Control of Documents Scope - Product Specifications
neash83
Hello all,
I'm just looking for some further clarification and opinions as to the scope of the Control of Documents clause in 9001.
Would you be of the opinion that it applies to product specifications?
We have internal product specifications that detail the components, components numbers, dimensions, colours etc and while these are controlled to a usable extent, they aren't controlled in accordance with 4.2.3:
-Changes do not appear to be identified between revisions
-There doesn't seem to be a formal approval route between revisions
I want them in accordance with the standard irrelevant of the scope of 4.2.3, but won't have the same clout in getting it this way if they are considered outside the scope of 4.2.3.
So thoughts????
The answer would probably found in 4.2.1 d). Are these documents necessary for the planning, operation and control of your processes? In other words, if the documents were incorrect, would it have negative impact? If the information correctness is important, then they have to be controlled.
ISO 9001 is very general as to how these will be controlled. In the two areas you mentioned (identification of changes and approval), there is a lot of flexibility. Your use of the word "formal" brings an image of filling out some form, and having sign-offs for the document. But that might not be necessary. Don't tie your hands here. You want control, but it must be balance with the amount of flexibility that you need. Too much of either can create a system to fail.
insect warfare
QA=Question Authority
On top of what Dave has said, 4.2.3 (c) more specifically requires that "changes and the current revision status of documents are identified". This can mean very different things to very different companies.
For example, "changes" (such as revision history tables for controlled documents) may be present in every document at one company, but at another company those changes would not be readily available to its user, but rather these tables might be stored on a local machine, and only made available by the document controller upon request.
Likewise, "current revision status" may mean a version number or letter to one company, but to another it may mean simply "approved" or "draft" or "obsolete".
Whatever your case may be, the core component to meeting this requirement (or any other requirement) is how "effective" it is at achieving the results you had planned to achieve. Gap analyses and internal audits should be the first weapons you use to evaluate and determine if such controls are in fact appropriate and effective. NOTE: "Effectiveness" is defined in ISO 9000:2005 as the "extent to which planned activities are realized and planned results achieved".
Brian :rolleyes:
neash83
Thanks for the opinions.
The reason I think it needs to be controlled better around the two issues I mentioned is because of the importance of the product specifications within the business.
If the product specification changes during the lifecycle of a product it requires external recertification (managed by QA). Now obviously if we don't have a formal approval route for new revisions, changes can get made to the specification without QA being aware. While I've not found any objective evidence (yet) I'm fairly confident there will be incidents in which this has happened, meaning we will have product specifications which do not tie up with their original external certification due to uncontrolled amends.
My second point around change history ties in with this, if product specification revisions are occurring and even if they were controlled 100%. QA would still need to specifically know what those changes were in order to acquire the necessary recertification.
Thanks again.
B Control of Duplicate Documents - Limited Scope (long) Document Control Systems, Procedures, Forms and Templates 5
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 5
L Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R Process control documents - Context of API Spec Q1, Clause 5.7.1.3 Other ISO and International Standards and European Regulations 0
qualityegghead ISO13485:2016 4.2.4 Control Of Documents - Lifetime of the Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 3
C Defining Approvals Required for Design Control Documents ISO 13485:2016 - Medical Device Quality Management Systems 6
N Responding to NADCAP nonconformance - Control of External Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
P Document Control - Do hard copies of documents need to be signed? Document Control Systems, Procedures, Forms and Templates 3
M Retiring documents in Document Control Procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Managing Level 3 Production Documents - Document Control System Help Document Control Systems, Procedures, Forms and Templates 6
M Document Control Management - External documents flowed down from customers Document Control Systems, Procedures, Forms and Templates 2
S AS9100 Control of Documents and SAP Implementation Document Control Systems, Procedures, Forms and Templates 1
M Control of External Documents such as customer manuals AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 28
Gman2 Control of Documents and (FORMS) on a Computer Network ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
T Information Gathering Documents and Document/Record Control Requirements Document Control Systems, Procedures, Forms and Templates 9
T Customer Specific Documents and Records - ISO 9001 Control Requirements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
drgnrider Control of External Audit Notes and Documents Document Control Systems, Procedures, Forms and Templates 8
drgnrider How to control documents that most likely won't change ever ? Document Control Systems, Procedures, Forms and Templates 5
U Do we have to have foreign legal documents? (ISO13485 4.2.3 document control) ISO 13485:2016 - Medical Device Quality Management Systems 3
A Company Name Change & Control of Documents Document Control Systems, Procedures, Forms and Templates 9
C Document Control - Details to include on Documents Document Control Systems, Procedures, Forms and Templates 2
J ISO/IEC 17025 - Which External Documents require control? ISO 17025 related Discussions 6
S Read Only & Password Protected - Sufficient to Control Documents under 4.2.3? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
W Control of Obsolete Documents Document Control Systems, Procedures, Forms and Templates 21
T Are Control Plans "Summary Documents" not meant to replace Work Instructions? IATF 16949 - Automotive Quality Systems Standard 3
C Control of Documents Procedure - Audit Nonconformance Document Control Systems, Procedures, Forms and Templates 30
Q Control Of Documents and Forms - Formats and Numbering Document Control Systems, Procedures, Forms and Templates 3
Q Control of Customer Documents (Documents of External Origin) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
T Document Control Master List for Obsolete Documents Document Control Systems, Procedures, Forms and Templates 6
K Control of Documents or Control of Records? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 27
S Referencing other documents in Control Plans Quality Manager and Management Related Issues 5
F Nonconforming Product Procedure vs. Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
L How to control some Documents and Records (ECN's and ECR's) Document Control Systems, Procedures, Forms and Templates 1
P Electronic Record Control (Specifically editable records not fixed documents!) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Document Control using Wiki - Cannot Create all Documents as Wiki Pages Document Control Systems, Procedures, Forms and Templates 10
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
B Reusing paper of Obsolete Documents to Control Waste Document Control Systems, Procedures, Forms and Templates 12
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
R Which documents to control apart from QMS related procedures? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 23
K Link between Control of Documents, CPAR & Control of Non-Conforming Product Procedure ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Control of Documents - Converted online in SharePoint Document Control Systems, Procedures, Forms and Templates 9
T External Document (Documents of External Origin) Control Template example wanted Document Control Systems, Procedures, Forms and Templates 14
A Designing a Documents Control System from scratch (in a php intranet) Document Control Systems, Procedures, Forms and Templates 5
R Control of Documents - Drawing (soft copy) for further work by other Consultants Document Control Systems, Procedures, Forms and Templates 1
H 4.2.3 Document Control using Microsoft Sharepoint - Visibility of Draft Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Living Documents which change every day - Control or Uncontrolled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
