Control of COTS (Commercial Off The Shelf) Specifications
rothlis
We are a small medical device manufacturer, with a quality system operating primarily under ISO 13485 with future plans to operate under FDA quality requirements. We are using a paper document control system and have historically approved a separate specification document for every component or material used in a product. Recently, however, we have considered the possibility that there are many cases where this creation of separate approved documents might be overkill.
In particular, the details regarding the components on a PCB, or raw materials used on a molded, cut or machined part, are often only actually used in practice to the extent that the make and model are communicated to the CM as inputs to the process of creating the PCB assembly or custom part. The proposal we are entertaining is that the make and model can simply be defined on the drawing or BOM of the assembly where it is used (in cases where that is sufficient information), so that the parent assembly is the only controlled specification document.
  • Do you feel that this is adequate to meet ISO 13485 and FDA requirements (assuming a company policy exists to verify that the correct product is received)? Is it perhaps already an accepted practice?
  • If this approach is used where the CM manages purchasing and receiving, does the parent assembly specification (or contract?) need to require that the CM verify the input components and materials on receiving inspection? Or would that only apply if the CM isn't itself certified to 13485 or 9001?
Appreciate your thoughts on the matter. Thanks.
yodon
Another apology for not responding to this sooner.
The 'manufacturer of record' is always ultimately responsible for ensuring all regulatory requirements are met. If some are flowed down to a CM, it's your responsibility to ensure they are complying.
FDA lays out purchasing data requirements in 820.50(b) and it's spelled out in much more detail in 13485 in 7.4.2 and 7.4.3. In 13485, there is certainly the concept of documentation commensurate with the risk. And what you describe (verifying the correct product is received is, I believe, generally the case for such commercial components. The CM needs to confirm the part meets the spec (typically in a BOM rather than a drawing) and then provide whatever traceability is required.
rothlis
Thank you yodon. When I reviewed the regulations I came away with the impression that if a part is specified only on the BOM of a parent assembly, then this satisfies the regulations if:
a) the entry on the controlled BOM of the parent assembly is sufficient to inform receive inspection, and
b) measures are in place to ensure that receiving inspection is conducted against the controlled BOM of the parent assembly (whether that's in-house or at a CM).
So my concern is primarily from lack of experience, having only ever worked at companies where every individual part is controlled as its own separate specification document. By abandoning that, I just want to make sure we aren't straying into some sort of unprecedented territory that will raise eyebrows.
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
C UDI Questions on Control Units Other US Medical Device Regulations 6
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Control-self assessment Internal Auditing 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
A Prototype control plan FMEA and Control Plans 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
T Risks arising from control measures vs. ineffective control measures ISO 14971 - Medical Device Risk Management 11
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
W Need for current design or process control FMEA and Control Plans 2
Q ISO 9001 8.5.1 - Control of production and service performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
J 510(k) for a control kit for an external IVD test kit 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
T Design Control Procedures later in the Development Process ISO 13485:2016 - Medical Device Quality Management Systems 6
L AS5553 Clause 3.1.7 e "Control packaging material ..................reused" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
