a chart in the computer for each set. So the operators would then have to choose which chart to measure on .
I agree with the Bill's. The two processes may be as similar as you like, but no matter how you look at it you still have two processes. They should be on separate charts. As it is you are trying to control two processes with just one set of controls.
/Claes
Steve Prevette
Deming Disciple
I suppose I would vote for plotting both the consolidated chart and individual machine charts. The consolidated chart can quickly react to something that is in common across the machines that perhaps the individual charts would not catch so quickly. The individual charts can of course capture a trend specific to an individual machine.
Similar situation at work here. I do hundreds of injury rate charts, at three different levels. Sometimes I see things at the higher levels I can't see on the lower levels (since they are so infrequent) and vice versa.
Bill Pflanz
I agree with Steve's comment about one chart for a high level view of the process. My only concern was that Mr. Medrano wanted to change one press to get the total average in control which could be risky. He would not know which press to change without the individual charts.
He also provided additional information in his last posting that indicated that there were 3 sets of dies that could be used interchangeably in any press. If I am understanding the process correctly then he will need control charts that monitor the effect of each set on each press. That is a more complicated system to monitor since there is normal variation in each press plus variation caused by using different dies.
Let me know if I am interpreting it correctly.
Bill Pflanz
G
Graeme
A fundamental concept of process control charts is that a single chart describes the behaviour of a single process. I just pulled some books at random off my shelf and found these:
Griffith 1996 said:
VARIOUS CONTROL CHARTING ERRORS TO AVOID
Control charts can be misplotted for seveal different reasons. Plotting errors on a control chart will cause poor decisons to be made on the operation of the process. some specific errors to avoid are:
Measurement errors, ...
Miscalculations, ...
Misplotting, such as using one chart for two different processes, ...
Data entry erors (using SPC software), ...
(Statistical Process Control Methods for Long and Short Runs, 2nd Edition. Gary K. Griffith. ASQ Quality Press, 1996. Pages 201-202.)
Besterfield 1990 said:
Regardless of the scheme used to obtain the subgroup, the lots from which the subgroups are chosen must be homogenous. By homogenous is meant that the pieces in the lot are as alike as possible -- same machine, same operator, same mold cavity and so on.
(Quality Control, 3rd Edition. Dale H. Besterfield. Prentice-Hall, 1990. Page 74.)
ANSI/ASQC B3-1996 said:
2.3.3 On the basis of the analysis of the process (2.2), decide how the observed results are to be grouped so that the articles in any subgroup are produced under the same essential conditions. ...
(ANSI/ASQC B3-1996, Control chart method of controlling quality during production.)
Juran's Quality Handbook also has information on this, but I don't have my copy handy for a reference. As I recall, there is even a diagram showing two process streams being mixed.
For each process stream (set of presses) the interest is normally variation within that process over time. That monitors the process and allows making judgements on tool wear, maintenance requirements, process adjustment and so on. Even two "identical" machines (or sets of machines) will have enough differences that they are separate production processes.
Plotting the output of several processes on one chart may be an indicator of variation between the processes (Steve?) that may be useful on a higher level -- but not for evaluation of the individual process streams.
In my opinion, if the software is not capable of analyzing the process streams separately then the problem is the software. To agree with what Steve said, producing one combined chart may be useful for some purposes, but producing a chart for each process stream is essential for knowledge of how the process is working.
Steve Prevette
Deming Disciple
I would agree. If I HAD TO choose between individual charts or a consolidated chart, I would choose individual charts. But in these days of automated data gathering and Excel spreadsheet, I don't think you have to choose one or the other.
Dr. Deming in Out of the Crisis on pages 354 - 355 points out the hazards of mixing product from three sources into one chart.
W Need for current design or process control FMEA and Control Plans 2
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
K Process Mapping - Inputs/Outputs/Detail Activities/Control points/Measurement? Process Maps, Process Mapping and Turtle Diagrams 4
A UDI and Design Controls - Labeling change via the Design Control process 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
R Software change control process and defect tracking ISO 13485:2016 - Medical Device Quality Management Systems 1
eule del ayre Merging FMEA and Quality Control Process Flow FMEA and Control Plans 0
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
K AIAG/VDA FMEA & Process Control Plans FMEA and Control Plans 0
A Process Control / Control Charting Procedure Capability, Accuracy and Stability - Processes, Machines, etc. 1
Marc Steve Prevette's Statistical Process Control (SPC) "Library" Statistical Analysis Tools, Techniques and SPC 0
Y Informational Change control process - Major vs Minor change - Active class III medical devices ISO 13485:2016 - Medical Device Quality Management Systems 12
S SPC (Statistical Process Control) for Unilateral Tolerance - Questions Statistical Analysis Tools, Techniques and SPC 6
L Control Plan - Multiple Process Steps FMEA and Control Plans 8
C Design Transfer - How do you guys control the design transfer process? Document Control Systems, Procedures, Forms and Templates 5
B Documented process for type and extent of control IATF 16949 - Automotive Quality Systems Standard 6
T Hot dogs and process operation and control effectiveness? 4.1.3 a) ISO 13485:2016 - Medical Device Quality Management Systems 2
Q Bespoke Machinery Process Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
A Statistical Process Control and Inspection in Footwear Production Statistical Analysis Tools, Techniques and SPC 0
V For a Drug-Device Combination Product, 'Design Control' Process is triggered at? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C What is an Airbus Industrial Process Control Assessment (IPCA) Audit Passing Score General Auditing Discussions 1
P Minitab Data Analysis - Understanding if a Process is in Control or Not Using Minitab Software 2
B IATF 16949 Clause 8.5.6.1.1 (Temporary Process Control Change) IATF 16949 - Automotive Quality Systems Standard 24
N YS Class in DFMEA & Process Control Measures FMEA and Control Plans 1
T IATF 16949 Control Plan and Process Monitoring Requirement(s) IATF 16949 - Automotive Quality Systems Standard 1
M Cross Function Process Map for Document Control Process Maps, Process Mapping and Turtle Diagrams 3
Steve Prevette Statistical Process Control Library Statistical Analysis Tools, Techniques and SPC 17
S Regression Control Chart - Process Capability Statistical Analysis Tools, Techniques and SPC 18
Q Incomplete Process Sheets Closure - DHR - Doc Control Document Control Systems, Procedures, Forms and Templates 3
I Control of Outsourced Process - Shipping ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
A API Certification - In Process Control Oil and Gas Industry Standards and Regulations 5
C Customer control of supplier's process Misc. Quality Assurance and Business Systems Related Topics 5
M ISO 22000 7.3.5.2 Description of Process Steps and Control Measures Food Safety - ISO 22000, HACCP (21 CFR 120) 1
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
T Electronic Document Control - Posting a process at work station ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L ISO 9001 Operation Process Control Requirements ("Carta de Control de Proceso") ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
O Process Startup Only items in a Control Plan FMEA and Control Plans 1
C List Error Proofing in the Process FMEA or the Control Plan FMEA and Control Plans 2
S TS 16949 Outside Process Control Requirements IATF 16949 - Automotive Quality Systems Standard 3
P Purchasing Process Out of Control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M In-Process Quality Control Job Scope Misc. Quality Assurance and Business Systems Related Topics 4
S FMEA Process Step or Current Control FMEA and Control Plans 3
Q Chrysler required FMEA and Control Plan Document Audit Forms and Process Audit Check FMEA and Control Plans 7
B Process Control - Selecting Parts - NDC & Study Variation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
M Process Flow Diagram -> PFMEA -> Control Plan Linkage IATF 16949 - Automotive Quality Systems Standard 17
Moncia Statistical Process Control Crash Course - Question Quality Manager and Management Related Issues 10
J Why are there Customer Complaints when the process is in control? Six Sigma 24
